single 18650 + XHP70: nitecore TM03
129 posts / 0 new
BrianK
We’re still friends Dale. No harm done and no umbrage taken.
DB Custom
DB Custom's picture
Last seen: 3 weeks 1 day ago
blueb8llz
Last seen: 8 hours 15 min ago
LarcKen wrote:
The strobe mode uses random frequencies alternating. When it’s on high frequency it looks like it outputs a 1000 lumens. But when it’s blasting on low frequency it clearly puts out a whole lot more than 1000. My thinking is that maybe that’s the way this light’s emitter works. It needs time to reach higher lumens which a higher frequency prevented it.
My light meter tells me that it’s doin roughly 1000 lumens on strobe. And I have several xpg2 and xml2 lights that does around 1200-1700 lumens, and those lights have a brighter strobe than my tm03. And this is not by eye, but by my light meter
blueb8llz
DB Custom wrote:
blueb8llz, I like the style of it and the fact they have managed a new threshold in the boost game. Until this one, the boost circuits were keeping outputs low, for some reason this one piqued my interest, in no small part the style of the dual switch mechanism on the tail cap. Had to see what that was all about. And I like deep reflectors. Drawn to em, not exactly sure why. Solarforce Skyline I kinda started it, the Barracuda in more recent times, and now this one. (My Skyline I now has an MT-G2, pretty sweet, opposite end of the spectrum from where this light started out. Wink )
I might end up using an LD-2 or Zener modifed FET driver with 2 18350 cells in this TM03 just for the fun of it, who knows. Slice and dice perhaps? Depends on how well it works in hand and if I stay impressed with it.
First I’ll try to put the circuitry on a 30Q and see how that works out. Then, if it doesn’t make sufficient gains, I’ll try to adapt the light to run on a standard cell without the circuit panel. From there, might just change everything inside. I tend to wing it and so things just happen as they happen. (It might prove to be a really cool MT-G2 light. Wink )
Sounds like you have a pretty detailed plan on the works of this light. But I think it would be fairly difficult to still have the access to instant strobe with a new driver. I think a dedomed xhp 70 might be another option to add to the mix? Or even a xhp 35 HI…. Since you were able to achieve 3000 lumens.
The light has a deep reflector, but the light does not really seem to throw all to well considering how bright it is due to the op reflector.
LarcKen
Last seen: 4 years 11 months ago
Then in this case i trust my eyes more. It’s pretty easy to see the brightness of the strobe, especially when it’s in low frequency mode and i blasted it side by side with a 800 lumens P20
texas shooter
Last seen: 1 min 8 sec ago
I don’t have the light and I haven’t seen a picture of the battery contact side of the head. Could someone please post one. Mhanlen stated in his video review that tail contact with the two same sided contacts caused sparks. I’m guessing that there is three contact points on the heads underside; one for the tube one for the outer ring on the battery and one for the center post. Since this light will take standard batteries and do all modes but turbo. I’m guessing that the center post is same as all others. The outer ring connecting the the tube is the same as all others. The ring between the post and outer tube connection is negative and probable wired to the turbo circuit directly. Not knowing what the battery circuits do. My guess is that by connecting the outer ring to the center ring will allow all modes in standard batteries. Anyone want to try or post pictures of the contact board?
DB Custom
DB Custom's picture
I am surmising the same and will be testing that when I get the light. Wink
blueb8llz
i also have the p20, and the p20’s strobe is brighter than the tmo3’s strobe.
although my p20 is slightly modified, doing about 1300 lumens, but even if it looks to be the same brightness as the tm03, thats only 1300 lumens when turbo is 3000 lumens?
LarcKen
well i also compared it with an imalent DDT40 that’s putting out constant 3000+ strobe.
Again, the TM03 puts out lower lumens on high frequency. But occasionally when it hits low frequency, it’s comparable with the DDT40
DB Custom
DB Custom's picture
What’s the purpose of strobe, in the first place? The definition might also define the answer to this query…
I would venture a wild guess that strobe is typically used as an attention getter. Car is down, strobe is being used to alert oncoming traffic of a situation where caution must be used to proceed. In this case, time is critical, having a cell die on you could put you at great risk, so having a lower powered strobe that does the job and allows run time only makes sense. Yes?
Speed4goal
Strobe works well in running the racoons off from my porch stealing the cat foot and from my neighbors rabbits. But ya I think its mostly as a signal/attention getter. A 1000+ lumen strobe will blind any person and give time to run away. Is there really a need for 3000 lumen strobe?
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
BrianK
That’s what I’ve always seen the strobe use to be. If I somehow get lost or hurt in the forest I just might be able to strobe a search aircraft.
The TV advert’s where it’s used as a weapon is pure BS unless the perp is subject to grand mal seizures.
DB Custom
DB Custom's picture
Exactly Brian, even the red/blue/white police or military strobe is just not gonna stop someone, especially someone running away. (my luck they’d be shooting at it!) Any bright light in the eyes of a dark-adjusted perp is going to gain you some time to make plans, but it won’t be long and plans better be executed quick cause now they’re mad at ya as well!
A good Chow will have fun with the Racoons…
sidecross
sidecross's picture
Last seen: 4 years 7 months ago
+1
I never understood what tactics people had in mind after using a strobe for ‘self-defense’.
Even if you engage with an element of surprise, your ability to react thereafter is past what a flashlight can do.
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
BrianK
And if the strobe blinks more than 10x in California or NY without recharging it would be illegal.
DB Custom
DB Custom's picture
What’s the rate of the strobe on that law Brian? Could a guy dump a 14 round magazine with double taps fast enough for the strobe effect to get him in trouble? Silly
BrianK
ROTFLMAO!
14 rounds period will get you in trouble unless you can do the last 4 silently, as in hellywood silent. (and then bribe the coroner examiner to not see the holes that were seen)
I saw some shooters in July that maybe, just maybe, could beat the strobe. Seeing is as close as I get to that performance. But I think after scorekeeping for them, and shooting an all classifier match, I moved from a D class shooter to a C class shooter just by figuring out what was important and how the formula was weighted. But it’ll take time for USPSA to figure it out and send me a new card. That’s if it happened, but I think it did. It may have happened for others as well if I saw it correctly.
BTW, Max Michel is just a machine. I saw some fantastic times on “my” stage, and he just blew them away. All timing, PERFECT timing. Facepalm Not me. I DQ’ed the match after just 8 rounds. Totally my fault and when I did it I just stopped. I caught myself red handed and made my gun safe. I stayed to score the squad as we were undermanned, of course I scored the event and we were undermanned there as well. But I learned that this old fart can either shoot or score but not both.
For those scratching their heads I gave plenty of clues for an internet search.
sidecross
sidecross's picture
+1
That was funny!
blueb8llz
for the most part yes, attention getter. but it also act as a self defense tool for me. and since this light has a secondary switch for easy access for instant strobe, i see this as a good self defense light.
i train in the full contact combat art called krav maga, and they teach us how to fight with a flashlight.
and the strobe actually helps a bit. at first, we thought just a blast on turbo mode would do the exact same thing, but no, strobe was more effective. its more disorienting that a constant bright light.
DB Custom
DB Custom's picture
I got my Tiny Monster today. Really like the overall look, something about a mega deep reflector just works for me. Smile
No pocket clip, no lanyard. The picture on the box shows a pocket clip on the light, oh well. No papers either, which is odd, as I know for a fact that Nitecore puts a brochure of their line-up in the package and has a warranty card as well as a User Manual. I know this because I just got the Nitecore MH20GT yesterday. Wink
At any rate, really like the light, got the cell charging, will look into opening it up and defeating the proprietary measures after I’ve gotten some readings from it in box stock form. Looks like the battery tube/head is all one piece, so the access will have to come from up top through the bezel.
Will let ya know how all that goes…
DB Custom
DB Custom's picture
Freshly charged TM03 cell, lightbox says this…
55.65 Lumens
662.4
1593.9
3091.2
Now to solder the proprietary top cap onto an Efest 3500mAh cell. Wink (this proprietary bit taken off the Panasonic PF I bought before the light got here.)
EasyB
Last seen: 2 hours 22 min ago
55.65 Lumens
662.4
1593.9
3091.2
Thanks for the measurements. Assuming the reflector/lens is 83% efficient, that is 3724 LED lumens. Estimating from djozz’s graph, that is about 5A through the emitter. Is this the most powerful 6V boost circuit in a stock flashlight?
DB Custom
DB Custom's picture
Ever once in a while, a leading manufacturer gets it. They listen. Sometimes they even do it without a bunch of hoopla or fanfare. Nitecore is one of those companies. They have been quietly listening in the background and then they put it to work.
And when I see this, inside a light, I get it. And I put it back together and leave it alone. Big Smile
Cree XHP-70 on a proprietary strip of copper, soldered to a thick copper threaded heat sink and powered by 14ga wires. WoooooHoooo! Big Smile The copper sink looks to be about a quarter inch thick. Love it!
My Efest 3500 18650 is a success, 3129.15 lumens with as much run time as can be had from a single 18650 cell. Booya!
M4D M4X
M4D M4X's picture
Last seen: 5 months 4 days ago
nice
can you explain your cell mod?
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
Trashman531
Last seen: 4 years 4 months ago
+1 I’m interested in your cell mod too please!!!
DB Custom
DB Custom's picture
I bought a Nitecore TM03 proprietary cell while waiting for the TM03 to arrive. With all the speculation I just had to unwrap it and see what they did to make it proprietary. There is a circuit board they put on top of the cell, a Panasonic PF, that has a ground ring around the button top. The ground ring has two copper strips running the length of the cell and welded to the bottom of the cell. Then there is a metal disc with yet another copper strip on top of an insulation disc (cardboard) at the end of the cell covering the previous two copper strips. This last ground strip comes back up to the circuit board on top, soldered to the board independent of the main ground leads.
Removing all this from the PF cell I soldered it onto a new Efest 3500mAh dark purple cell that is rated as 10A continuous, 20A pulse, or essentially slightly better current capability than the PF cell and some 600mAh more capacity (PF is 2900mAh) Then I rewrapped the combination with covers given with cell purchases from IMRbatteries.com in Houston. Works just like the factory cell but with a better cell inside. Smile
(I’ll use the PF cell elsewhere.)
I intended to see what could be done about bypassing this proprietary set-up and allowing use of a normal cell, but when I saw how well made the light was inside I simply put it back together. Probably later I’ll remove the insides and figure out what to do to use normal cells. I don’t really worry about having the protection circuit and that’s mainly all that circuit board adds.
Chicken Drumstick
Last seen: 10 months 2 weeks ago
M4D M4X wrote:
code is available…
Is the code still available please?
DB Custom
DB Custom's picture
I should have checked to see if that white goo in the threads of the copper sink is thermal paste or adhesive, but I didn’t. Of course I have that to do, right? lol
blueb8llz
55.65 Lumens
662.4
1593.9
3091.2
By chance, did you measure lumens on strobe mode stock form? I’m impressed with the stock nitecore battery. So a efest cell only gave less than a 100 lumen gain.
DB Custom
DB Custom's picture
I don’t measure strobe because it’s always going to be wrong. The meter will try to average the output and show a much lower number than what the actual flash was.
The Efest cell gave a little boost but 600mAh capacity, which was the point. I could have used a 3000mAh cell for more lumens but chose capacity over output.
I’ll try the stock cell with strobe and see what it says, I don’t put much faith in it’s accuracy though. (Let’s face it, on most of our direct drivers the light is pulsed with PWM using full Turbo power to create a low mode, we only see low output, right? The pulse is full Turbo power, which is why this DD isn’t considered efficient.)
