I should have been more specific. Only the large set of 7135’s should be moved down to the bottom board. One or two on the top board should be able to dissipate their heat via the surface area of the upper driver and through the copper wires connecting to the bottom board. The bottom board doesn’t need a Batt. You can just run Batt straight from the spring to the top board/LED. Both the top and bottom board need Batt~~. So that wire would remain. All you need in addition to that is PWM feed and LED~~. So 3 wires total.
Oh.
Normally I try to make my drivers as useful as they can be for people other than myself, but I thought I would be the only one who liked the idea of the pins. So I did it “my way”. This involved reducing the driver size by 0.5mm (15mm now), removing 2 of the 7135’s (I usually only use 3 anyways), and removing the FET pulldown resistor (I’ve yet to need one, and they’re easy to stack on the FET pins themselves) . You can use just about any 0.025” header pins you want, but I ordered these just now.
Why did you have to remove the 7135s? You could split the placement of the three pins. 1 or2 where they are now. 1 at the via for r2. And one at the via for the bleeder resistor. You would need to move the bleeder via and the fet output just a bit to make that happen. The ground ring on the bottom of the driver board should be enough to carry the signal. What do you think?
Guessing those pins will be gold coated steel. If so, they will be rigid, but will conduct heat and electricity less efficiently. That much rigidity doesn’t seem needed. Some flex will help protect the solder joint from breaking. 22 gauge solid copper wire will be a tad over .025”. Here is a chart showing the diameter of various gauge wires:
I was under the impression the pins were brass. They come in either tin plated or gold plated. Even so, I’m assuming they will have more resistance than copper wire (which is partly why I thought the whole idea was going to be unpopular).
I had to remove one of the 7135s, and I chose to remove another one just because I personally never use more than 4 and I didn’t think anyone else would be using this board. I wasn’t even planning on posting it here to be honest.
I don’t think I can move the vias for the pins. To put them where the other smaller vias are would mean I have to make the driver bigger again, which will push the pins more outside, and I think that would cause clearance issues where the contact board sits on the shelf of the pill.
I think this was the hardest puzzle I’ve ever done. Things are very tight to say the least. Still an even 15mm for the top board, but we are back up to 5 total 7135’s. Most of them are on the bottom board for better heatsinking, as is the FET. The FET pulldown resistor (R4) is back and C2 from the Q8 has been added (it is optional) to go with the input resistor (R3). The bleeder resistor is gone but I can count at least 3 places you can stack one if you need to. This version uses 5 header pins, but none of them will carry more than 380mA. Your emitter wires will be mounted to the spring and contact board and will bypass the stacked board entirely. This one should be easier to get a programming clip on, and it consists of two single-sided boards for easier reflow. Both boards are required for function but I left them as separate files so that you can order the bottom board thick and the top board thin.
Wow! Very nice! I think this board will be perfect for the d80. I have 25 d80s to modify. The driver has to be one sided on these lights because of the retaining only thing that would be nice is an 18.5mm contact plate. That’s just for my purpose though.
I wasn’t happy with how messy those traces were, so I cleaned some things up. I think I’m about to order; the OP will be updated too. Feel free to follow this maze to check the circuit if you’d like to. It’s not my prettiest, but should be functional.
Really? That’s surprising. Just having the MCU tilted to one side at an odd angle drives me nuts. I’m the type of person that likes things to be uniform and symmetrical if possible.
I also just realized this one would be even easier to drive a secondary LED (like red) than the original was. Just don’t connect a header to the top right via and use that for a second LED- wire instead.
Yep, it also annoyed me at first then I started looking at some other compact PCB designs and realized that most appear to just use the auto-placement / auto-router and thats it.
As I am sure you know, the auto-placement and auto-router are just beautiful things to behold (for everyone else I am being sarcastic, they are downright ugly to look at).
Fact is those setups work just fine even with 5 times more vias then they need and traces 3x longer then can be done.
So I decided after that to just get it on the board and make it as pretty as was possible in a reasonable time frame. Once it is in the light I only care about how it works anyways.
“auto-placement and auto-router”? … never heard of her.
I lay every trace using either the line, circle, arc, or square tools.
Though I must admit, this was a lot easier when we had 7 parts on our drivers, they all easily fit on one side of 17mm, and it didn’t matter where they were in relation to each other. DEL’s scope has made my life so much harder
I just have to laugh though. Between the few revisions I did that was the most difficult board I’ve ever done, and it was all just so I can use a bigger spring….
LOL, I guess eagle doesn’t have any automation features for placement or trace routing? They are no good for small boards like this in diptrace but I messed around with them at first, downright ugly layouts but it worked.
So eagle just sees the layout as a picture not much different then MSpaint? I guess that is why I could not get the hang of it.
Diptrace sees each pad, trace, copper pour and via as there own part and it knows exactly what should connect to everything else. so while I still have to layout the placement and traces manually it takes care of all the small things because it knows what goes where.
I will agree that the extra parts make things a lot more interesting, thats why I went with 0603 resisters, they are not much harder to work with, even hand soldering and are just as good as the 0805 versions for a performance standpoint for our uses.
Eagle does have fancy stuff, I just don’t use them. The way I do it, yes it’s basically just a multi-layered bitmap.
You can link a schematic to a board and have it check your circuit for you, and give suggestions and treat traces as signals and such, but I didn’t know what I was doing and it would just give me errors all day long. So early on I figured out that if I just skip the schematic, it will let me draw traces wherever I want without complaining about all of the “rules” I was breaking. Since that’s how I’ve been doing it since day 2, I have never learned the more advanced features of Eagle. That’s also why my files usually aren’t much help to people that want to learn the “right” way.
I don’t mind working with 0603, but my small stockpile of parts are all 0805 and I didn’t want to buy all new stuff.
Yeah, once you learn a way of doing something it is hard to relearn. Thats why I generally take a rather long time to pick out which program I will use for a new format, (like solidworks for CAD, diptrace fo PCB, photoshop for jpeg, DXO for RAW ect.)
There is nothing wrong with doing it like you do, just harder to keep track of things during the design process and if you make changes to the parts later it is harder to update them. So it is a tradeoff.
