ITS HERE! SIPIK SK98 - A 18650 based Sipik SK68 with an XML!
184 posts / 0 new
Vectrex
Vectrex's picture
Last seen: 1 year 1 day ago
fishinfool wrote:
Ok here's the deal.......I know this Sipik style torch is very, very popular here at BLF but am I the only one who thinks it's fugly?  It's design probably doesn't work too well as a pocket edc because it looks like it gets stuck A LOT.  This is just my opinion folks so don't have a cow.
No you are not alone... I like the C78 which is a (Coast) Led Lenser clone a million times better as far as aesthetics go. Too bad a few of the best functioning flood-to-throw 1AA lights look like sharp edged hideous tools (Sipik SK68, Romisen RC-29). The RC-29 is much better in build quality as the SK68 and the C78, but you can shave yourself with the tailcap. The C78 has tailswitch problems sometimes.
kreisler
kreisler's picture
Last seen: 8 years 2 weeks ago
i've got a bada$$ file on my new victorinox multitool
*FMI* i got 4 i/o sh
Firelight2
Firelight2's picture
Last seen: 5 hours 55 min ago
I own a few Sipik 68s and clones myself and I agree.  The design IS ugly.  Personally, I don't like it for pocket carry because:
1. The crenelations on the bezel are sharp.  They feel uncomfortable in the pocket and feel like they might wear through my pants.
2. The bezel and body near the bezel seems to be wider than it needs to be on a Sipik SK68.  If I'm going to have a light with a wide body I want the light to take full advantage of it... this means that the lens should be as big as possible so it can use the extra width.  In the stock Sipik SK68 it's not.  However, my 3-mode SK68 clone does actually use a bigger lens in the same sized body.
3. The decorative ring that serves as the clip mount sticks out.  Definitely something you'll feel in your pocket.  It also makes it difficult to unscrew the tailcap.
4. The clip tension is far to strong to make it easy to get onto a belt or pants, and the clip itself is very short.  The clip doesn't feel usable as a clip to me.  Instead it seems to serve as an anti-roll device.  Can't be easily removed either since the screws holding it on tap right through the body of the light.  If you remove the clip you'll have open holes leading to the body compartment unless you put the screws back in without the clip or fill the holes with a filler such as epoxy.
Personally, in a pocket EDC light I prefer an efficient shape that isn't bigger than it needs to be.  I also want something smooth that won't tear up my pockets.  A clean cylinder with full knurling works well.  This is why I much prefer the shape of the Sipik 58 over the Sipik 68.  The SK58 is much cleaner and smaller.  A much better shape for EDC.  The stock SK58 is inferior though due to worse emitter, but this can be fixed with a driver and emitter upgrade.  The SK58 is easy to mod.
hank
hank's picture
Last seen: 21 hours 54 min ago
are the 68 and 58 close enough in size so that the guts of a 68 can be dropped into the 58 body, or are sizes not close enough?
Pherra
Pherra's picture
Last seen: 7 years 1 month ago
I´ve have ordered one hope it´s a good buy!
sobe
Last seen: 10 months 3 weeks ago
Is there a AA version of this?
Firelight2
The pills are different sized so unfortunately they aren't interchangeable as-is.
However, you can fit the same sized driver and emitter in either pill with a little work.
The slot for the driver in the Sipik 58 is only 16mm.  But with a little filing at the edges of the driver and a 17 mm Nangj 105c fits fine.  The chips on the bottom of the driver may prevent the pill from screwing down completely, but this is actually a good thing anyways since it means the lens will retract closer to the top of the emitter and give wider spill.
Vieplis
Last seen: 6 years 2 months ago
I measured 15mm, not 16.
The golden dragon is higher than XR-E, it is not quite 1:1 swap, the retaining ring does not fit.
sixfink
Last seen: 2 years 9 months ago
Beamshots, anyone?
I have read all I could about combining aspherical lenses with the ubiquitous XM-L emitter, and the outcome wasn't very promising. My own experiments were desastrous- such an ugly beam, I quickly stopped before I dumped too much money into this.
Now - does the collimator lens work decently with the XM-L on this new Sipik? I'm curious.
1. The crenelations on the bezel are sharp. (...)
Yus, they are! I didn't want to live with that, so I took care of that on mine with a file and some fine-grit sandpaper. As a bonus, you'll get a groovy "used"-appearance!
Firelight2 wrote:
2. The bezel and body near the bezel seems to be wider than it needs to be on a Sipik SK68.(...)
uhmm... yes.
All true - but I've learned to appreciate the advantages that come with it. First, when I cannot unscrew it easily, it cannot unscrew itself easily, as well. Second: I found that it makes a decent cigar-grip.
All very good and profound observations. I usually clip it to the top button hole of my loden coat, to use it as a worklight. It works for me. Since the clip IS strong, as you noticed, I rounded the edge on the body it is resting against with (you guessed it) a flt file and some sandpaper. Even more cool-looking grungy signs of usage!
True enough - my current EDC still is Boaz's Nitecore he used to sell last year. Much sleeker and lighter. The only change I made was to tie it to my trousers, and stuff in an eneloop. Still, I like my SK68 very much, too.
oh, thinking about it, you missed one of the biggest cons: The SK68 doesn't come with the emitter clued to the pill. It is held in place just by the leads! Has been the case on every single one I bought (total of seven). I wonder if they have fixed that on the new one?
regards, Simon
weiser
Last seen: 7 months 1 week ago
For some reason I actually like the design of this light (and SK68). Being a zoomie it just works for me. It's simple and utilitarian in design, which I tend to prefer in this kind of light. I don't think it would work on anything bigger though.
trooplewis
trooplewis's picture
Last seen: 2 years 4 months ago
LOL, yes, that is the original Sipik 68
Rats, finally sold my 2010 509hp Mustang...now I can buy more lights!
Sold the red one too! Now guess what I drive, doing my penance for 500 hp commuters...
http://dreammustang.com/
http://i884.photobucket.com/albums/ac47/Ha
bose301s
bose301s's picture
Last seen: 8 months 1 week ago
I must be odd like weiser, I like the design and looks of these Sipik models, they just look cool IMO. I may pick this one up, will see how others like it first though.
KumaBear
KumaBear's picture
Last seen: 7 years 2 months ago
I ordered this just because I was curious.  Now I have to find it so I can compare to the others:
http://www.ebay.com/itm/300552404670?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
KumaBear
Lensman
Last seen: 9 years 7 months ago
KB, I have two of those from ebay seller ultrapire. IMHO one of the best buys for the $ I've made since joining BLF. As always at this price point, QC is probably questionable so I hope yours is as good as mine; if it is I'm sure you'll like it. Be interested to hear your impressions Smile
sobe
I meant with the XML and 3 modes!
wewander
Last seen: 6 years 4 weeks ago
dthrckt
dthrckt's picture
Last seen: 3 days 19 hours ago
I have one.  I converted to xm-l and improved the pill.  Switch went bad, and since it is retained by pressed in plastic, I haven't fixed it yet.  That's best reason to buy this 18650 sipik imo...even though it is more difficult to unscrew the tail, at least the switch is serviceable
Lensman
dthrckt: "That's best reason to buy this 18650 sipik imo...even though it is more difficult to unscrew the tail, at least the switch is serviceable"
Good comment. If these Sipiks get good reports I'll definitely buy a couple.
weiser
If the report comes back with positive impressions this is a guaranteed buy for me. I've been waiting to try out a decent XM-L zoomie but was in no rush. Considering the reputation of the SK68 this should be a no-brainer for the XM-L zoomie buyer.
gloomywarfreak
gloomywarfreak's picture
I ordered one just now. Now for the long wait again.
weiser
Should be arriving to some of you very soon. Looking forward to your feedback Smile
bose301s
bose301s's picture
For under $20 shipped with tracking I decided to say screw it an ordered one. Hopefully have it within a month, lol.
Toppel
Last seen: 3 years 7 months ago
I got my 18650-Sipik 68 today!
Compared to the smaller one:
Compared to the smaller one.
Front:
Front
Both on Flood-Mode:
Flood
Zoomed in:
Zoomed in
Zoomed in
What I dont like is, that the 18650 Sipik gets hot very fast. After like 2 minutes it was nearly to hot to hold.
The beam is much bigger and a little bit brighter. I dont know whether I like it or not. I will have to wait until tonight.
gloomywarfreak
@toppel: That was fast! When did you order? Nice shots also.
Toppel
Thank you!
I ordered on 16th.
That was really fast, yes!
Ledsmoke
Ledsmoke's picture
Last seen: 1 year 6 months ago
Thank you for sharing.
IMO that looks like just what the doctor ordered for me.
BIIIG flood and decent throw for pointing at stuff.
I am so bummed that I cant receive it while I am on this ship. I would have ordered 3 already.
About the heat: That is good. It means some decent heatsinking is working to keed the led cooled. What do you think about the modes??
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
Toppel
I dont know if its good or not. But you can warm up your hands in winter with it Big Smile
The flood is very big!
The modes..mhh I dont know. I forgot that it has modes and when I turned on the lowmode I first was like: WTF where is all the brightness?! Then I accidentally turned on the strobemode and i remembered that is has modes Wink
I like the smaller one without the modes better.
But i can live with it. I like the reverse-clickie.
I think it is worth every cent. Good quality. Impressive flood. Nice throw.
Ledsmoke
Ledsmoke's picture
Smile
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
clagged
clagged's picture
I put it on my cheap DMM and got 2.1amps on high.
I don't like the strobe so I was going to do a driver swap to a 2.8amp nanjg 105c driver however there is no heat sinking in the pill, the star is suspended by the edges of the pill only giving very little area for heat transfer.  I will need to improve the heat sinking before upping the output.
SK98 Driver
alex21
Last seen: 1 week 2 days ago
which has farthest throw? still like the little brother better Smile
