Ah, Thanks! I knew that 0.025” = 0.635mm, but did not realize that “mil” referred to one-thousandth of an inch.
Do you pull the pins out of the plastic bit before using them, or leave the plastic bit on there? I’m using the pins for some lighted tailcap v5.3 boards that I ordered today. I just posted my question in this thread because it was the only place that I found a comment about sourcing the pins.
Just got my boards today. Hopefully I can build one tonight or tomorrow. I’ve been waiting for these to finish a d80 build for my brother. I have the lighted Tailcap assembled and everything is ready to go but the driver. Hopefully the circuit works well with the bleeder.
I think he’ll like it. He told me to have it done before hunting season. I’ve been noticing him steal my parents four wheeler so I think that is my que. time to get it done
Yeah I haven’t thought about where to put a bleeder on this layout… I’ll have to think about it when I get my 20mm contact boards. I suppose you could still stack it on C1… I don’t see why not
I think I’m going to put it on the spring side of the board. I’ve been doing that with the new fet +1 boards from Richard and it has worked well. Then I can swap it out without removing the driver. On those boards there is a trace and via carrying the plus signal that I scrape clean and put the resistor over that via connected to the ground ring. I see I might be able to do the same on these boards. One of the extensions of the plus/spring pad goes really close to a via with the ground signal. I scrape the solder mask off of that via and put the resistor there.
btw hopefully the three-pointed spring pad works for everyone. It’s perfect for me because I reflow my springs with solder paste to keep it clean. I tested it on one I already received and it worked perfectly that way; a good strong bond.
You’ll want solder that flows easily if you are using an iron though.
Well. I built a triple stack driver today. Aligning the pins proved to be more difficult than expected. And it didn’t help that I accidentally ordered 2oz contact plates as well. Two of the via traces broke loose when trying to align them. The vias were lined with solder mask and were difficult to solder too and I had quite a bit of troubles actually.
But it is built now and it’s perfect for what I needed. I’m going to put it in a blf d80 where there is room in the driver cavity, and a retaining ring that would normally not work with triple channel layout. The spring pads worked well for me. They required less heat to get the solder to flow and it seems to hold just fine.
Now that I put one together, I think I learned some tricks. Hopefully the next goes better
I have yet to flash the firmware. Hopefully I’ll get to that tomorrow.
Ok. I have the triple stack built and running bistro tripledown. It’s working with a 680 Ω bleeder and a 12k resistor in front of 6 green 0604 LEDs in the Tailcap. It was some work, but I’m excited now! The thing that work for me in the end was to use 22awg solid core hookup wire for connecting the vias. I solder the bottom via first then I clipped the wire at about 2cm then moved on to the next one and cut that one at 2.5cm. I let the wire length grow like that till all 5 were soldered. Then I feed the longest wire into the top board and then the others one at a time while sliding down the pcb. The wire was malleable enough to allow a perfect allignment. I would want to mess with the triple stack when not needed, but with lights that have retaining rings it’s the best option for sure.
Did my first of the TripleStack’s in the OP. The driver is definitely more work assembling that a traditional design, but for me it’s worth it for the clean look on the battery side. I also could have compressed it quite a bit vertically, but there wasn’t any reason to with the L2’s big driver pocket. I’m very pleased with the clearance for the programming clip.
Copying here my TripleStacks made specifically for the EagleEye X2R and X6R.
For the X2R, you just remove the top board on the original driver, get rid of the extra header pin, and solder this in its place. For best performance, you will also want to solder the big pad on the bottom to the top of the USB connector on the charger board. Headroom is tight, but the LED wire pads should line up perfectly with the holes in the shelf. If you order from Oshpark, be sure to get the thinner 0.8mm size. Also note the FET is the smaller LFPAK33 size.
For the X6R you will also use the stock pins. You will run ground wire from the charger board to the pad/via by the FET. The LED+ hole is over a spot you can safely drill through the charger PCB to bypass the spring/PCB. I’ll illustrate all of this with pictures once I finish my X6R mod. Also be sure to order this one in the 0.8mm size.
Thanks! The X6R is probably the best board I have ever made. I think even DEL would say the circuit is routed as well as can be, there should be plenty of clip clearance, Tom would be happy with the power path, and it even passes my aesthetics standard.
I’ve been lurking this forum lately and I’ve been reading a lot of your posts. Anyways, I really want to build a 17mm rev2 but I haven’t figured out what parts I need. Do you have a list somewhere of the parts needed to populate the board? I’ve looked but I couldn’t find it.
Another user reported an issue with the Triplestack X2R board. It seems I may have specified gaps closer than Oshpark can make reliably. There didn’t seem to be too much demand for that one, so for now I have taken down the link. If you are interested in ordering it, just let me know and I’ll fix the issue and repost.
Please fix it! I would love to mod a X2R with with a Triplestack variant.
I already ordered the X2R TripleStack board but I haven’t gotten around to assembling it. I can do some testing on it if it’s helpful. It’s the least I can do to support your work.
What should signs of a problem should we look for? A quick visual check shows that spacing between the pads shouldn’t be an issue, but it’s difficult to tell what’s going on with the traces that aren’t exposed.
I aslo checked the normal 17mm Triplestack base boards I ordered by accident and I may have found a problem with them. One of the three boards I ordered has an electrical connection between the center hole a smaller hole close to it. None of the others have it, so I think it could be an issue.
