Test/Review of AW IMR14500 650mAh (Red) 2016
Official specifications:
  • Nominal Voltage: 3.7v
  • Capacity: 650mAh
  • Low Discharge Voltage: 2.50v
  • Maximum Discharge Rate: 5 amps
  • Maximum charge Rate: 1.5 amps
  • Operating Discharge Temp: –10 to 60°C
A new generation high current cell from AW
The two cells matches fairly well on capacity, but there is a voltage difference.
As usual with small cells the discharge is too fast to get high temperatures.
Conclusion
I wonder about the difference in voltage between the two batteries, are they different age?
The capacity matches fine enough.
Notes and links
The batteries was supplied by aw-akku.de for review.
Comparison to other LiIon batteries
Thanks for the review!
Thank you for this review. These cells have not the oomph to really fire up a Kronos X5.
But are better than most of the expensive rewraps with the big (flashlight) names on them.
