Convoy L6 and 26350 - Short tube or lego?
Shorter with the same input voltage to the driver is what patmurris means.
So it would be a smaller light.
Interesting question!
I think the L2 tube will interchange if I have understood correctly.
Yes, L2 and L6 tubes are interchangeable.
Awesome. I had been wondering the same thing. Are the short L2 tubes available anywhere? I only see the long ones in Simon’s store.
Ah, right, I get it.
Runtimes would be reduced by half though!
Thanks!
Now to find a single 1x26650 L2 tube… I’ll ask Simon at Convoy.
I have asked Simon through the AE messages system his reply was “sorry no short tubes”. Lets hope it will be available in the future.
…same answer. :frowning:
Hmmm, if I’m following this, if the L2 and L6 tubes are interchangeable… My L2 tube has threads 1/2 way down to turn it into either a 1 cell or 2 cell light. Just buy another L2 tube and use the front 1/2 of it on the L6? Would that give you what you want? I didn’t try using one cell in the L6. I suppose I can. All I have charged at the moment are 18650 cells and one wouldn’t light the light. I’ll try again later tonight with a 26650. Or will I need 2 cells to get the voltage?
That raised a question for me. If I use part of the L2 tube on the L6 to make a 3 cell light, will it allow another cell in it for increased runtime? Will that hurt anything? :slight_smile: Other than my arm?
I already tried the L2 as a single cell light with a 18650 and it worked fine.
Maybe if someone purchased long one piece tube for L2 could have a spare short one. I have L6 and an L2 host but I want to build L2 as a single cell.
@BrianK: The L2 has a 3V emitter and only needs one cell. Its driver does allow two cells though, hence the optional long tube.
The L6 has a 6V led and needs two cells - it wont work with one. However, with short 26350 cells you can fit two in a one cell tube and build a ‘short’ L6.
Right now the only way to achieve the short 2x26350 L6 is to swap tubes with a L2.
2x26350 may be too long for convoy l2 1s battery tube
Thanks. I thought that might be the case about the voltage in the one battery L6. Would adding 1/2 of the L2 battery tube to the L6 to make a 3 cell L6 hurt anything in the L6 with the increased voltage?
Has anybody been trying this in the meantime? A 3x 26650 Convoy L6 would surely be an impressive beast. :smiling_imp:
I don’t think so… it says Working Voltage: 5.4-8.4V on the GB specs…
http://www.gearbest.com/led-flashlights/pp_360866.html
Thanks for the feedback! Would have been too nice to impress the Maglite fans even more. :wink:
i has found this
https://th.aliexpress.com/store/product/L2-L6-short-tube/330416_32803828707.html?isOrigTitle=true
is there used for replace L6 to 1*26650 ?
or use for +25560 is to 3+26650?
The Convoy L6 requires 5.4V – 8.4V input voltage to power the XHP70, so you always need two batteries. One battery is not enough, and with three batteries the driver and/or the LED could be damaged due to excessive voltage.
I.e. using the short tube you can operate the L6 with two 26350 cells. This might not make a lot of sense, but looks very cool. :sunglasses:
I asked Simon the following question regarding this single-cell tube :
and he answered:
So the L6 will run on 12 Volts (3 cells), only not for a long time, as it gets too hot.
personally, I would like an extension tube so I can run 4 26650s with an XHP70.2, reduce the current needed for the output across the lockout switch.
