Oh my, I wish there was a gofundmyimagination site where others could borrow some of that stuff.
Brass is good. Great pictures too.
Need some sort of -fire name for it.
Thanks OL
I thought it was here…
Certainly Not! :laughing:
It’s worth the time it takes for the pictures to load. A few words of text with the pics would help figure out which end we’re looking at. Fun puzzle figuring it out. This one reminds me of when I could still see small. Congratulations!
You’re too kind, thanks.
Added brief descriptive text to images.
I can see we have another Brass Master in our midst! Seriously, CRX, your build is indescribably awesome already, and you still have parts three and four to go!
My favorite entry so far. Do you intend to polish the surface?
Thanks, yeah there’s still final tweaks, sanding and polishing to be done, i might even make them all black - just kidding! :laughing:
I was thinking of giving the acrylic window of the lantern a sanded/ brushed finish for a more diffuse light output - opinions welcome on that.
Oh, I feel so outclassed and you’re only half way. Awesome work CRX.
For the diffusion try a bit of tape first to see if you like it. Maybe have some funky design on the tape (inside the tube)…? Just a suggestion.
Good idea, thanks pink.
Or cut a negative, stick it on, spray paint, then remove the negative. Sort of like OL’s flame Mag.
You sir are a mad nutter. Where have you been hiding this skill? This is coming along beautifully. I may have to steel your Plasticine idea sometime.
Wow! I’m in awe of your imagination and talent.
Part Four – Magnetic Brass UV Light and 10440/ 10180 Charger Module
This battery charger/ UV light module is held together by strong neodymium magnets and friction.
Powered by and charges any length 10mm round cell (10440, 10250, 10180)
Made from 15/32” (11.9mm), 7/16” (11.1mm), 3/8” (9.52mm) and 13/32 (10.31mm) brass tubing and 0.5mm brass sheet.
Height – 80mm
Depth – 12mm
Weight – 26 grams
Parts - 24
Time - 12 Hours
Thanks for looking.
Was thinking more micro bat signal.
This is great, I love it!
I just noticed your vice. Did you make it?
No, i got that years ago from a crazy old antiques dealer i used to know.
+1
I, sir, am also in awe of your imagination and talent. Absolutely amazing work. This is exactly what I hoped for. Members making things by hand like when craftsmen made everything by hand. I can't wait till you do the custom hand engraving on them! Truly awesome work.
This is the right stuff! Reminds me a bit of some of the things I did in the first comp. No way I can repeat that kind of effort but it’s good to see a similar approach again.
