Test/Review of Charger 1.5A 3.6-4.2V (TP5000)
27 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 48 min ago
DSC_4427
This is a charger module from ebay, it is based on the TP5000 charge controller, depending on settings it can either charge with 4.2 volt or 3.6 volt.
The official specifications from the ebay page is:
  • Charge module- Switch mode charging.
  • Current- 1.5A. changing the charging current by changing the Rprog resistor
  • Charge precision- 1.5%.
  • Input voltage- 4.5V-9V.
  • Full charge voltage- 4.2V/3.6V.
  • Led indicator- when soldered with LED
  • Input interface- 4.5-9V.
  • Work temperature- -10°C to +85°C.
  • Inversed polarity protection – NO.
  • Size- small to 17×18×5mm.
I got it from ebay dealer: wkws20
The above specifications are not completely correct, the module I got was configured for 2A charging.
DSC_4414
I got it in this bag without the led soldered in.
DSC_4424 DSC_4422
The regulator is a switcher with an inductor.
DSC_4418 DSC_4419
DSC_4420 DSC_4423
functions
The supplied led is a 3 pin two color led that fits directly in the holes.
jumpers
Default selection is 4.2 volt with 10% precharge current, to enable the other function a knife must be used to cut the trace between the two solder points.
currentSelect
The charge current can be anything from 0.1A to 2A, this table shows some of the possibilities. Without a heatsink it is best to keep the current at 1A or lower.
supportedBatteryTypes
supportedBatterySizes
Charging LiFePO4 works, but is not ideal.
Measurements
  • Power consumption when idle is 0.1 watt
  • Discharge with 2uA when not connected to power.
  • Discharge with 6uA when connected to power (5 volt supply).
  • Will restart if battery voltage drops to 4 volt (4.2V setting).
  • Will restart if battery voltage drops to 3.45 volt (3.6V setting).
  • From 0 to 1 volt it will charge with 0.4A (1A setting).
  • From 1 to 2.9 volt it will charge with 0.1A (4.2V/1A setting).
  • From 1 to 2.4 volt it will charge with 0.1A (3.6V/1A setting).
Charging 4.2V LiIon
Charger%201.5A%203.6-4.2V%202A%205V%20(PA18650-31)
This looks like a very good CC/CV voltage charge curve with termination at 10% of charge current, here 200mA, the current is slightly below 2A due to heat.
Compared to linear regulators this regulator reduces current closer to 4.2V, this will make the charging a bit faster.
Temp3121
M1: 95,3°C, M2: 92,3°C, M3: 79,3°C, HS1: 117,5°C
The chip gets fairly hot and reduces the charge current.
Charger%201.5A%203.6-4.2V%202A%209V%20(PA18650-31)
With the higher input voltage the charge circuit could not maintain full charge current, it got too hot and regulated the current down.
Temp3123
M1: 113,7°C, M2: 92,6°C, M3: 81,0°C, HS1: 115,6°C
With 9V input the diode gets very hot, this make the circuit board hotter and the chip has to reduce the current even more.
Charger%201.5A%203.6-4.2V%201A%205V%20(PA18650-31)
At 1A charging current the CC/CV voltage charge curve also looks fine.
Temp3125
M1: 55,1°C, M2: 54,5°C, M3: 46,6°C, HS1: 57,9°C
1A current looks much more acceptable in temperature, nothing is really hot here (At least for electronic).
Charger%201.5A%203.6-4.2V%201A%209V%20(PA18650-31)
At 1A there is no heat problem with 9V input.
Temp3127
M1: 78,7°C, M2: 68,5°C, M3: 58,9°C, HS1: 79,9°C
With 9V input the diode gets warm again and increases the temperature of the chip, but it is still acceptable temperatures for electronic.
Charger%201.5A%203.6-4.2V%201A%205V%20(SA18650-26)
Charger%201.5A%203.6-4.2V%201A%205V%20(BE18650-26)
Both the new and old 2600mAh battery was charged perfectly.
Charger%201.5A%203.6-4.2V%200.1A%205V%20(KP14500-08)
Replacing the two 0.1ohm resistors with a single 1ohm resistor the current is down to 0.1A. I tested with a 14500 cell and it was charged perfectly to 4.2 volt, but with this low current ot took some time (0.1A is for smaller cells).
Charger%201.5A%203.6-4.2V%200.9A%205V%200.5ohm%20(PA18650-31)
Simulating a long cable from a USB supply did not really affect the charger.
Charger%201.5A%203.6-4.2V%200.9A%205V%202ohm%20(PA18650-31)
Adding more resistance between the 5V and the charger will slow down the charging, but the battery is filled.
Charger%201.5A%203.6-4.2V%200.9A%205V%205ohm%20(PA18650-31)
Even with 5 ohm in series it works, but very slowly
Charging 3.6V LiIon
Charger%201.5A%203.6-4.2V%201A%205V%20(18650-LiFePO4)
Breaking the 3.6 volt jumper I tried charging a LiFePO4 cell. The charge voltage is fine, but I do not like the automatic restart, it is placed at too high voltage.
Conclusion
It is a nice module for charging 4.2 volt LiIon batteries, even fairly small ones, the flexibilty in input voltage makes it useful for 6V unregulated solar panels.
I am not impressed with 2A performance, either a heatsink must be added or one of the resistors must be removed for best lifetime.
Notes
L4M4
L4M4's picture
Last seen: 1 hour 10 min ago
Thank you for this test!
What does that “10% precharge” mean? Never read it before.
Edit: Can someone give me a link to this charging circuit?
In germany, you only have access to PowerSellers from China – For me, the “wkws20”-Shop is empty.
HKJ
HKJ's picture
It means it will charge a over discharged LiIon cell careful as it is supposed to be.
The reason you can disable it may be because the circuit can also be used as a led driver.
Halo...
Halo...'s picture
Last seen: 5 years 5 months ago
Very nice!
Thank you HKJ!
Is the termination always at 10% of charge current? Hard to see exactly where it is on your 100mA chart.
Halo...
Halo...'s picture
wkws20 seller: http://www.ebay.com/itm/4-5-9V-1-5A-Lithium-ion-or-iron-phosphate-LiFePO...PCB-18650-A123-/121267753845
Another seller: http://www.ebay.com/itm/4-5-9V-2A-Lithium-ion-or-iron-phosphate-LiFePO4-...PCB-18650-/181728713087
HKJ
HKJ's picture
Yes.
fritz15
fritz15's picture
Last seen: 5 months 4 days ago
Thank you very much for the test. Does this charger drain the battery empty if it is disconnected from the power source and the battery is still connected?
Barkuti
Barkuti's picture
Last seen: 1 day 28 min ago
Hello!
TP5000 @ aliexpress
Cheers Party
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
HKJ
HKJ's picture
No: “Discharge with 2uA when not connected to power.”
ko4nrbs
Could you use this without the LED? If using Solar power wouldn’t the LED take power away from the charger?
Bill
HKJ
HKJ's picture
ko4nrbs wrote:
Could you use this without the LED? If using Solar power wouldn’t the LED take power away from the charger? Bill
The led do not use much power, but you could leave it out.
Barkuti
Barkuti's picture
In retrospect, seems you complained from a too high of a LiFePO4 charging restart voltage, HKJ.
From what I've observed among some different cell reviews, the actual LiFePO4 resting voltage seems to lie ≈3.4V.
Mmm, digressing a bit off the topic, I was wondering if I could (snugly) fit 3×10440 cells inside a PP3 battery case…
Cheers fellows Party
DoubleA
DoubleA's picture
In parallel setup?
and on the first day he said "Let there be light"...
Barkuti
Barkuti's picture
Of course in series, DoubleA.
DoubleA
DoubleA's picture
But you can’t charge those cells in series with that module.
Barkuti
Barkuti's picture
Yes, I can't charge 3S 10440 LiFePO4 cells with these modules, DoubleA; I never said I was going to do such a thing Wink (off-topic).
Cheers
DoubleA
DoubleA's picture
Oops, my bad. I thought you were trying to charge multiple cells. Big Smile
supersonic
Last seen: 3 years 8 months ago
Hi,
I am new!
I have bought two Sanyo NCR20700B batteries.
I would like to charge the batteries by using TP5000.
What you think, is this module suitable for the battery?
If not could you suggest something else?
Thanks!
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 55 min ago
It would be great charging at 1A.
Would work quite well with an appropriate 20700 cell holder, and charge in around 4-5 hours, which would be perfect for the cell.
Barkuti
Barkuti's picture
supersonic wrote:
… could you suggest something else?
Thanks!
If you can do with 5V of input, TP4056 modules are small, low profile, good and cheap. They were tested by HKJ to charge at 0.85A, can work in parallel from the same input supply (input and output grounds are common), are sold in a variety of charging boards with miniUSB or microUSB input and even basic DW01A + 8205A protection circuitry… and are this  cheap: https://www.aliexpress.com/item/Free-Shipping-5Pcs-TP4056-Micro-USB-5V-1A-18650-Lithium-Battery-Charger-Board-With-Led-Indicator/32804303644.html
Another alternative is a proper CC/CV module, I have many XL4015 units and they work very nicely for a variety of purposes (fully customizable current and voltage output). Example: https://www.aliexpress.com/item/5A-DC-To-DC-CC-CV-Lithium-Battery-Step-Down-Module-Charging-Board-LED-Power-Converter/32799532951.html
Cheers Smile
supersonic
great, thank you I will try it out… Thumbs Up
supersonic
Regarding XL4015, is there any indicator to see whether the battery is fully charged?
Barkuti
Barkuti's picture
supersonic, in the above picture two leds can be seen at the lower right board corner; out of these two the one at the left (closest to the LM358) is on when in CC mode, while the rightmost one lights up (and the left one turns off) once the output current has tapered off below 10% of the set ratio at the right (CC) trimpot.
Alternative unit with slightly different PCB and colored leds:
https://www.ebay.com/itm/1-2-5-10Pcs-Lithium-Charger-5A-CV-Buck-Step-Down-Power-Supply-Module-LED-Driver/191993567480
These boards won't work in constant current mode with less than ≈7V of input, bear this in mind though.
Cheers Party
Originally posted on Thu, 05/17/2018 - 01:23; edited to add extra clarification info.
BlueSwordM
Wait, is that why when I tried to charge super capacitors with a 5V power supply, the current kept going up until the power supply shut off, and not doing it with a laptop power supply?
Now I get it. I have 5 of them regular buck converters, and 5 of them which have MPPT operation.
These work very well at parallel charging, and safe low voltage recovery voltage at <2V lithium ion cells at 50-100mA.
DoubleA
DoubleA's picture
Barkuti wrote:
If you can do with 5V of input, TP4056 modules are small, low profile, good and cheap. They were tested by HKJ to charge at 0.85A, +can work in parallel from the same input suppl (input and output grounds are common)
Sad I don’t think you should do that. I’ve seen elsewhere that these modules need isolation if powered from the same supply.
Anyways has anyone tried them TP5100? heard they can charge both single and 2S
Barkuti
Barkuti's picture
DoubleA wrote:
Sad I don't think you should do that. I've seen elsewhere that these modules need isolation modules? heard they can charge both single and 2S
Well, others like pilotdog68 have done it successfully besides me:
The above is a custom powerbank I made for a close friend. It has a good old PCB featuring a single TP4056 charging chip onboard which can be seen just under the red cable in the photo, besides the onboard 5mm led. As can be seen in the photo I boosted its charging capability with an additional TP4056 board, and that thing is still operating. The powerbank is now housed inside a different transparency box because he once crashed it hard. Big Smile
Cheers Smile
DoubleA
DoubleA's picture
Are you sure these modules will work fine without any issues if you wire them to a common power supply without any isolation? If so then I would like to do that setup with 2 TP5000 modules (the other type, the red one which HKJ reviewed) in parallel to charge 2 LiFePO4 cells simultaneously.
