Not only those parameter but also the focusiong: matrix, spot, weighted average…
I can assure you it makes a lot of difference for a thrower and a flood light.
Mostly finished modding this light over the weekend.
Initially I tried an XPL HI reflowed onto the stock star. This took just 10 minutes and made for a nicer tint and throwier beam.
Then I tried upgrading the driver to a 17mm FET driver with moppydrv.
Installing a new microswitch was a pain. The rubber post from the button boot is at the very back of the driver compartment. Not centered like in other lights I own. This works fine if your microswitch is a side-mount SMD switch. Not so great if all you had on-hand is surface-mount switches designed to mount upright.
I also found installing the switch inside in the right position was awkward simply because the light is smaller than other side e-switches I’ve worked with.
Attempt 1: Made a small frame for the switch and tried to wedge it in place with longer wires going back to the driver board. — Failed.
Attempt 2: Made a circular frame for the switch and pressed it into place. Once in position, the driver board is then pressed in place. Thin wires connect the e-switch to the driver board with glue around the solder joins to help protect the wires when folding into position. — Failed
Attempt 3: Made a u-shaped frame for the switch and pressed it into place. Similar to attempt 2. Double-checked all solder joints and replaced driver wires. — Failed. Switch wires or solder joins kept breaking.
Attempt 4: Same as attempt 3, but glued the switch into position before mounting so I could be sure it would actually click. Then folding wires and pressed driver into place. — Failed.
Attempt 5: Glued the u-shaped frame to the back of the driver with arctic alumina. While the glue was curing I held the driver together with the stock driver to eyeball the correct position for the switch. This seemed promising. No more broken switch wires. However, results were intermittent. Finally, I installed flexible wires to connect the switch to the driver board, to counter the small amount of flex during installation and when switch is pressed. SUCCESS! Finally.
After that I replaced the stock aluminum star with a Sinkpad. Had to Dremel the Sinkpad to fit. Replaced emitter with a fresh 4000K XPL HI 5A2 tint. Overall, I’m quite pleased with how it came out. At max power this light is VERY bright…. easily over 1000 lumens on a fresh Efest purple. However, parts of the head get too hot to comfortably touch in 30 seconds or so. Not much heatsinking in this tiny little light. I set the turbo timer at 25 seconds.
Not sure if I’ll solder-braid the tailcap spring or not. This light probably doesn’t need it.
Forgive the ignorance…but WHAT happened? I see two E11 variants at $30….is that a new price or is the 3D a new tint? Orrrrrrrrrr………did a hyperlink just automatically get added to your post because you changed out your emitter in the E11?
The last picture (gif) is obviously crap or faked. The camera was likely set to auto-exposure, and the exposure time or other settings are completely different between the two images.
I completely disregard that gif image, unless the settings are detailed in full. Don’t believe it. And given that the photographer doesn’t know how to operate a camera, I wouldn’t be surprised if he also doesn’t know how to set the flashlights to max.
It sure looks to me like the E11 is wider in the beamshot.
Anyway, my point was that nothing in the gif can be believed, without seeing the exif data from the image (and believing that the photographer isn’t faking something else, which I’m not even sure of, given the more believable beamshot comparison picture).
That gif is from review done by kj75, who does a lot of very competent reviews. There is always a possibility of mistake of course, but faking is definitely out of the question in this case.
Well, maybe he knows his flashlights. But it doesn’t appear he knows how to use the manual settings on his camera.
I suppose it’s possible he got a bum E11 light, or a bum battery. But given the huge difference in his gif, compared to side-by-side beamshots, I think he left the camera on auto. Or perhaps he let the camera blow out some of the highlights or something. Anyway, something is definitely off about it.
Can anyone who has the 2 lights comment on the difference in throw between them …… I would have thought the Mi7 with the XP-L Hi would have a tighter hotspot and longer throw but I know that’s not the only contributing factor …. mainly interested in if one has a much better throw than the other???
