Is your manager and engineer also your financier? The lathe looks real nice especially for the age. Looking forward to the update.
Thanks for the background on you lathe. Pretty neat set up. Best wishes on mastering that hunk of titanium.
So, here is the overdue update:
I finally found some time to get started on the tail cap.
The lathe is still all nice and clean:
Now let’s make some titanium shavings!
The titanium rod has a diameter of 30 millimetres on the outside and my three jaw chuck has an inner diameter of 30 millimetres as well. Since I want the part I am working on to be as close to the chuck as possible in order to avoid rattling, the diameter needed to be decreased a few tenths of a millimetre. At this point I was pretty curious about how my lathe and the titanium would perform. As it turns out, it isn’t a big problem. There seems to be a lot of respect for titanium, and I have to admit that I can’t take off too much material at once, but with a little bit of patience, good lubrication and very sharp carbide cutting plates, it works great.
Now the chunk of titanium fits nicely in the chuck:
So, I began shaving off material to reach the right outer diameter:
Next, I measured and controlled the diameter. I always measure stuff like that, so prepare for a lot of measuring
24.99 Millimetres, where 25.00 Millimetres was desired - that’s a very good fit and I am satisfied. Actually it’s just a flashlight and not a normed engineering fit (can I say that?) so I wouldn’t need to be that precise and could just measure with a caliper, but whatever, why not be that precise? (Apart from wasting my life time haha)
Having gotten the right diameter, I started shaping the outside of the tailcap:
So that’s it for today, thanks for reading and tomorrow I’ll continue with the inside of the tailcap.
Thanks for the great pictures. Good luck with the build!
Thank you, I am glad you like the pictures.
Haha, well she certainly is the one I will have to convince of the usefullness of every bigger purchase for this hobby
You must be Joking! What do you do for a living?
‘hand scraping’ isnt something you see a lot nowadays. And I know it ain’t easy. I can’t do it (actually never tried it…) but my colleague does it.
That is a really nice lathe. I would love to have one similar in size in my shop at home. Thanks for sharing,it doesn’t look as old as you say it is. Very well taken care of. Best of luck on your light.
Thanks! I am studying right now, but nothing related to machines. And well, it is something completely different if someone professional does it or I am just scraping around a little in my free time. Hand scraping is kind of an art in itself and I would never dare to say that I only remotely mastered it. But doing it on a hobby like level isn’t that hard. You just need a lot of patience. Are you working in this direction? Müller Nick has many videos about hand scraping on his channel. I especially like his video about how the Chinese spotting technique (certainly applicable to my Chinese milling machine haha)
@ Andybibbville: I like it a lot and it is very light and handy with just 65 kilograms (around 140 pounds) which is unfortunately also it’s biggest downside. It just isn’t as sturdy as a heavier one.
After shaping the outside of the tailcap I started with the inside:
Again, measuring, this time the inside:
Everything is ready for threading the tailcap:
Here I used a tool holder with a Carbid cutting plate:
So, the tailcap is nearly done and ready to be parted off. I just added a chamfer to the inside of the tailcap as well as to the threads. Always add chamfers to everything There will be no sharp edges and it feel and look very smooth and well made:
And the tailcap is parted off:
A picture of the inside (you see a chamfer at every edge):
After the exhausting process of making the tailcap my manager and engineer made some lovely lasagna for dinner :
And after that I was strengthened enough to start on the body:
More measuring, but the diameter was still a little too big:
So I turned it down until the diameter was right, and I then measured again, just to be sure:
That’s it for today, thanks for reading and more tomorrow!
Is there a reason you’re posting everything twice? (including all the pictures!)
Hi Fritz
If it is ready,please make me a good offer.
I love your lights.
Regards Xandre
Yes. I think it’s nicer not having to look around for all the stuff in the thread and it’s also nice being able to post pictures in the ‘update-posts’.
Does it take too long to load the page?
Thanks but I am sorry, this light won’t be for sale.
Not a problem for me. Just wondering why.
Very satisfying seeing the nice shiny threads in the Titanium, isn’t it?
Nice job documenting the work. Looking good…
OK Well if anyone has troubles because of too many pictures, please let me know.
Thanks! Yeah, it is very satisfying in general since it gets so shiny with those CCGT carbit inserts Usually I don’t like the shiny stuff but here it’s great.
Since the body had the right diameter I could prepare cutting the threads for the tailcap:
With a parting tool I made the indents for the O-rings:
Using an indexable threading tool I cut the threads on the body:
You get nice little shavings:
After the threading was done I added chamfers to every sharp edge:
Even to the one I can’t reach with the normal tool:
Having done that it’s time for a test fitting:
It fits very nicely and here it also pays off that I have been that precise - you can’t see the transition between tailcap and body:
I parted off the tailcap with a little excess material (it is easier to take material away than to add to it), so I measured the length of the tailcap and need to take 0.05 mm of material away:
Now it’s time to finish off the tailcap and adding some chamfers:
The tailcap is done:
I continued by shaping the body:
Since I changed the angle of the cross slide several times I needed to measure again:
And the body is shaped on the outside:
Looks already very flashlight like:
That’s it for now, thanks for reading and more later.
very nice this is going to be a top quality build…
Looks really nice
WOW!
What a report, thank´s. :+1:
If you set width to 100% the page might load faster.
