When will we see first flashlight for the new 20700 cell type?
42 posts / 0 new
Aggressor
Last seen: 3 years 4 months ago
As you may or may not know, new Tesla/Panasonic Gigafactory-1 will start producing cells in a month or two, and when it comes to full capacity this single factory will produce as much cell capacity as the current worldwide production combined. As you also may or may not know, this new factory will produce cells in a new format: slightly larger 20700 instead of traditional 18650.
So, when are we going to see flashlights for the new 20700 cell type?
Any existing 18650 flashlights large enough to accept 20700 cell?
Edited by: Aggressor on 08/24/2016 - 09:12
The Miller
The Miller's picture
Last seen: 2 years 1 month ago
A lot of 26650 cells are longer so figure a lot of 26650 lights accepts these.
Though how likely is it they will sell them to the general public?
Wonder why this size though…
Aggressor
I have no doubt they will quickly find their way to the general public. Just like, for example, readily available Sony VTC6 cells did, despite Sony’s vocal objections.
Single cell 26650 lights are too fat for my taste, but 20700 cell would not increase size by much compared to 18650. Since it would also add 30-35% capacity, personally I am looking forward to 20700 flashlights.
DavidEF
DavidEF's picture
Last seen: 2 weeks 17 hours ago
Now, we need someone to also make a 20350 cell, so those 20700 flashlights that are yet to be made can also be modded for ~6V operation. Cool
- The YKK Philosophy
Gurthang
I’ll be curious as to how soon we see 20700 cells in hobbiests’ hands. Based on the graphic a top-of-the-line 20700 cell could have up to 4200 mAh capacity. Are there any current 1 cell lights w/ enough ‘meat’ in the battery tube to be bored out to 20 mm?
DavidEF
DavidEF's picture
If a 26650 light is too fat for your taste, then your selection is going to be very limited indeed. However, any light that is made to take both 18650 and 3x AAA in a holder should be big enough. Otherwise, if you can find one that’s made to take 18650, and has a thick tube, you could possibly bore it out for ~20mm cells yourself.
Henk4U2
Henk4U2's picture
Last seen: 10 hours 15 min ago
The volume of a 26650 cell is roughly TWICE the volume of an 18650 cell. And so could be the energy-content (roughly). But the energy-content of the best 26650 cell’s is not even 50% larger than that of an 18650 cell. The increase in capacity will only occur if everybody agrees 20700 is the new industry standard and everybody puts his shoulders to the wheel.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Aggressor
Did you miss the word Panasonic? Or the part which explains that this single factory will produce as much cell capacity as the current worldwide production combined?
DavidEF
DavidEF's picture
No, we don’t need everybody, just somebody. Panasonic already has high energy chemistry, so they could pull it off easily without anybody else’s help. The reason none of the other size cells have as great energy density as 18650 isn’t because there aren’t enough people trying, it’s because there aren’t the right people doing it. The big guys with all the best technology only make 18650 and 18500 (and soon 20700) cells. That’s how it works. Everybody else has inferior capacity, even in 18650 cells.
sidecross
sidecross's picture
Last seen: 4 years 7 months ago
From my reading this new size battery is being designed for power packs for the automotive industry and especially Tesla who will have the world’s largest battery manufacturing facility in Sparks, Nevada.
The flashlight industry is a very small user of either 18650 or 20700 batteries. The new battery for our needs is far off.
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
Texas_Ace
Texas_Ace's picture
Last seen: 16 hours 23 min ago
I am very curious to see where this new factory goes with battery technology.
The next 1-2 years should be very interesting that is for sure.
Henk4U2
Henk4U2's picture
Let´s wait and see. “High energy chemistry” and perceived economies of scale in one move is no small step for man.
sidecross
sidecross's picture
+1
The new Tesla facility is surrounded in secrecy; the next five years should bring new advancements and hopefully one’s that would even surprise many of us here on this forum.
pilotdog68
pilotdog68's picture
Last seen: 9 months 1 day ago
It will be cool to see what happens, but I sure hope 20700 doesn’t replace 18650 for the major manufacturers. I want better and better battery technology for the lights I already have. I don’t want 90% of the lights I own to become outdated because you are stuck with old battery tech.
I don’ think that would happen, but you never know.
Aggressor
18650 batteries we are currently using were not designed specifically for flashlight use either.
DavidEF
DavidEF's picture
+1 That was my first thought when I read that post.
Barkuti
Barkuti's picture
Last seen: 1 day 7 hours ago
If capacity is all they were after, which I doubt since they'll also benefit from simplified manufacturing protocols, I'd have preferred to see them chosing the 26650 format. The reason I see here behind the 20700 format is that it's area/volume quotient (cooling, power delivery) is not so far off the 18650's one.
Cheers Party
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
Couchmaster
Last seen: 2 days 13 hours ago
Tesla is spending craploads on R & D to increase the power of these cells. Given the rush to produce, they have most likely not incorporated even a part of the changes they are looking at in the lab into the finished product yet. Interesting times indeed, I’m looking forward to it. Musk quoted about the speed improvements based on the new battery packs from yesterdays BBC article: the cars “… hailed the upgraded battery as a profound milestone….will do 0-60mph in 2.5 seconds”
http://www.bbc.com/news/technology-37171455
Given the rush to production I think it’s possible we’ll see availability within a year. Hard to say as none of us know the production details of the battery’s. That means that 4-5 years might not be unreasonable either, but I doubt it will be that long. They have a bunch of pre-ordered cars they need to build first ASAP though.
The Last Katun
The Last Katun's picture
Last seen: 6 days 15 hours ago
A few years ago, I had read that Tesla would have chosen the 22650, to replace 18650. have changed their idea.
I like more the 22650 to replace the 18650; It is not fat like an 26650 and can reach (and archieve) good capacities …I think
Rufusbduck
Rufusbduck's picture
Last seen: 9 months 3 days ago
It might not make sense in terms of capacity/cell but if the added capacity brings down the number needed then it makes sense, especially for vehicles using thousands of them. Then there’s also the power wall technology that will demand a huge number of cells.
Scott
Bort
Bort's picture
Last seen: 2 hours 40 min ago
Quote:
Don Elon: “It really comes from the first principles of physics and economics. That’s the way we try to analyze everything. To say like if no cell existed in the world, what size should it be? What is the size that would achieve the product characteristics we’re looking for, but would be fundamentally optimal? 18650 is not optimal.”
http://cleantechnica.com/2016/07/30/3-critical-keys-elon-jb-brought-batt...
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
Tom E
Tom E's picture
Last seen: 1 day 10 hours ago
So, do we stock up on 18650's or sell off our 18650 flashlights as quick as we can, while they are still worth something? smile
Ohhh - maybe the new BLF Q8 can be tweaked to support 4 20700's? smilecool
The Miller
Yes Tom let’s go for a thick walled tube Wink
But with the demand from cars , build by car manufacturer I think it will be a while before 20700 get available for us
Cool they spec 700 maybe the longer 18650 and 26659 cells will be labeled 18700 and 26700 soon!
sidecross
sidecross's picture
The 18650 battery will be around for a long time.
Bort
Bort's picture
Tom E wrote:
So, do we stock up on 18650’s or sell off our 18650 flashlights as quick as we can, while they are still worth something? smile
Ohhh – maybe the new BLF Q8 can be tweaked to support 4 20700’s? smilecool
Only Tesla is committing to a new size, so unless everyone else is going out of business we are safe.
RobertB
RobertB's picture
Last seen: 2 days 4 hours ago
I could be wrong, but I believe the “breakthrough” Musk was talking about is the new cooling system that will be utilized, more so than the individual battery itself. I think it’s the problem Honda is having right now with their new hybrids. The cooling system is poorly designed, the cells heat up and lose capacity, thus less than expected fuel mileage. Note in the BBC article Musk says, “in cool weather, a driver could travel from San Francisco to Los Angeles – a nearly 400 mile drive – without recharging”
Tom E
Tom E's picture
Tesla and Panasonic are committing, that is... We just don't know how committed Panasonic is, and if others will follow.
The Miller
Maybe they are hollow like the Apple cells recently discussed (with the hollow space for cooling.)
sidecross
sidecross's picture
WojtekimbieR
Last seen: 2 months 3 days ago
Can't wait to see how it develops. Some of the 18650's are already close to 20700 dimensions Wink I believe most torch walls could be bored out by a milimeter without a problem to fit the new cell if necessary and worth the effort in terms of gained capacity.
Just for a moment... Okay I may stay a little longer
EasyB
Last seen: 5 hours 39 min ago
sidecross wrote:
https://www.youtube.com/watch?v=tBpLBMoBUTg&index=3&list=PL1t6JkcqG9Nkaq...
https://www.youtube.com/watch?v=NmG1p6EuF3s&list=PL1t6JkcqG9NkaqDf0Txcfy...
First link is about “graphene batteries” and is surprisingly un informative. I have searched and not found any info about what this battery actually is. They do have very impressive claims. I would not believe them, however. Battery “breakthroughs” generally do not happen. There is incremental development and improvement. If this particular graphene battery technology was really promising, lots of labs and institutions would be developing it.
Second link is old, and about the development of a type of Li ion battery, LiFePO4, that A123 pioneered.
The cells that will be made at the gigafactory will very likely be traditional Li ion chemistry.
