So I’ve got an old Meco light that I’d like to do something with since it’s been sitting around. I’ve got so many spare emitters and drivers that I’d like to just slap something in it and see how hard I could drive it. Unfortunately it has a totally hollow pill with a tiny ledge for the MCPCB to sit on, so I need a piece of brass, copper, aluminum… anything to help with heat dissipation (along with a few jars of Fujik).
I’m looking for someone that has a copper/aluminum 20mm rod that can slice me off a piece about 1-2mm thin (the thinner the better.)
For a piece that thin, why not just get a small sheet of copper, say a few inches square by the thickness you’re looking for and cut out the circle? That thin and a good pair of shears should cut it.
Same problem here, only 20mm is too big. A penny is 19.06mm, and doesn’t drop in as expected (from the driver side, which is to be expected because it takes a 20mm driver).
I don’t want to file down and solder together a bunch of pennies, because the solder wouldn’t be as good a conductor as copper. And it’d be tricky to shave them down to juuuust perfectly fit the pill (ie, circular). I’d like a Cu slug a few mm thick to wedge in there and make good thermal contact with the pill. AS5 epoxy?
Someone mentioned a 5/8” Cu plumbing end-cap (~19mm OD). Wedge it in, fill with Cu shot and molten solder? Dunno if the end of the end-cap is flat enough, or rounded and needs to be pounded flat.
Wish they’d just make the damned pills solid…
Was looking into modding some C8 pills, but the collar needs to be shaved down, a notch added to hold the o-ring, and of course you have to first check to see if the threads (pitch and size) fit.
I had thought about that, but I only need a small piece. Whereas I’d have to buy a $15 sheet from home depot for just a tiny circle. The light is only worth 6 bucks so I’m trying to do this as cheap as possible.
Just tried a penny and it is the exact diameter of the hollow pill. There is a tiny shelf that the MCPCB rests on which is what I’m trying to find a tiny wafter to solder onto the shelf, and then put the mcpcb on top.
I had considered soldering the MCPCB straight to the pill, but that would make centering the emitter pretty difficult. But, sanding down a MCPCB, soldering it, and then putting the emitter/mcpcb on top is a great idea!
I think I may end up doing that if I can’t find someone with a copper rod. Thanks Khas!
