Testing a custom made 16mm Nichia 119 copper core board (non-DTP), edit:sold out
74 posts / 0 new
djozz
djozz's picture
Last seen: 7 hours 37 min ago
I had a batch of 100 Nichia 119 boards made by Kerui  in Shenzhen. The reasons were several:
-every now and then I wished I had a board for leds that only have two electrical pads with no thermal pad in between. I could not find them for sale in Europe easily. Interesting leds without thermal pad that will work on this board are the Nichia 119, Luxeon Z, Nichia 276A and other UV leds, the new Nichia 229A and 144A series, and all mid-power leds that are sometimes interesting to put into small flashlights (i.e. Yuji leds)
-I wanted to check out the Kerui board manufacturer (result: they were a pleasure to work with, lots of attention for the customer despite the small order)
-I wanted to see how such a board performs: trying a design with maximum heat dissipation despite not having a DTP to the core, and test if they are any better than existing similar boards. So the electrical pads widen in a large pour, and had the core made of copper (not knowing if that makes that much of a difference, at least it looks cool, and you can solder it). To make them as versatile as possible for use in flashlights, the diameter is 16mm, and the thickness 1mm.
So now I'm stuck with 128 of these boards that costed me $2 each (all-in).
So here's a test of the board.
The idea of the test is to take one led (the only led available to me was the grossly outdated 92CRI 3000K Nichia 119A) and reflow it repeatedly on my board and a generic board, and do full current-to-output/voltage tests to see how they perform.
The only board I had to compare my board with was the Nichia119 board that came with the Convoy S2+ UV Nichia 276A. It looks very similar, with also the electrical pads widening into a pour, but under the led is a wider gap and the core is aluminium.
Note that it is labeled 'Cree' while I'm not aware that there are Cree's with this footprint cool
I did 5 test-runs with the Nichia119 led:
*I first reflowed it on the djozzN119 board and did 2 test-runs up to 2A, to see if there were any 'burn-in' effects (there were not)
*then I reflowed it on the genericN119 board and did a test run
*then back on the djozzN119 board to see if the performance had not changed, test run (performance was still the same)
*and last again on the genericN119 board and did a test run, to see if the (differing) results were consistent (they were).
Here are the results in a graph. I made the djozzN119 results in shades of purple, the genericN119 results in shades of orange/brown
I had not expected a difference that was so obvious: my board does clearly better, at 2A the led was still close to maximum output, while on the other board the output was already halved. Note also that on the generic board the led runs at a clearly higher edit: lower voltage, up to 0.2V at 1A, this must be caused by the higher led-temperature.
So what is the reason for the new board to perform so much better? I can think of 3 reasons, what the contribution of each effect individually is I do not know:
*the wider gap (air!) under the led on the generic board lowers the heat dissipation area under the led, right where it counts most
*the dielectric layer on the Kerui made board is superior: less heat resistance. I have not dived into the heat conductivity numbers of various manufacturers (I should Sad  ), but I'm sure it varies.
*the copper core stays cooler than an aluminium one and thus also the heat passes the dielectric layer faster.
A remaining question is: how much worse is this type of board compared to a DTP-board? I can't test that for this board because the DTP boards are for a different type of leds, but my guess is that over 3 or so amps the DTP board performs better. In my 6x XM-board test a non-DTP copper board even up to 5A was almost just as good as the DTP ones.
Conclusion
I succeeded in what I wanted: I now have a bunch of boards for non-thermal pad leds, and  they perform better than at least the one generic board that I had around.
_____________________________________________________________
 EDIT AUGUST 24, 2017: Sold out! I have just a few leftover that I would like to keep for own use.
Now for getting rid of the surplus boards. I really wanted to order these boards, for occasional use, and because I was curious about the performance. But even though the minimum amount that could be ordered of 100 pieces is extremely low for a direct manufacturer order, I do not need all 128. And I think that the $250 that I lost on it a bit much for the (though fun!) ordering experience and the bit of knowledge that I have gained about the thermal performance of led boards.
So 110 of these boards are for sale now, leaving me with ideally 18 pieces that should be way sufficient for whatever I want with them. Since it will be cost price, I do not bother posting this in the commercial sellers corner. The boards will be $2 a piece plus shipping. Shipping for up to 8 boards is $1.40 worldwide, 8-20 is $2.80, 20 to 40 is $4.20. A bubble mailer plus ziplock-bag (I will tape them in) is 0.30.
Example: 7 boards will be 14+1.40+0.30=$15.70
Please reply in this thread how many you would like, and PM me the address the boards must be sent to and I will PM my Paypal address. First come first go. I will probably collect demands for two weeks before I ship a bunch out, but it all depends on how many, if any, are sold.
I have no idea if these boards are interesting for anyone but me but I hope for the best. The price could of course be better if many more would have been ordered, but for this niche board I do not think that would have been wise.
Thanks for reading!
Edited by: djozz on 08/24/2017 - 15:42
MRsDNF
MRsDNF's picture
Last seen: 3 weeks 1 day ago
Nice work djozz and all the best for the sale. Thumbs Up
Rufusbduck
Rufusbduck's picture
Last seen: 3 months 6 days ago
Maybe 2oz copper traces instead of 1oz on the generics. The Cree XQ(X) is 1.6 × 1.6 mm with no thermal pad. It might work. Also has an HI version.
Scott
Ouchyfoot
Ouchyfoot's picture
Will these fit any of those non DP osrams.
DavidEF
DavidEF's picture
Last seen: 2 days 8 hours ago
I have some Nichia 119b from texaspyro that could use these boards. But I don’t have any money. Sorry djozz. Hope you get them sold.
- The YKK Philosophy
djozz
djozz's picture
You mean Oslon Black’s ? No, they do have a thermal pad, but it not electrically neutral. A good quality common non-DTP XP-board should be best for them.
djozz
djozz's picture
The XQ-E Hi is indeed a nice led for this board. I myself prefer a dedomed XP-E2 (easier to get), but not everyone can or wants to dedome their leds, and the tint after dedoming is not great. They have XQ-E Hi’s at Mouser.
DavidEF
DavidEF's picture
Are these 16mm boards? I couldn’t find the size listed in the OP.
Gunga
Gunga's picture
Last seen: 4 hours 23 min ago
I have no specific use for them now, but who knows, that could change. I’ll take 4 in Canada. I have a random stockpile of parts. It’s kinda fun for the random mod that requires it. Any other odd stuff to sell?
Smile
djozz
djozz's picture
You are right, I forgot to mention that: they are 16mm diameter and 1mm thick.
djozz
djozz's picture
Smile
PM me your address! I will add some random stuff with the boards. Smile
Texas_Ace
Texas_Ace's picture
Last seen: 11 hours 31 min ago
I will most likely take a few, curious if you will be running any tests on the new 114a / 229a LED’s that these were designed for anytime soon?
Depending on how well those do in the test will determine how many I need. Looking for some good high output high CRI LED’s for some projects.
djozz
djozz's picture
No hurry, haven’t sold any yet. I realise now that I even have not sent Gunga’s boards (sorry Gunga Blushing ) , at least he did not sound like he needs them right now Facepalm
I’m supposed to get the new Nichia’s from clemence, but via maukka who is going to do a tint/CRI test first.
Texas_Ace
Texas_Ace's picture
Sounds good!
Gunga
Gunga's picture
Whoops! Yeah. I forgot about them. Smile
Flintrock
Last seen: 3 years 6 months ago
So these led's have no central thermal contact?  So a standard DTP style board is not possible?  But there's no reason the ground side of the LED can't connect straight to the core in a DTP like fashion right? In fact, maybe you can just scrape off the contact and insulator on that side and just try it.  Depending on how good the electrical conduction of your thermal paste is (likely not very), might need to do the same with the ground wire then.  Anyway, these are clearly a big improvement.
Also there was this thread:http://budgetlightforum.com/node/30532  (that should be stickied if it's not)
Basically it shows similar results to what you have.  Copper non-dtp is almost as good as DTP in either copper or aluminum.  Was it because of the copper or was it just a better board than the aluminum one?  Well now there are two data points.  It's looking like copper probably helps.  For those tests, in normal operating ranges (under 3A for that XM-L2) you almost can't tell a difference (maybe one percent?) between copper non-dtp and dtp and so, probably my idea above won't make that much difference either.
In DTP though it seems to matter almost none if it's copper or aluminum.
DavidEF
DavidEF's picture
Flintrock wrote:
So these led’s have no central thermal contact?  So a standard DTP style board is not possible?  But there’s no reason the ground side of the LED can’t connect straight to the core in a DTP like fashion right? In fact, maybe you can just scrape off the contact and insulator on that side and just try it.  Depending on how good the electrical conduction of your thermal paste is (likely not very), might need to do the same with the ground wire then.  Anyway, these are clearly a big improvement.
Also there was this thread:http://budgetlightforum.com/node/30532  (that should be stickied if it’s not)
Basically it shows similar results to what you have.  Copper non-dtp is almost as good as DTP in either copper or aluminum.  Was it because of the copper or was it just a better board than the aluminum one?  Well now there are two data points.  It’s looking like copper probably helps.  For those tests, in normal operating ranges (under 3A for that XM-L2) you almost can’t tell a difference between copper non-dtp and dtp and so, probably my idea above won’t make that much difference either.
In DTP though it seems to matter almost none if it’s copper or aluminum.
Well, it would be a lot of work to make a light with the negative side of the LED electrically connected to the board, because the host is grounded to the negative side of the battery, but the driver regulates current to the LED on the negative side. So, you’d then have to either electrically insulate the DTP board from the host, or come up with a driver that regulates power on the positive side of the LED instead. Both of those things have been done before. But in my opinion both of them are more trouble than they’re worth.
Flintrock
DavidEF][quote=Flintrock wrote:
 Well, it would be a lot of work to make a light with the negative side of the LED electrically connected to the board, because the host is grounded to the negative side of the battery, but the driver regulates current to the LED on the negative side. So, you'd then have to either electrically insulate the DTP board from the host, or come up with a driver that regulates power on the positive side of the LED instead. Both of those things have been done before. But in my opinion both of them are more trouble than they're worth.
Edited:  I  misunderstood.  at first.  Yeah that's a problem then.
It's not a new idea though (but indeed now I see that this light has no driver):
 http://budgetlightforum.com/node/13679
The original explanation is here:
http://budgetlightforum.com/node/8370
But in the original they isolated both contacts from the pill.  In the first link above it seems only the "hot" (whichever that may be) was connected.
I can see there might be a third option to make the case positive, but it might have issues too, and anyway, it's still a new driver board (and a backward battery).
But it seems copper without DTP can be almost as good as DTP anyway.
djozz
djozz's picture
You have read a lot around BLF Flintrock, way back into the match days Smile
clemence has had boards made for the new Nichia leds that have a direct connection to the core at the cathode side (where the most heat is produced), and in fact I will be getting some leds to test on his boards. It gives me the opportunity to see how much that differs from my non-DTP boards.
As discussed in the OP, what may be a big factor in how well a non-DTP board sheds the heat is the quality of the dielectric layer. In my 6xXM board test I may have struck a non-DTP board with a good layer while other non-DTP boards may have worse heat-shedding properties.
Gunga
Gunga's picture
I.might have a buyer for you from cpf.
s1m888
s1m888's picture
Last seen: 1 day 19 hours ago
Hi djozz, I would like to buy some, please check your message.
ohaya
Last seen: 3 years 3 months ago
Hi,
I’m not clear from your OP where the cutoff is for the $2.8 shipping cost? Is it 19? Or is it 20?
Wherever that cutoff is, can I have that many (either 19 or 20)?
Thanks,
Jim
Jerommel
Jerommel's picture
Itś a matter of surface area.
Two big surfaces with insulation between them is much better than two small surfaces with insulation between them.
thijsco19
Last seen: 13 hours 33 min ago
You say that the generic board results in a higher Vf but when you look at the graph the results show the other way around?
DavidEF
DavidEF's picture
Jerommel wrote:
Itś a matter of surface area. Two big surfaces with insulation between them is much better than two small surfaces with insulation between them.
yes, you’re right, and in fact, as djozz points out a few posts up:
ECHO
Djozz, I’ll take 5 boards. Check your PM for address and I’ll await your paypal info. Thanks!
Flintrock
Pretty sure it's just slip of the brain/keyboard. djozz is certainly aware that heat reduces Vf in diodes.
djozz
djozz's picture
Yes, sorry, I meant ‘lower voltage’ I corrected the OP.
Btw, I read the PM’s, will answer later tonight.
ohaya
djozz wrote:
Yes, sorry, I meant ‘lower voltage’ I corrected the OP. Btw, I read the PM’s, will answer later tonight.
Was wondering about that :)…
emarkd
emarkd's picture
Last seen: 7 months 1 week ago
Hey Djozz I’d like 4 of these boards please. Thank you!
snakebite
snakebite's picture
Last seen: 1 day 5 hours ago
these should work with that new hex die nichia?
if so these will be a hot commodity.
