D.I.Y. Illuminated tailcap
1813 posts / 0 new
hank
hank's picture
Quote:
after all your work to get one of these tailcap boards
Chuckle. All I expected was an ordinary switch that would fit the host.
I’m guessing they’re scraping the bottom of various parts barrels when filling those host orders.
Oh well. Given my shaky hands, I suspect I’ll ruin one or two, then be waiting and hoping RMM or someone else, finds reason to build driver-and-switch combinations for sale to modders at my stick-it-together level ….
Thanks for the info. This stuff is always fun to watch, more so the more it gets past my reach.
djozz
djozz's picture
Last seen: 3 days 7 hours ago
pilotdog68 wrote:
Hey djozz, remind me where you get all these interesting colors?
It was asked to me by PM too by someone . It was a 100x gree-to-blue mix very leisure tossed loose in a small grip-bag by ebay-seller ledbaron. But the listing is gone now, and it appears that cyan 0603 or 0805 leds can’t be found on ebay anymore (or anywhere else?). Green, blue and ice-blue are easily found though, i.e. at lebaron (german seller).
pilotdog68
pilotdog68's picture
So far the most I have ever used is 3 LED’s. For my next one I think I will use all 6 pads. I just can’t decide if I want to mix red and blue, or blue and green, or red and yellow.
MRsDNF
MRsDNF's picture
I’d suggest to build three in the above colors. Smile
Rufusbduck
Rufusbduck's picture
Fwiw Kaidomain has several different sized translucent tail caps including 8, 10, 13.6, 14, and 16mm.
Scott
Texas_Ace
Texas_Ace's picture
Last seen: 11 hours 51 min ago
I am in a similar LED delima myself.
Firstly, has anyone ordered LED’s from digikey? Any recommendations?
I am thinking I will grab these in a few colors to start out with, they have the highest MCD rating for the price/size so I figure they should net more light at low currents as well.
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=2049245...
Next is color, I am thinking I would focus on green or blue/green combo as they should be the brightest for the least amount of power used since our eveys are more sensitive to those colors. Or is red just too good looking to pass up?
pilotdog68
On the newer boards the power is so infinitesimal, just go with what color you want. Having said that, you could look at it from the angle that reds and oranges have a lower Vf, so they need less power to be as bright as the greens Wink
Texas_Ace
Texas_Ace's picture
I suppose so, I just tend to overthinks things to make sure I get the best possible setup, even on the little things.
pilotdog68
Test it! Perceived brightness vs power draw at different input voltages
Texas_Ace
Texas_Ace's picture
Oh I plan to, just like to know I have all the parts I would need ahead of time. I royally hate having to wait for parts in order to finish a project.
Rufusbduck
Then just get several values to start with.
Scott
Texas_Ace
Texas_Ace's picture
Yeah, I am going to order some of each color.
No big deal, was just curious on peoples opinions for color and experience with LED models.
pilotdog68
Every time this thread gets some attention, I start thinking about something I’d like to change. This time it’s to incorporate the header pins I got to use with the TripleStack.
So here is what I dub Rev5.3, Top and Bottom. The two boards are aligned so you can use header pins to connect them through the vias.
Top has Six LEDs, two channels, and two resistors for balancing colors. It also has a jumper pads to merge the two channels to bypass the resistors.
Bottom should be very familiar: two pots and the mini slide-switch to jump between them.
Hunter
Last seen: 1 year 6 months ago
That feeling when you buy something and the very next day new updated version is released:
pilotdog68
Lol sorry. If you actually ordered yesterday you can cancel as long as they haven’t been sent to fab yet.
There weren’t really any features added other than the pins anyways, so I wouldn’t feel too bad
Hunter
They were assigned to panel in about 20 minutes from my payment and sent to fab. in less than a hour.
No speed limits for OSH park Big Smile
LanWolf
LanWolf's picture
What switch can i use best for the 20mm rev4 ? I want to use them in a solarforce l2p tail, it has big square switch original.
/ Just a Byte /
pilotdog68
Most of these are designed for the Omten 1288. Others may fit but you’ll just have to try it. The BIG SWITCH version might be best. It will be added to the OP soon.
I am currently editing the OP over the course of the day, so don’t be alarmed if parts are missing.
juaquin
Last seen: 2 years 11 months ago
Jumpers on the top ring are a great addition. For single-color tailcaps I’ve been relying on the pot’s resistance and just jumping all of the resistor pads together with a piece of copper braid, but had to be careful with the placement so it still stacked flush. A thin solder connect over such a small jumper will be much thinner. Thanks!
pilotdog68
Ok I think I’m done with the OP for now. I tried to organize and simplify……. I think it ended up longer than before. Facepalm
Oh well, at least there shouldn’t be any more dead product links.
Texas_Ace
Texas_Ace's picture
Yes, it is much better laid out now and much more understandable. Good job!
LightRider
LightRider's picture
Last seen: 4 years 5 months ago
The op looks great!
Did I read somewhere that there is a translucent boot for the s2+ metal switch boot?
pilotdog68
There were some made, but they aren’t for sale that I know of. I had some I could send people, but I haven’t seen them since we moved.
Alternatively you can use the finger cut from a clear latex glove. It works pretty well.
Fulgeo
Last seen: 1 year 8 months ago
Read thru the post carefully and have ordered some Rev4 & pyro1son 16mm boards. I have also ordered my LEDs, pots, resisters and translucent tail caps. I will need to hunt down or create a transparent/translucent washers. Just waiting on the slow boat at this point. I have constructed 18 Convoy C8s so far. 14 of them I gave away as gifts. The Convoy C8 hosts I used were the version 3s with the integrated aluminum shelf. The tail switch uses a Omten 1288 type switch. The switch board is 16mm x 1mm. The ring/washer is 18mm x 1.4mm. I will share my results when I have some. I would also like to appeal to pilotdog68 on the creation of a 18mm Rev 5.2.
pilotdog68
Wouldn’t be too hard. When I was editing the OP I noticed a few holes in sizes. Give me a couple days.
Fulgeo
Thanks in Advance!
zeremefico
zeremefico's picture
Last seen: 12 hours 46 min ago
Will the following be enough:
Any suggestions for more pcbs (any kind)?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
pilotdog68
Any other PCBs? Hmm do you want to build drivers? There are a million of them to choose from.
djozz
djozz's picture
I still have a hundred or so translucent silicon thingies for the S2+ which I can sent out for shipping costs. Even to the US it is just $1.70 from here (long live postnl!).
(that reminds me there was a request for them that I never sent, I’ll look that up Facepalm )
ImA4Wheelr
Last seen: 1 year 2 weeks ago
Thank you for updating the OP. This thread was so big that I didn’t think I would ever get around to reading it. Bought some boards and LED’s. Smile
