Yeah, once you learn a way of doing something it is hard to relearn. Thats why I generally take a rather long time to pick out which program I will use for a new format, (like solidworks for CAD, diptrace fo PCB, photoshop for jpeg, DXO for RAW ect.)
There is nothing wrong with doing it like you do, just harder to keep track of things during the design process and if you make changes to the parts later it is harder to update them. So it is a tradeoff.
Texas_Ace, Eagle has an autorouter that tries its best to optimize the signal path. I have seen it do some weird looking stuff. But, it seems to be able to get traces to places I couldn’t figure out how to reach. I’ve never seen an autoplacement button, but I’m a very new user, so I could have missed it. Sometimes, as PD said, the fancier features actually make things harder when you already know how and where you want to place things.
PD, if you start to get bored with easy stuff, and want something more challenging, try looking at my contest light driver. It’s my first attempt, so maybe I’m still in the learning curve and that makes everything seem hard. But, I’d like to make that monstrosity with no traces on the bottom, just one huge ground plane. I’ve utterly failed so far. I did get a board designed, but it’s super ugly and has traces popping up and down through vias all over. I don’t even know how to do the correct placement of parts. I read about DEL’s scope and know there were changes made to the Q8 driver because of it. But, I just don’t know what I’m doing. Your drivers always look so nicely laid out. It is funny that you did all this work, and had such a difficult time, all because you just wanted a bigger spring.
I’ve been pulling my hair out trying to find 0.025” header pins. The ones you purchased are $20.00 shipping to Canada, a bit much for me.
I’m a huge electronics noob, I believe that the issue that I’m having may be the search term “0.025”. I’ve found header pins listed as “0.64mm” or “25mil”, I get way more search results using those terms.
Ah, Thanks! I knew that 0.025” = 0.635mm, but did not realize that “mil” referred to one-thousandth of an inch.
Do you pull the pins out of the plastic bit before using them, or leave the plastic bit on there? I’m using the pins for some lighted tailcap v5.3 boards that I ordered today. I just posted my question in this thread because it was the only place that I found a comment about sourcing the pins.
Just got my boards today. Hopefully I can build one tonight or tomorrow. I’ve been waiting for these to finish a d80 build for my brother. I have the lighted Tailcap assembled and everything is ready to go but the driver. Hopefully the circuit works well with the bleeder.
I think he’ll like it. He told me to have it done before hunting season. I’ve been noticing him steal my parents four wheeler so I think that is my que. time to get it done
Yeah I haven’t thought about where to put a bleeder on this layout… I’ll have to think about it when I get my 20mm contact boards. I suppose you could still stack it on C1… I don’t see why not
I think I’m going to put it on the spring side of the board. I’ve been doing that with the new fet +1 boards from Richard and it has worked well. Then I can swap it out without removing the driver. On those boards there is a trace and via carrying the plus signal that I scrape clean and put the resistor over that via connected to the ground ring. I see I might be able to do the same on these boards. One of the extensions of the plus/spring pad goes really close to a via with the ground signal. I scrape the solder mask off of that via and put the resistor there.
btw hopefully the three-pointed spring pad works for everyone. It’s perfect for me because I reflow my springs with solder paste to keep it clean. I tested it on one I already received and it worked perfectly that way; a good strong bond.
You’ll want solder that flows easily if you are using an iron though.
Well. I built a triple stack driver today. Aligning the pins proved to be more difficult than expected. And it didn’t help that I accidentally ordered 2oz contact plates as well. Two of the via traces broke loose when trying to align them. The vias were lined with solder mask and were difficult to solder too and I had quite a bit of troubles actually.
But it is built now and it’s perfect for what I needed. I’m going to put it in a blf d80 where there is room in the driver cavity, and a retaining ring that would normally not work with triple channel layout. The spring pads worked well for me. They required less heat to get the solder to flow and it seems to hold just fine.
Now that I put one together, I think I learned some tricks. Hopefully the next goes better
I have yet to flash the firmware. Hopefully I’ll get to that tomorrow.
