Review: Hypetac P1A SS (1x AAA)
31 posts / 0 new
Steve_the_Chief
Steve_the_Chief's picture
Last seen: 2 years 1 month ago
Hypetac P1A SS 1xAAA
Reviewer's Overall Rating: 90%
Hypetac P1A
Summary:
Battery: 1x AAA
Switch: Reverse Clicky
Modes: Mid - High - Low
LED Type: XP-G R5
Lens: Glass
Tailstands: No
Price Payed: USD 23,45
Date Ordered: May 2012
Pros:
  • Build quality
  • Fit & finish
  • very practical brightness levels
  • no strobe
Cons:
  • weak pocket clip
  • switch could eventually be engaged in your pocket
(With this review I changed from the five stars rating to a percentage rating. I think it is more flexible that way. So, one star equals 20% if you want to compare.)
Although I do have a couple of 1xAAA lights, I was still looking for my perfect edc light.
For me, an edc flashlight needs three modes:
- low has to be low enough for comfortable reading and to provide long runtimes even from a single AAA
- medium as the allround mode with reasonable output for everyday situations, like looking for dropped keys or checking dark corners for spiders etc.
- a high mode for emergency use that squeezes as much light as possible out of the battery
I don't need a split ring because I don't like a flashlight hanging on my keys, and I favour a pocket clip over a lanyard on a light of such a small size. Besides, I don't like twisty lights, so my options are greatly reduced.
Now we all know that there is no such thing as a perfect flashlight (or else we wouldn't constantly be buying new ones), but this one comes close.
So, what is it? Here are some specs:
* LED: Cree XP-G R5 LED, Max 90 Lumens
* Battery: 1x AAA alkaline or NIMH
* Materials: Stainless steel
* IPX8 waterproofing
* Reflector: Orange peel
* Accessories: two spare O-ring
Output & Runtime:
Medium 28 lumens / 3.5 hours - High 90 lumens / 1.2 hours - Low 3 lumens / 40 hours
Operation:
Press the tail switch will turn on/off the flashlight
Chang brightness levels (medium - high - low)by pressing light tail switch
Flashlight will go to medium automatically for every start if turning light off over 5 seconds
Dimension: 11.3cm x 1.4cm      <-- This is actually wrong, the length is 10.2 cm!
Weight: 44.5g (excluding battery)
Features / Value: 95%
It comes in a nice package which looks very non-budget. Instructions are on the back of the box, only accessory inside is a little plastic bag with two o-rings. Bright and shiny stainless steel finish. Overall feel is that of a non-budget, high quality light. But: No attachment point for a lanyard (only -5% because I don't like lanyards on small AAA flashlights anyway).
P1A Packaging
Design / Build Quality: 70%
It is not exactly the smallest light for a 1xAAA, but it should fit in any kind of pocket there is. The stainless steel should make it durable enough to take some beating.
When I first got it in my hands, I was suprised how hefty it feels. Probably too heavy for a dress shirt pocket. Now some folks might prefer an EDC to be as light as possible, but I think heavy is good. Heavy is reliable. If you run out of batteries, you can always hit someone with it (thumbs up if you get the movie reference).
Of course you could buy the aluminum version if you prefer a lighter flashlight.
The surface is bright and shiny, absolutely flawless. The reverse clicky switch is a lot quieter to click than the usual rubber-booted tailcap switch. It feels like something you would find on a precision instrument. However, you don't need to use great force to engage it and thus it might accidentally get turned on when loosely flying around in your pocket (-5%). Furthermore, with the protruding switch the light cannot tailstand (-5%).
If I were to make an improved version, I would leave a metal rim around the switch. That way the switch would be protected inside your pocket and the light would be able to tailstand.
When I first put a battery in and screwed the light together, a bit of the o-ring got stuck and squeezed out between the two parts. When you screw it together, you have to pay attention that the o-ring sits firmly in its groove and doesn't get squeezed out of it. The head part seems to put a lot of pressure on the o-ring to achieve IPX8 waterproofing. Two spare o-rings are supplied, so this shouldn't be an issue.
The lens is made of glass and the reflector is a very low orange peel type.
The beam is a very practical flood kind with a large hotspot.
About the only drawback I can find is the pocket clip. It looks like one from a cheap ballpoint pen and doesn't match the high quality finishing of the flashlight. Besides, it feels a little flimsy and there's not much pressure on it (-20%). And I would absolutely love it if the clip would be reversible.
A closeup of the clip
Battery Life: 100%
Current draw with eneloop cell (runtime calculated):
Mid: 0.3 A    (2.7 hours)
High: 0.9 A    (0.9 hours)
Low: 0.1 A    (8 hours)
Measured values are rounded because it was a little hard to maintain a good connection (on this light the head screws off so you can't measure at the tailcap).
So it maintains the highest brightness for almost an hour or gives you an emergency light for a whole night. Nice!
Light Output: 95%
The stated brightness levels of 90, 28 and 3 lumens are very reasonable. Compared to my Ultrafire A3 (which draws 2 ampere and delivers maybe 60-80 lumens), this provides more light with longer runtime. Nice!
The brightness levels are exactly what I need for daily use. And it starts in medium mode, which is convenient becasuse that one will probably get the most use.
The lower modes are achieved by PWM, but the frequency seems to be quite high. You can hear the buzz only if you hold the flashlight close to your ear. But, -5% because the buzz is there.
Summary: 90%
Hypetac surely put some thought in creating this sexy looking flashlight. Brightness levels are fine, machining is fine, overall feeling is fine. In an improved version I'd like to see a protected tailcap switch and a better, stronger pocket clip. Make it reversible and you've got a happy customer!
Some Pictures:
Reflector and XPG LED
Size comparison: Hypetac P1A, MXDL 3w clicky, Ultrafire A3, Maglite Solitaire
White wall shot (spill area is bigger than the picture):
If you have any questions or if you would like to see more pictures, feel free to ask.
Have a nice day!
Edited by: sb56637 on 08/26/2014 - 17:12
Lensman
Last seen: 8 years 11 months ago
Great review Steve, thanks for taking the trouble Cool I don't normally like the penlight form factor (not sure why, just never been keen) but that is one nice looking little light! Shame about the pocket clip; I guess that's one area where this type of torch really can't get away with weakness. Maybe it'll turn out to be stronger than it feels.
Misfire
Thanks for the great review.  Cool  I've been thinking about getting the 2xAAA version, as $27 seems like a really good deal for a SS flashlight.
Question: is the clip removable?
Steve_the_Chief
Thanks guys!
The clip is removable. You have to unscrew the metal cap around the switch, it holds the clip in its place.
I just did that and bent the clip a little in shape, it has more tension now. It was bent quite easily though, don't know how long it'll hold the tension.
fishinfool
fishinfool's picture
Last seen: 1 year 9 months ago
Very nice review Steve!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Langcjl
Langcjl's picture
Last seen: 3 years 1 month ago
I was just looking at these on SB Yesterday. Thanks for the review.
Piers said " ....but who wants enough light, when you have the option for far too much "
jacktheclipper
jacktheclipper's picture
Last seen: 5 hours 55 min ago
Cool
What I do
Steve_the_Chief
Thanks for your nice comments.
Yesterday I wasn't able to take a good makro shot of the clip because of the lighting. Today was better so I edited it into the review. It's hard to take good photos of shiny things though...
ralf
Last seen: 2 years 7 months ago
HYPE-tac?
Are we in for a bunch of XXXtac names now that XXXfire has pretty much been mined out?
fishinfool
Very nice photos Steve!
Misfire
That new pic of the clip is encouraging; to be honest I was expecting it to look much more frail.
I meant to ask you about the switch.  Does it stay locked down when the light is turned on?
Steve_the_Chief
The switch sticks out 3 mm no matter if it's on or off.
sb56637
sb56637's picture
Last seen: 14 hours 12 min ago
Nice! Decent price for a Shiningbeam light. Thanks so much for the great review! Frontpage'd and Sticky'd.
marcl
Last seen: 4 months 1 week ago
ralf wrote:
HYPE-tac?
Yesterdays Fire is today's Tac!Wink
Marc.
Eagles may soar, but weasels don't get sucked into jet engines!
scaru
scaru's picture
Last seen: 4 years 5 months ago
ralf wrote:
HYPE-tac?
Wait, no more fandyfire?!? No!!! Cry
Steve_the_Chief
Thank you Mr. Admin!
BTW, maybe I should reserve the brand name "FireTac" Money Mouth
Steve_the_Chief
Over on CPF is a review of the Bronte RA02. This is probably the same light as the Hypetac P1A in a slightly different exterior and with minor tweaks on the electronics. By the way, that review is a lot more thorough than mine and every interested user might want to double check, because most of it applies to the P1A as well.
The packaging looks the same, overall design is the same, the underside of the circuit board looks the same, brightness levels are also in the same range.
I think that Hypetac and Bronte are just sales brands and their flashlights are manufactured in the same factory.
Steve_the_Chief
After having used this light for some time I discovered a little design flaw that sometimes shows when using rechargeable batteries.
I noticed that sometimes when shaking the light it would flash on even with the switch in the off-position, other times after switching off it would stay on and needed a few shakes to go off.
To illustrate what was going on, first I'll show you a side-by-side-shot of an alkaline AAA cell and a rechargeable AAA cell. Note that on the rechargeable cell the negative pole takes up the whole area of the cylinder bottom:
Photobucket
And here's a schematic drawing of the P1A battery tube (click to enlarge):
Photobucket
At the end of the battery tube, there is a metal ledge around the spring with very little clearance to the negative battery end. When using a rechargeable battery, the negative pole sometimes touches that ledge and, bypassing the switch, closes the circuit.
My solution was to cut out a washer with an outer diameter of 10mm and an inner diameter of 6mm and place it inside the battery tube on top of that ledge. At first I cut it out od a .5mm guitar pick, but that was already too thick. I am using .2mm carton now and I didn't encounter this effect ever since.
scaru
scaru's picture
I guess in Germany you have different types of batteries. In the US negative poles are always flat and take up the whole end.
Steve_the_Chief
That's interesting, didn't know that! That means even more batteries would be affected.
Of course there's also a possibility that my particular light is missing some isolation piece in the bottom, but I somehow doubt that. And I won't order a second one to check Wink
Steve_the_Chief
Just a minor status update - I have grown so fond of that little bugger that I almost feel naked when I leave the house without it.
The pocket clip is doing a great job since I bent it to increase the tension, and the light it is perfectly reliable with the diy washer mod.
You have to carry it clipped to a pocket though, I had it in a jacket pocket a few times and it managed to turn on and drain a battery once.
ohaya
Last seen: 3 years 2 weeks ago
Hi,
I know that this is a really old review thread, but I just got one of these from shiningbeam.com, and at least initially, I’m finding it very nice. I have several AAA twisties, including a ITP A3 EOS (upgraded) and an Illumina Ti, which are much smaller, but I really like having a clicky switch on a AAA light, which is what this HypeTac has.
Also, I like that it turns on in medium mode instead of high or low. A good compromise IMO.
Besides the clicky, the stainless steel light really “caught my eye”. It’s actually pretty nice aesthetically, and not just a plain shiny tube, but the grooves on the head and tail end give it a kind of “designer” look.
Finally, re. the clip: I don’t wear pens or lights in my shirt or pants pockets, but I ordered a lobster claw from shiningbeam.com at the same time, I put the split ring on the clip, and will wear it like that on a belt loop. I also do the same when I’m carrying the ITP and Illumina Ti (but not all at the same time :)!)…
Thanks for the review and pics.
Jim
P.S. Has anyone tried this light with a 10440 yet?
Steve_the_Chief
Glad you like it!
Concerning the 10440 cells, the manufacturer states that it is alkaline/NiMH only, so personally, I wouldn't try it just to be safe.
However, if you are a more daring fella than me... Cool
ohaya
Glad you like it!
Concerning the 10440 cells, the manufacturer states that it is alkaline/NiMH only, so personally, I wouldn’t try it just to be safe.
However, if you are a more daring fella than me… Cool
Hi,
This light has been out for awhile, so I was hoping that someone else had tried it :)…
In general, what would determine if it’s safe or not? Is it the # of amps that the driver is spec’ed for? Or something else?
Jim
P.S. Besides, I don’t have any 10440s yet :)…
Steve_the_Chief
Well first of all, the driver components must be rated for the higher voltage. If that is the case, the thermal path of the LED must be good enough to wick the additional heat away.
It's really hard to predict anything, it could be an instant driver fry, or it could work fine at first but with a reduced lifespan...
You could try and ask the manufacturer, I think they've got a contact form somewhere on http://www.hypetac.com/
ohaya
I may do that (ask mfr), but I’m always hesitant to do that, lest they say “no” :)…
“It’s easier to say you’re sorry than to ask for permission” or something like that.
Jim
Steve_the_Chief
In case you like coloured flashlight, the Hypetac P1A's almost identical twin brother, the Bronte RA02 is available in red and blue for $ 22 @ manafont:
http://www.manafont.com/product_info.php/bronte-ra02-cree-xpg-r5-led-95l...
There's also a 2AAA version (RA03) available for only $2 more.
ohaya
In case you like coloured flashlight, the Hypetac P1A’s almost identical twin brother, the Bronte RA02 is available in red and blue for $ 22 @ manafont:
There’s also a 2AAA version (RA03) available for only $2 more.
Shining Beam has the 2xAAA one also (http://www.shiningbeam.com/servlet/the-73/HypeTac-P2A-SS-LED/Detail) also, in stainless, which would be domestic in the U.S.
Jim
Steve_the_Chief
Right! The black aluminum version seems to be sold out though.
ohaya
Hi Steve,
Do you know if this’ll take 10440 batteries?
Jim
Steve_the_Chief
According to DX, the Bronte RA02 takes 10440 cells, but I wouldn't count on that, as the manufacturer doesn't state anything like that...
