It is bright, gets hot really quick. I spent a lot of time learning how to do things. Then about an hour to recognize that reflector was doing short circuitā¦from the temperature one spring collapsed due to hot, but fortunately - nothing else was burned.
Since I was using regular Convoy light - not the host - I had to desloder the driver from pillā¦.that was really difficult. How do you do this?
Afer that - another challenge was to solder new driver in placeā¦maybe you have also some hint for this?
Of coarse, but Iām designing a headlamp that will be made from aluminum (CNC machining). This is just a protoype test to see if I want to make a triple headlamp alu case. I donāt think so though, Iāāll probably pursue my other expensive ācheapoā prototype: Build: Dual XP-L headlight project.
I made up an extension ring for a DQG 26650 to take a Khatod optic. I havenāt filled it with running gear yet. The thread onto the body worked out a little bit tight but I think itās a good thing because I notched a groove in the extension ring for the optic to sit flat ie the optic has a nob on one side from manufacturing (I guess thatās what it isā¦?). Now the optic wonāt try to spin when I screw the bezel on and off :sunglasses:
Edit: just rotate the optic some 60Āŗ and put a new slot in the adapter ring, lining up the TIRās and still keeping the notch, albeit on a near opposite side.
Sputtering in this context is fogging the surface with sparse droplets of a clear finish that doesnāt yellow much, it breaks up beam artifacts. There ought to be some posts here on it, I know OL has done some. As opposed to sputtering in outrage though the pictures brought to mind might be similar.
sk68 clone.
Part of host threads are cutted off, sliding tube is fixed in lowest position.
Custom copper pill, XP-E2 triple with Carclo lens under 20mm glass.
P.S. I have lots of this hosts and pills but no time at all so I can send them to anyone who will pay shipping cost.
Yes, sipik AA clone host without stock pill with copper one. Parts may look not good and sometimed requires lots of hand work time (which I dont have).
Need to check how many they I have. I suppose 15-20 sets.
Would love one set if shipping is reasonable, i would love to try and assemble one if it is possible only by hand work, donāt have any power tools for the job.
Chech how does pill enters tube (mid part). It should be pressed inside, if it can not be pressed sand pill OD.
When pill is pressed and you are screwing this set into host measure how much distance between tube end and host. Then you need to cut this distance from part of host with internal thread
Pill is press fitted into the tube that is used for the focus and then screwed into the host, then measure for clearance for the optics and led star and then cut the required size off the host? It does not seem that hard, but i cant find any 14500 battery around, had few dunno where they went, might be thrown away, so im out, sorry for taking ur time
Would using DC fix work also (I donāt knowā¦ Iām just asking)? Also, there was someone here who bought a quantity of DC fix and was selling smaller pieces, but I donāt recall who that wasā¦
