I also can confirm on low Vf V6’s, i have seen few 3D’s pull 5.8-6A from 25R measured at the tail, might be slightly lower at the emitter but those are very good numbers.
Yea, not sure what MEM was think'n of, or his results of the de-domed XP-G3 exactly. He's checked out for a while now - hoping he comes back. Haven't followed the M3X stuff - wasn't interested in yet another 63 mm head 2 cell or 1 cell thrower, and not cheap as well, plus it's Olight - not my favorite manufacturer.
For throwers for now, my interest lies in something small and pocketable, or really big.
Indeed Tom, and here comes our lovely C8 host , good old S4 2b and the fet driver- if you get lucky: 200k, Uniquefire C8 has a very nice reflector you know
Why not X6? With your A85 driver mine gives 115k mcds, quite pocketable too
Speaking of Olight M22 warrior can still be found at a very reasonable price, its design is quite good plus it could top 90k mcds with a V6 emitter and a fet dd driver
The new UF 1508( the 75mm head) is a great big thrower too, i was able to get 480k mcds out of one( again V6 modded)…sadly those days dont have the time to try the XPG2 version out
Your A85 drivers and firmwares are lovely btw, keep the good work going!
Thanks! Yea, I got great #'s from the 1504 (big head one) with the good S4 2B, think it was 540 kcd, at least. It's a true light saber - love it! Also got a 2nd one in green, and spare pill with red - both outstanding.
Dunno where the best deal is on the 75 mm 1508. See a few listing on AliExpress. Maybe this one for $53: http://www.aliexpress.com/item/UniqueFire-1508-T75-xm-l2. Little pricey...
So… i ordered 20 pcs from those S4 binned Moser breeds…and they came out from the old stock…quite a surprice
Yet, the suprice wasnt just one - instead of S4 1A or 1D they are something like S4 2C/ or at least very colse to those S4 2C that i got from Cutter earlier this year, i saw this the moment i powered one for a hot dedoming
The tint after dedoming is clearly warm with a nice greenish addon ! Great for hunting, and no that great for your BLF taste
4 pcs are already dedomed and tested, they all pass 4amps easy
The bad thing is that one cant trust Mouser binning and labeling too
No offense, but I’d personally trust mouser labeling more than cree binning
Ofc m8. Just sharing my experience: for me thise aint le1
Mitko you could start small business selling us leftovers of old S4 emitters?…
You are lucky(or knowledgeable) in getting what you want. I don’t have luck… You got good old S4 from Cutter for example while I got crappy new one.
I gave up on searching them.
If you want i can share some of those Mouser XPG2 m8( have 14 pcs atm, will order more), but you can buy them yourself- when i saw them the reet was full, now it has 980 pcs
its highly unlikely if they send you something different if you order that “wanna be” LE1 bin
I aint saying they are bad- vise versa: C8 mad eon a fly went with 162k cds with no AR glass and no tail spring bypass: and it wasnt that 100% focused you know, i tested it with not fully charger old 25r battery
A Clean 20% gain from the best S4s atm
i will order more of them cause they are the best atm, its just they are not LE1 but more or less E2 or something, even with the dome on you can clearly see the difference
The tint aitn that bad( for ppls taste) actualy, its looking EXACLY as Olight M3x default emitter`s tint
S4 2B are to be kept for special occasions only
I would also like to order a few, but I don’t understand the mouser cataloque yet - how/where can I find them there?
My 2 cents regarding best throwing LED for single cell lights:
XP-L V6 1A dedomed in Convoy L2 (single cell) with fresh Liitokala 5200 and FET+1: 280,000 Cd.
New production XP-G2 S4 2B dedomed in same host with same cell and driver: 290,000 Cd.
Not much of a difference.
But - the XP-L pulls 6 Amperes and the XP-G2 only 3.7 Amperes …
Seems like new production S4 2B is better choice then V6 1A cause it smokes less current and therefore longer battery life for fet drivers. With buck drivers it could be opposite.
Did anyone managed to find or restock old production type of XP-G2 emitters?
on the contrary, I was pretty fond of the XP-G2 S3 3D stash of intl-outdoor, because of the (dedomed) good throw and still good tint, and recently I ordered a few extra and I received them now labeled ‘S4’ on the package (normally we are happy with a bin-upgrade :person_facepalming: ) and on inspection they are new type!
Very unlucky Djozz…
There must be more of them around. Probably in China market and it seems that we have only few China forum members here that could check that out.
I doubt that on the China market they have the highest bins S2-S4, most probably are not with known bin at all (tint or output). Hank was pretty good in getting specific high bins, some even exclusive.
They don’t necessary have to be S4…
S3 is also fine or even S2 is fine… Even R5 is better than new production XP-G2.
I am very lucky to have few good old XP-G2 S3 2B from Taobao thanks to our forum member wkhchin81 but I am running out of them…
He also tried to contact China market dealers and says that plenty of sellers are not familiar with such issue and the few sellers that are aware of problem say that their stock is first in first out…
I’m gonna buy some XP-G3s and compare them to my old XP-G2s, see how they perform at 6A.
Very well probably, the point is: how do they perform when they are dedomed?
I can’t remember if it was you or someone else who tried dedoming it and it didn’t perform anywhere near as good as an XP-G2?
I will do a test with dome on, then a test with shaved dome, and finally if both methods perform worse then I will try dedoming.
I will be comparing to a dedomed XP-G2 and dedomed XL-L2 and XP-L HI.
I think with dome on or shaved dome the XP-G3 should be able to have higher intensity than dedomed XP-G2 simply due to higher lumens at the same current.
