This is one of the most comprehensive reviews I have seen yet. I wish I had ways to measure everything you measure. How do you determine the color temp of the led?
Thank you for the excellent and comprehensive review.
Considering that some 26650-based lights that offer built-in charging like Klarus G20, Acebeam EC50 Gen2, Manker U21 have maximum charging rate of 2A, I wonder why Olight designed the charging current to be 1A only
Here’s also a comparison between runtimes and levels on turbo with and without cooling. The uncooled one matches Olight’s specification of 2h 30min at 800 lm after the initial stepdown.
Just popping in to say… great review!
My appreciation as well for this report, and I agree that 1 amp internal charge is not to my liking.
I have the Manker U21 and it charges at 2 amps even with my Anker 10,050mAh power-bank.
The usefulness of the R50 beam can be seen from these outdoor beamshots.
It offers a bit more throw than the Nitecore while still lighting up the near foreground so you know where you’re stepping on. The Nitecore’s MT-G2 led is more of a smooth floody type while the Olight’s XHP50 has a more pronounced hotspot but a wider spill.
great review with tons of info - THX!
Good visual example between XHP50 and MT-G2!
Very in-depth review. Thanks for the time you have put into the review!
What the others said. Thanks. :+1:
Indeed! Both emitters have low CRI (approximately 70 (Ra)), but the MT-G2 reveals browns, yellows, and even the greens much better than the XHP50.
With this review, maukka moves to the front of the pack. No other reviewer provides such a wealth of measurements.
Thanks!
+1
I am surprised that few manufacturers are taking advantage of the Cree MT-G2 LED. It is my favorite flood LED with good color rendition.
I use the Fenix PD40 for now, but I would like to see what other’s can do with the MT-G2 in a single cell 26650 flashlight.
And yes, maukka does very good reviews.
wow, crazy detailed review…nice work!
would it be possible to check if turbo mode can be memorized? my olight s30r javelot has a turbo memory.
same double click for turbo. but if i turn it off in turbo, it will turn on in turbo with a single click.
Thanks for the lengthy review +pics!
No turbo memory on the R50. It is considered a hidden mode like the strobe on the light.
Runtime graph comparing the Olight R50 Seeker and the Nitecore EC4SW.
When looking at the lumen-hour results, it’s clear that there’s pretty much no difference in efficiency between the XHP50 and the MT-G2.
I measured the Olight 26650 battery at 4940mAh at 2A discharge, while the two Keeppowers used in the Nitecore total 6300mAh. This is very close to the ratio that can be observed in the lumen-hours: 6300mAh/4940mAh=1.275 vs. 2123lm*h/1696lm*h=1.252. I didn’t record the energy in watt-hours for the batteries, which would have been more accurate though.
Got the Wh data for the batteries at 2A discharge with the SkyRC MC3000: Olight 26650 4500mAh 18.01Wh, 2x Keeppower 18650 3500mAh 21.77Wh. So the Keeppowers offer only 20.9% more energy, but produce 25.2% more total light energy over the test period. The difference is so small that I wouldn’t conclude that the MT-G2 or the Nitecore is more efficient. Could be the measurement setup.
Please send also if still available
Olight also sent me the R50 Seeker in raw copper. Other than the body material and hence the massive(!) weight, it’s absolutely identical to the aluminum version. However, if not cooled with a fan there’s a slight difference in time it takes to step down on turbo because of the higher mass and better thermal properties of copper. With cooling the stepdown is delayed for a bit more than minute on turbo. No significant difference in output.
Here’s the Al-Cu pair.
And the runtimes.
