109 LED mod and other aspherical lights
25 posts / 0 new
zizo
 So I became a flashaholic about a year ago, and I've been modding some lights just for fun. I finally bought a lux meter recently and I think I can share some numbers to pay back for all the information I got from BLF.  Enjoy!
Measured at 3.17m with LX1010B and converted to 1m;
x2000: 9000lux
502b xml 25mm dx aspherical lens: 24k lux
c8 Lumapower xml 21500lux
X9 xml 44k lux
ZY C10 aspheric 35k lux
Tiablo aspheric R2 73K lux
109 LED XML 3.0amp 75mm lens 135k lux
Here are some other number I got by holding the lens in front of LED.
XML 3.5amp C10 lens  43k lux
XML 3.5amp Tiablo aspheric lens 65k lux
XML 3.5amp 66mm lens 95k lux
XML 3.5amp 75mm lens 150k lux
Xre R2 c10 lens 50k lux
Xre R2 66mm lens 125k lux
Xre R2 75mm lens 174k lux.
If anyone Interested 109 LED was modded with a C2 light and o-ring is made of silicone putty.
25, 66 and 75mm lenses are all from dx.
updated some beam shots.
Top XML 75mm lens, middle Tiablo R2, bottom ZY C10 at 10 yards
Tiablo R2 at ~ 50 yards
XML 66mm lens ( spill is from inside the shiny surface of bezel)
XML 75mm lens
Edited by: zizo on 05/15/2012 - 22:26
dthrckt
dthrckt's picture
Last seen: 1 week 2 days ago
good stuff!
willie
willie's picture
Last seen: 3 weeks 3 days ago
SWEET! I have to get a light meter. Where did you find your 109 host? I have an Optolife 80mm and am looking for a host. Most of my aspherical mods are on 50mm Optolife lenses. Have ordered several DX 50mm but went to Opto cause my reject ratio was 1in4 good.
Richie086
Richie086's picture
Last seen: 32 min 9 sec ago
Great job!  I'd love to see a beam shot of that 109 LED.
Richie
JohnnyMac
JohnnyMac's picture
Last seen: 5 days 6 hours ago
Does anyone have experience with this host? 109 LED from Harbor Freight
They list lens as 3 3/16" (80mm) so I'm sure a 75-80mm aspheric can be made to work. I've been eyeing this up for some time but hate to waste $20 on junk if it's no good to modify.  I'm mainly worried about having enough focal length for the lens to work with an XM-L but it looks pretty similar to what Zizo used.
willie
willie's picture
I have been waiting for that light to go on sale. Everything at HF eventually goes on sale. Want to mod the head to my 4D Mag PT120.
JohnnyMac
JohnnyMac's picture
Right now it's on sale for like $17.95.  Has it gone for less in the past?
keltex78
keltex78's picture
$17.95 is the sale price. I've looked at that light many times but haven't been convinced to buy it yet. The one item I want them to put on sale, they never do! Technically it is on sale now, but only $2 off... I think it's a good candidate for a 20%-off coupon.
http://www.harborfreight.com/5-in-1-digital-multimeter-98674.html
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
bibihang
bibihang's picture
Last seen: 1 day 8 hours ago
Great ideas there!!
I am curious about the build of the 109LED aspherical light. May I know is this http://www.manafont.com/product_info.php/uniquefire-c2-t6-900lumen-3mode-memory-led-flashlight-18650-p-7017 is the same C2 that you used? Any machining is needed and how did you adjust the focal point?
nitro
nitro's picture
Last seen: 1 month 3 hours ago
Does the C2 host screw in perfect ??? And where did u buy them at
zizo
Yes, almost! There was about .2mm gap between the C2 and 109 LED bezel, but you can push it hard and it will fit. I epoxy glued mine and it looks like one solid piece. The focal length is about 1-2mm long for dx aspheric. I didn't like raising the LED so I just trimmed the top of bezel where the lens seats, and the lens looks more protected with the bezel now.
The left light is in the wrong focal length just for comparison.
zizo
Can you measure the back focal length of Optolife 80mm? If it's around 50mm it should work. The quality of dx lenses are getting worse everyday. I ordered 5x75mm lenses and only 2 were usable. 50mm lenses are just junk and 66mm are the best but no good host to use it for.
Pok
Pok's picture
Last seen: 2 years 5 months ago
Nice job Zizo !!!
ma_sha1
ma_sha1's picture
Last seen: 1 year 4 months ago
Nice job!  Looks cool as well.
Now for the lights with  lux of 100K or higher, you need to measure at 10 meter or longer distance to avoid artificially high readings.
bibihang
bibihang's picture
So tempting to me... and i'm going to build one, too Silly
Any source to buy the 109LED flashlight?
viffer750
Last seen: 4 years 10 months ago
ebay
unique engrish language... Smile
Rezolution
Rezolution's picture
Last seen: 11 months 2 weeks ago
HA!  Yes, I have some experience with that host LoL.  I bought it when it was on sale and then used a coupon on it.  It looked cool so I figured I would see what it looked like.  About 3 minutes into using it, it shut off, so I opened it to see why...
The top of the battery carrier spring melted into the plastic from the current flow and shorted out inside the head Smile
As I recall the metal of the light felt like cheap pot-metal.  You might want to give it a shot though since you wont be using the factory battery carrier anyway.  You can always return it if you don't like it.
Rezolution
zizo,
What do you do to covert your 3M measurements to 1M measurements?  I have a light meter but never bothered testing out the lux values on my throwers...
ma_sha1
ma_sha1's picture
Lux@ 1meter = Measured Lux x Square of measuring distance in meters
3 meters
Lux@1 meter = measured lux@ 3 meters x9
5 Meters
Lux@1 meter = measured lux@5meters x25
10 meters
Lux@1 meter = measured lux @10 meters x100
Most flashlight light beams coming out of flashlight first converge & then diverge, the point of this converge/diverge junction gives extremely high lux but it's not accurate indication of throw.
The longer the throw capability of a flashlight,  the smaller the beam spread angle will be, thus the converge/diverge junction will be further away from the flashlight, thus the measurement needs to be taken further away  from flashlight to be more accurate.
Typically, I measure at 10 meters for lights ~100 Klux or higher & 100 meters for lights with 1 million lux or higher. If questionable, then increase the measuring distance & try again.
10 meters is not always enough, I have a light that measured ~2Million cps (CP=lux@1meter) at 10 meters,
but only 800,000 cps when measured out at 100 meter distance.
Pok
Pok's picture
Why measure at longer distance but lux reading less, because there are many dust , vapor , scattering of light , etc.. in the air.
(Maybe I will  measure at space Wink )
Rezolution
3 meters
5 Meters
10 meters
Perfect, this is exactly what I needed to know.  I'll try to take some readings tonight when I get home.  I'll have to convert feet to meters first though since I'll be using a tape measure to see what the furthest distance in my basement is  Smile
Is there a variable I can throw in for cat dander in the air? LoL
ma_sha1
ma_sha1's picture
There is indeed a difference if air is not clean or humidity is high, but that's not nearly as big of an error impact as measuring at too short a distance & end up measuring at the convergence/divergence junction. Worrying about air quality is like splitting hairs now for typical flashlight lux measurements.
Unless, one is going for world record, then go up to the mountain where observatory is & measure it from a mile away Smile
zizo
I repeated the measurement again at 6.74m
75mm aspheric 3600lux ~163klux at 1m
66mm lens 2100lux  ~95k lux at 1m
C8 xml 310lux ~ 14k lux at 1m
Tiablo R2  1700lux ~ 77 lux at 1m
So it seems like aspheric lenses are if not statistically better, they are not doing worse at 6.74m than 3.17m, but C8 with a reflector is doing worse as expected. I guess it could be that the lens focuses at longer distance better.
Rezolution
Ok I did my tests at 5 meters.
P60 SMO XP-G - 5,500
Sipik Clone Zoomie - 6,750
P60 SMO XM-L - 12,000
X2000 Zoomie - 14,250
Nitro's P60 aspheric kit with XR-E R2 - 14,750
Stock 2D Rebel Mag - 21,250
52mm Aspheric Mag XM-L - 61,250
WalterK
Last seen: 2 years 9 months ago
Fun hey, knowing what they do Wink !?
Could you please measure the lux @ 1 meter distance from the bare led?
So without the lens? Hope you can screw the bezel of from the 66mm and 75mm flashlights…?
That would be very interesting. It would give insight in what lumen is coming from the led, and then in turn how good the lens is.
It would make it easy to predict what candela you would get with a comparable set-up.
Its also a good way to evaluate a lens with the formula for throw.
I am working on a 75mm aspheric and XM-L at 3 Ampere.
My mods in my flickr sets
