4th Annual BLF/OL Scratch Made Light Contest- Hand Made 10/31 finished
266 posts / 0 new
FmC
FmC's picture
I just love the hacksaw blade attached to the drill press – priceless! Smile Beer
I kind of wish I was making something round this year, so I could try it out. …yes, I have an idea of what I’m going to attempt to build…. took me some time – hope it’s not indicative of how long it will take to build it!
DavidEF
DavidEF's picture
Last seen: 5 days 22 hours ago
That’s some beautiful wood! Good job on the ‘machine’ work there.
- The YKK Philosophy
MRsDNF
MRsDNF's picture
That is so sweet. I believe I have been owned. Beer
MtnDon
MtnDon's picture
Last seen: 6 hours 55 min ago
Thumbs Up
Rufusbduck
Rufusbduck's picture
Last seen: 7 months 1 week ago
Thanks guys, the hacksaw is pretty crude and by itself can’t begin to compare with even wood lathe cuts but the closer you get to round the less wobble there is and the more even it gets. Stopping the drill, rotating the wood on the tape a bit, and spinning it past the blade a few times does a lot to clean it up but it’s the time spent sanding that does the trick. Probably about 6 hours work in that last brass/wood session and two thirds of it sanding. My two alternate reflectors came in the mail yesterday so the timing is good and I can figure out the appropriate head length and number of fins. We can each have our good days, eh Steve? That gum wood looks a lot like teak, very pretty.
Scott
MRsDNF
MRsDNF's picture
I’m not sure if it looks like Teak or not. I will still be crapping myself until its finished in one piece. Silly
Six hours polishing?
What do you do to get it looking like you have? What sort of finish would you recommend?
Rufusbduck
6 hours total, I forgot about the grinding on the brass which took a bit more than half an hour before it went on the drill press. About half an hour each for cutting the brass bezel and wood collar and an hour cutting the tube which leaves around 3 1/2 hours sanding the wood parts, mostly the tube as the collar just had much less surface area. I’ll use the same epoxy resin sealer without thinning for several top coats then sand the begesus out of it. I’ve also used lacquer but although it dries quickly it takes a long time time to cure(like a month) before you can polish it. The piece you used looks porous which is what reminded me of teak and you’ll need to decide whether you want to fill those pores with putty, finish, or let them show. Raising the grain is where you lightly moisten the wood with a dampened cloth, cut fibers absorb the water and swell more than uncut ones so the wood next to a scratch puffs up and more easily sands off. Spinning to sand makes removing material easier but it’s cutting across the fibers the hand sanding with the grain that gets the wood smooth without the scratches. So it’s spin sand, hand sand with the grain, raise the grain, change to higher grit and repeat. You can repeat raise the grain/ with the grain sanding. Scratches tend to show more when finish is applied and the damp cloth gives an indication of how it might look. Most finishes add Amber to the look of just damp wood
Scott
MRsDNF
MRsDNF's picture
Thanks. Looks like I have a little more homework to do. Thumbs Up
Rufusbduck
There are water based polyurethanes that are pretty easy to use and some woods are nice with just oil and /or wax. You’re right though, lacking specific knowledge it’s possible to screw up anything. What else is new. Sick
Scott
Rufusbduck
I’m making the sleeve tube for the battery tube and have these two brass tubes One is the right ID and the other has the wall thickness I want but which do I use? The thick walled one is a perfect fit for an 18650 but weighs too much and I’d need to pare down the wall thickness on the outside and just a little at the ends on the inside so I’ll use the thin walled stock and cut a slice from it and braze it back together. Sometimes you have to use a hack saw as intended. And another cut Then annealed so I could squeeze it down and file the cut edges smooth. And also take enough of the edges so I could fit the ends inside part of a TP holder I scavanged for the brass several years ago. Brass work hardens more quickly than copper and between squeezing it to see if it fit and opening it up to file some more I ended up having to anneal it 3 more times before the fit was right and I could clean it up and cut the end collars which serve to hold the seam as well as reinforce the tube where threads will be cut. Finally ready to goop it up with flux and braze the seam and collars Good, the seam is closed. Too much brass added but I can grind off excess but can’t rebraze if there’s a void. After getting rid of excess brass and squaring up the ends its ready for me to figure out what to do with it.
Oops
Scott
lostheplot
lostheplot's picture
Last seen: 9 months 5 days ago
awesome work
sorry all images down
thanks photobucket
fritz15
fritz15's picture
Amazing! Does the solder actually get everywhere under the surface at the ends or are there spots which are not covered in or connected with solder?
MtnDon
MtnDon's picture
Very very nice! Isn’t it wonderful to have all those odds ‘n’ ends that you saved for so long…? (TP holder).
Rufusbduck
Capillary action draws the melted brazing wire wetting any pair of closely mated surfaces that have been cleaned well and fluxed. Gaps generally aren’t bridged and poor cleaning or if not enough flux or not enough wire is used then even well fitting joints can have voids which is why I used more than probably necessary. It’s similar to a plumbing solder joint in how the solder instantly flows through the joint but wetting happens at a much higher temperature(glowing hot)and is much stronger than tin solder, more expensive too.. With small or thin parts it’s easily possible to melt them into slag. I’m still not very good or consistent at it since I don’t do it much.
The penalty is having too much clutter but it’s nice when you find the perfect bit not for sale anywhere.
Scott
MRsDNF
MRsDNF's picture
I’m with ya. Thumbs Up
Rufusbduck
I am sooo smart. At least some people tell me so but sometimes I’m not so sure. Read on if you want to bask in my blazing intellect. Facepalm
I decided to use a different method to tap the battery tube threads than the big brass nut I used on the copper threads so I cut a piece of 1” PVC and cut a slice from it so that it would fit inside another section. I needed to ream the inside of the inner piece so the brass battery tube would also fit. Once that was done there was a gap at the ends because the PVC is thicker than the brass collar pieces. So I cut a ring to fill the gap and keep it all centered in the outer PVC tube. Then I tapped and taped a short piece of aluminum tube to also center the tap in the PVC tube. Here it is all put together. Now I just need to grab it somehow. I did the tail end first since the threads are shallower at that end. There’s a 5/8” bit wrapped in tape shoved inside to prevent it from crushing. So far so good. Then I switched it around to do the other end which gets ~20 mm of threading. For awhile it went just fine but then the brass began to slip inside the PVC so I put the whole thing in the pipe jaws of the 5” bench vise. It still slipped some and each time it did I tightened the vise a bit more. All good right ? Wrong! The pipe jaws corrugated the brass. I tried annealing it and rolling it, annealing it and pressing another pipe through it. Finally annealed it one too many times just a bit too hot and effed up the seam and rippled the tube. Trashed two days work with my smarts. I already have replacement parts started and an idea how to prevent a reoccurrence but this sucks the big one.
Small update
Scott
MRsDNF
MRsDNF's picture
Sorry about the good idea not working. I guess you were screwed from the start. Facepalm
There must be more of that Humpty Dumpty getting around the traps than just in my shed. Silly
Looking forward to see how MK2 is achieved. Smile
MtnDon
MtnDon's picture
So many details of construction to work out and it is a real bummer when something goes wrong after so much time being invested. Good luck with V.2 Thumbs Up
Rufusbduck
I think I spent as much of the evening trying to fix it as it took to mess it up in the first place. Fortunately it’s not a case of something I can’t do just something I did wrong. An epic fail would involve harder to replace items like the wood. With any luck I’ll be able to improve MkII.
Scott
MRsDNF
MRsDNF's picture
Were you using anything as a thread cutting fluid?
tekwyzrd
tekwyzrd's picture
Last seen: 3 days 5 hours ago
Ouch… I’ve used the nut guide method in the past on a pontiac engine build tapping to replace push-in rocker arm studs with screw-in studs intended for a big block chevy (after adding helicoils). After damage from a saboteur (one of my brothers) a big block chevy rocker arm broke but the studs held. 700+ hp engine. 1958-1963 big block pontiac engine converted to hei and coupled to a 400 turbo trans in a 77 firebird formula. It produced enough torque you could feel the car twist.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
Rufusbduck
Yes, some light oil.
Scott
fritz15
fritz15's picture
I am sorry, such things are always annoying. But that’s the right attitude, if you have to do it again then at least it’ll be an improved version
Rufusbduck
Out of action for a bit. See op.
Scott
MtnDon
MtnDon's picture
Sorry to hear that. Get well soon, take care of it and do what the docs/therapists say
MRsDNF
MRsDNF's picture
Thats no good at all RBD. It looks like you have a bit of carnage to your thumb as well with the big groove in it. Get well soon. Sad
Solar
Very nice project you have going. I hope you heal up quick.
MG
Last seen: 6 months 6 days ago
Ouch! Best wishes for fast healing!
Rufusbduck
Thumbs fine, that’s just the elastic bandage wadding me up. After the first 24 hours the wrist is pretty stiff and ~50% oversized. Feels like a stubbed toe right in the joint. Another day and it will be more colorful, already showing a bit yellow.
Scott
MRsDNF
MRsDNF's picture
Any sympathy from the better half?
