I understand your comment and reasoning, but it assumes the buyer or consumer is not smart enough to comprehend the dynamics of the batteries being used.
If the amount of profit made by selling ‘protected batteries’ to an unsophisticated public is a guide, then who knows what other great ‘new’ batteries will be released.
The ‘lowest common denominator’ is not a principal I would like to see in innovative flashlight or battery design.
The numbering is intentionally ‘nominal’ to allow for slight variations from different manufacturers, but IMHO a 5mm or more difference isn’t nominal and should be noted through use of a different number. Had they started with different more true descriptions (which they should have done) it would work, but now it would just confuse the average person even more. At least we’re smart enough to check for the length before buying
This could be useful for a trip when you don’t want to carry additional chargers, just the light and one battery. However it uses a panasonic NCR-B which is not good for high powered flashlights.
I like the concept of having the micro USB built into the battery. It adds portable micro USB rechargeability to flashlights that don’t have a built in micro USB port.
My main concern is length - 70.7 mm is a bit long for some flashlights. It’ll either really crunch down on the springs, or won’t fit at all.
I don’t really “need” micro USB rechargeability for my use cases, but I might pick up 1 or 2 of these just to try out.
I can see the usefulness of these cells, but they’re not for me. With 3 ‘brands’ offering these now I’d guess the chargers are outsourced, probably all from one factory ATM. If so, there would likely be a large minimum order but maybe a MegaStore will chance it and offer them.
Most enthusiasts are already going to own a bunch of batteries and chargers they like. I could see this battery being good for the everyday person that just has one 18650 light that lives in a glovebox or on a bedside table. If your only going to have one battery then just buying one of these is cheaper than buying a protected cell and a charger. You also don’t have to worry about losing the charger in the 3-6 months or maybe more between charges.
Is 3400 mah the only capacity available for these built-in USB 18650s? Will there be a cheaper 2600 mah version? Is there even a market for a 2600 mah with USB recharging?
Personally, since I only want one or two of these for fun, I’d rather get a cheaper 2600 mah.
Hmm yeah I removed the grey wrapper and black disc covering the top. Rge charging and protection part are very solid attached to the cell and I do not dare to proceed, it seems pressed fit and knowing the strip connecting the protection with the - is probably used makes me not going any further.
