Due to the arrival of the new little half cells (26350) I did some shuffling around between a couple of Convoy lights.
I had the L6 with XHP-70 and a 2 cell tube for 2 26650âs and a tactical ring, the stock light with an output bump to some 4600 lumens. I also already had an L2 with XP-L and Bistro driver, single 26650 cell tube. So today I got busy and did some swapping and modifications such that the L6 now has a single cell length tube with 2 of the 26350 cells, the tail cap is off my L2 and has been bored to allow an 26700 cell to fit, perfect for working with 2 26350âs.
So now the L6 with itâs larger head has the appearance of the L2 in short form. Love it!
Then I modified an LD-2 driver for the L-2 light, put an E4 1D XHP-35 in it with the 2 cell tube from the L6 so it holds 4 of the 26350 cells. These little cells are 2000mAh in capacity, so now the 12V emitter is taking some 2.8A and Iâll still have close to an hour run time and great throw, but considerably more lumens over the XP-L in this light. I have all 6 of the short cells on the charger now so I can get some readings.
Pretty neat that my big Convoy is now the small one and my small Convoy is now the big one. lol Confusing though, I know. lol
Edit: The charged 26350âs did a tail current of 3.13A to the XHP-35 E4 1D HD emitter for 2986 lumens and 170.25Kcd at over 800M throw, Iâll take it!
I had no idea that had a press fit (and adhesive?) bezel. Do the other model Olights also have a press fit? Or do some have threaded bezels? If screw in, which ones?
Nice. I did basically the same thing with my light saber, because taking the battery out is kind of a huge pain and risks damaging the internals. Also, it has no true âoffâ switch otherwise; I have to put in a non-conductive âkill keyâ to cut power.
This is just a driver and LED swap, but with a lot of details. Yesterday is the first time I built a Wight FET + 1 x 7135 driver. I have been getting them from BangGood and already built from Richard, because they looked hard to assemble. This one is with a board from OSH Park and a kit from Mtn. Elect. It looks a little crooked, but it works.
I also had to file a 16 mm. Noctigon down to 8 mm. The old star was put in place with rubbery thermal compound, so I used thermal epoxy. I didnât file the pillar of the pill shorter, so I had to add an o-ring spacer to get it to focus, even though it had travel to spare before. The Noctigon added over a mm.
That is an XP-G R5 4C. I put heat sink compound on the pill threads and the front slide o-ring, as usual.
Added: The driver started having problems soon after I wrote this. It may be my build or the narrow ground ring. I plan to try a BangGood A6 driver in it. It worked really well when it worked and was, briefly, among my best lights.
August 20:
Because the narrow ground ring may have been the problem, I switched to a Qlite 11 x 7135 driver.
A problem remained that it went out, without changing modes, when the optics touched the dome of the LED. I added a 2nd o-ring spacer and partially de-domed the XP-G with file. It works now.
Next time: BangGood driver or Nichia LED, less solder between LED and star, file the pillar flat and 1 mm. or a bit more shorter. De-dome.
It seems to be not as bright as it was with the FET driver, but it works. The file de-dome seems to have made the spot smaller.
It seems not bright enough for the current it draws. Maybe the LED is damaged. I am changing to a Nichia LED that may work better and will draw more current. The pill is only about 1 mm. thick at the top, so I canât file it to make up for the extra thickness of the direct thermal star.
I modded the Skilhunt H03F.
First I removed the Noctigon baseplate with a XM-L2 8B4 HICRI that was monuted on my H02.
Then I soldiered on the H03F and checked if it worked.
All good, exept that the Noctigon was too large to lay flat in the head of the H03F.
So I removed the Noctigon from the H03F, I did re-flow a XM-L2 7C1 on the H03F original baseplate and reinstalled it.
Then, instead of putting the H03F toghether as original, I used the TIR optic from the H02, and I gave the H02 the reflector from the H03F.
Now I will use a lot more the H03 and I can still use the H02 (that now is a H02R).
I had one UF-1504 leftover that had a Nichia219C and LD2 driver, that never had good throw. I redid the mod today, and now it still has its high current forward clicky (â6A Ebay-switchâ I prefer a reverse clicky but this 1504 first gen. switch design does not fit a standard switch-board), and a BLF-A6 driver and dedomed XP-G2 S3 3D. For what it is worth for a thrower, the tint is pretty nice, much better than the much used (and now unavailable) S4 2B, and the throw is also really good, I measure 486 kcd at a current of 4.1A on a Keeppower 26650 IMR 4200 mAh, 30 seconds after switch-on.
I think that the mods are well done, with a high amp switch, neat spring bypasses, ledboard soldered to pill, area around the led-die blackened, very clean beam in spot mode. The body does not look mint anymore though, decent enough, but the ano is not perfect on some edges anymore.
In the end I like the impressive throw but still find the light too heavy to take on trips.
A couple 2 or 3 weeks ago while checking out a comment about an S70 clone on ebay I saw a SRK in gold with 9 emitters on the cheap. Stupid cheap, like $13 or something. So I bought one. It came today⌠with Lattice Bright emitters making 1683 lumens on 4 LG HE-4 button top cells. Of course I opened it up and checked it out. They had a large FET for a simple driver, no sense resistor, small pair of wires to a single aluminum mcpcb housing the 9 XM-L copycats. So I pulled the LB emitters, dug around through my ever growing pile of stuff and found 9 XM-Lâs Iâve pulled from other lights an put it back together with 20 ga Turnigy leads. 1811 lumens rock solid, meter wasnât budging. Then I remembered having a second one of Richards SRK group buy driverâs put away⌠so I stuck that in there in place of the simple 2 mode (w hidden strobe) driver.
Now it makes 3881 lumens in High, 1228 lumens in medium and a very miserly 0.38 lumens in Moon. With reversing switch, itâs really nice.
Perhaps later, if I remember, I can make a nice copper heat sink to assist the thick aluminum mcpcbâŚ.
Edit: 4157.25 lumens with the batteries freshly charged and an UCLp swapped in. Works for me!
Edit: Pics of the driver and mcpcb from the e-bay Sky Ray with omitted âkingâ. (itâs a SRK but a clone apparently, although the site showed Sky Ray King lights)
Modded⌠or more like fixed my lumzoo GH10 with XP-L HI and a Zebralight driver rescued from a H600. The reason I didnât repair the ZL instead was the press-fit bezel and would not longer be waterproof after the mod. Awesome compact angle light with excellent build quality all around.
From the BLF Q8 project, got in the V5.1 drivers and reflowed a couple up, bench tested running the latest Narsil v1.1. It now can blink out the firmware vers #, as well as having full access to all strobe modes from ramping:
Also modded up the new UltraFire U-F10, yes, it's a real, true authentic Ultra Fire here, least it says so on UltraFire.com. It's got the driver in the tailcap:
Here's a close up of the 1 sided driver:
And here's the contact board in the pill:
The mods I made were: XM-L2 on SinkPAD, reflowed to the brass pill top (thick shelf), wires upgraded to 22 AWG, spring bypass's, and a resistor mod: added a 0.5 ohm on top of one of the 1.5 ohm resistors (I traced to follow a FET), and got amps up from 0.85A to 1.25A - moderate bump up, but now it does over 500 lumens in flood.
I'm thinking the MCU runs on power via those 3 resistors (bleed resistors?) that sit between LED+ and LED-, but the what that hard white substance covers is a mystery, but it's very low profile.
Anyone have ideas on how this tail driver e-switch works? No separate wires between the pill and tail.
Had a chance to put some XP-G3âs in a few different hosts, one being a Manker U11. Removed the original board and re-flowed a â3â series High-CRI XP-G3 in place of the original XP-L. Definitely exhibits the hotspot-corona K/temp variation others have noted. The tint is the âcreamiestâ 5K emitter Iâve seen, more yellow than the Nichiaâs Iâm used to. Could be exaggerated because of the reflector, (others have said they look better in an optic), or could be further off the BBL line than the Nichiaâs, hard to say because the specific tint bins werenât listed.
Canât speak to specific comparative output because I canât get to most of my equipment, but to the eye it doesnât look like I lost much output, but the throw was improved.
Hopefully I can get into storage and locate some of my stuff, first mods Iâve done in a while and it stinks having now way to measure output. Thereâs also a box of old lights in there somewhere, thereâs a particular one I want mod with one of the XP-G3s, itâs a older E2L Outdoorsman, the one with the factory optic. Originally came with a Lux-III, so it might actually work well.
Iâll try and get some pics up later, can compare between the XP-G3 High-CRI and an NVSW High-CRI, but forgot to take âbeforeâ beamshots of the original XP-L.
I tried a new production style XPG2 S4 2B in my UF-1504. With a fresh Liitokala 26650, I got 463kcd at 30sec. I only have one new style XPG2, bought from MTN, but this one performs quite well.
Not quite as good as the old one which was ~520kcd.
I think those colors showing in the image of the emitter are literally chunks of different phosphors â coarsely ground up, mixed in some medium and extruded to make the spot on the die. The coarser the phosphor material is, the spottier the die looks and the less consistent the color will be from one LED to the next on the same reel.
Thereâs an analogy with prescription medicines I recall reading a warning about:
â some pills are thoroughly mixed finely ground active ingredient(s) and binder, and itâs safe to break them (and theyâre often scored to make it easy to divide them). When you break that kind of pill in half you get about the same amount of active ingredient in each half.
â some pills are coarse chunks of active ingredient(s) in a binder, and arenât safe to divide â when you break them you can get all the active ingredient in one half, and just the binder in the other half.
I recall seeing that kind of spotty color mixing in LEDs used in one of the variations of the ZeusRay, when they were cutting corners on those. Iâd suspect the reels are from a batch of poorly mixed phosphor.
