Prototype spacer. I also have other reasons for using a spacer. I’ll get into that later after I see if there is any light output penalty…
First step is to use the drill press to hole saw a blank…
The first blank was done with a 2-1/4” saw and was too small. This one with the 2-1/2” was a tad too large to fit inside the neck…
The drill press was used again along with a rasp and then sandpaper…
That did work although the blank turned out slightly out of round. End grain and side grain of the wood removed at different rates I guess. Then I sawed out the center…
We have a donut!!
I used 80 grit paper on the benchtop to hand sand down the high spots…
To locate the position of the heat sink mount holes I made a pencil tracing. Yes, I am a mystery / detective fan!!
The punch marked the holes…
With the holes drilled through the lid, the LED was trial fitted with the heatsink on the top side of the lid. The spacer was temporarily fixed in place with double stick tape…
Like so…
Some temporary power hookup and we have light!!!
Now to wait for nightfall to see if the spacer causes any appreciable reduction in light output. Don’t know if many photons will get absorbed by the wood. Maybe line the spacer with aluminium foil?? (I never should have put the window in the workshop / garage….)
Cool, you can pick up some efficiency by sticking a reflector in the donut. Anything that fits will recover energy lost into the wood. I think your right about end/side grain. To stay round the wood can’t wobble and the cutting surface(rasp, sandpaper, whatever) has to be fixed. At least that’s been my experience. Threads also seem to grab unevenly in the chuck so I use a carriage bolt with the end removed. Sometimes I’ll press a bushing into the table but that can be a false security and may or may not put more pressure on the chuck.
If I have time tonight I’ll try it in the darkened shop with
(a.) the spacer as is now
(b.) the spacer with an OP reflector from an S2… it fits the hole and thickness of the board used
(c.) no spacer, dome right over the led.
I dug out my old Sekonic L28C2 photo light meter… really old school thing. (That dates me I think… :laughing: ) A selenium cell and analog meter. I have no idea if it will be able to discern differences at the light levels I intend.
Wow! I do wish I had a modern digital lux meter. I think that will be the next thing I buy. I’ll have to do a search on the topic of what’s good.
My old Sekonic analog meter showed the best output to be without any spacer and the dome placed directly over the emitter/mcpcb, listed above as setup (c.).
With setup (a.), the spacer in place but no reflector, the output was noticeably lower. In photographic terms there was slightly more than 1.5 f-stops less light, measured at the same point and distance from the dome.
With setup (b.), the Convoy S2 reflector inserted in the spacer center hole, the output was almost as good as with no spacer at all. Maybe only 1/4 f-stop less than no spacer at all, setup (c.). Considering that I have other reasons for the use of a spacer I believe this is the direction I will take. I used a small plastic “washer” under the reflector to insulate the reflector from the mcpcb.
I may do some further tests with a different reflector I have from an old mini-maglite and with changing the height of the reflector or perhaps the spacer thickness. But that will have to wait a bit.
Thanks to RFD for affirming that photons may be getting lost due to the wood spacer.
First, for those who don’t know and want to know, a forstner bit is made to drill a flat bottom hle in wood. This is one…
I need a cell holder. Here’s my first idea/attempt. The layout on a glued up piece of pine. This is a first prototype. I intend to use hardwood for the final.
Here it is drilled and cut to rough size. Drilled with drill press and corners cut using a cut off / mitre saw
I neglected to take in between shots for this prototype. For the final I will remember! I used a coarse hand rasp, then a finer one. The final version will be taller or perhaps an upper and a lower disc with dowel or tubing separators.
The block and cells do fit through the neck of the mug…
Not quite enough space for a centered fifth with the size restraints caused by the mug neck inside diameter. There’d be no wood left to hold things together.
Found it on ebay a while back. Search for “Mini Programmable Adjustable Digital Regulated Power Supply ” or something like that. For my flashlight needs I power it with a 30 year old TripLite 12 volt 10 amp benchtop power supply. The “MPADRPS” can put out amps but needs some fan cooling to sustain that. ….another little project that needs doing…. There may be better ones, but I only paid $20 probably a year ago.
Did some more today. I forgot myself and had glued up and begun to cut the cell block and missed taking some photos. The block I believe I’ll be using started out glued up like this one. Except the one I used is maple, padauk and walnut, whereas the light colored wood here is red oak. The orange wood grows like that. It is african. Walnut is from a friend’s farm in VA and the maple is a left over from a 25 year old table project. never throw much out.
This is the one I am using. I cut the pieces mainly using the mitre saw. First I cut it to a square, more or less, then an octogon as shown. I end up with lots of cool little shapes of the different woods.
Then it was to a vice.
I began rounding off the sharp corners with a coarse wood rasp.
After a while it was somewhat more cylindrical
Next a switch to a finer toothed rasp/wood file
Much better, but only close…
Yes, that is me hand filing and using the camera self timer
Once the shape was close to what I wanted i also filed lengthwise to try and get the best cylindrical shape
This is a better fit than the first pine prototype.
Never crossed my mind but the mug handle is just like the old 6V lantern cell flashlights. Pretty obvious when someone else thinks of it. :person_facepalming: Good job! From here you could go with a tail standing area light as you planned or throw in your choice of reflectors behind the mason jar lid or both as so many “emergency lights” do.
The cells need a contact plate for both ends. This is the plate that will service the bottom end which will be the positive + ends of the cells. I cut the plate from a strip of 2” wide, 0.010” brass. The raised contacts are brass 4-40 machine nuts. Soldering them in place was tricky as they kept sliding about. I used them as the design is to use some of the many flat top cells I have on hand. Heat damage to the oak scrap from using a butane torch for heat.
… another shot including the cell block. The W. denotes the section that covers the walnut wood segment.
A view of the cell slot end with the plate held in trial placement.
