Really cheap recoil DX
35 posts / 0 new
Tas62
I've been using an Ultrafire UF-007 recoil as a mounted weapon light for a while now. I've found it really useful for that purpose.
About a month ago I noticed this little Sipik branded light on DX. At $US14.80 I couldn't resist and ordered the light. Out of the box it's a well
finished light with even anodising and no rough edges. Firing it up with an 18650 it's obvious that it uses the same driver (and other internals) as the UF version. That means it's a strictly 3.7-4.2v light..........I fried the switch on the UF using the 'recommended' alternative 2X CR123's.
My conclusion......good value if you need a cheap 'thrower' with absolutely no spill
Sipik CK361 recoilhttp://www.dealextreme.com/details.dx/sku.50104
Edited by: Tas62 on 12/30/2010 - 03:43
Kokopelli
Kokopelli's picture
Last seen: 2 years 6 months ago
Thanks for the tip. I added this to my wishlist. How's the beam in night? I may use this as a lightsabre if it has a strongly definite beam.
Tas62
Hot spot is 55cm @ 6m distance......no spill.
Budgeteer
Budgeteer's picture
Last seen: 8 years 3 weeks ago
No spill at all or just unworthy to mention?
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Tas62
Apart from a very faint ~1.5m disc @ 5m range..............nothing.
pipopopo
Last seen: 8 months 3 days ago
would you be kind enough to show us a long distance beamshot
I am looking for a good thrower
edit:
Don't mind I have found some great videos on youtube on the Ultrafire
http://www.youtube.com/watch?v=OitrHB9SGKA&feature=related
How does this one compare same brightness same throw?
BanglaBob
Yup, I ordered one too. Probably arrive end of January, knowing DX Frown
I figured it's cheap, and I don't have one of those "recoil" flashlights; so what the heck...
My son's using the C74 recoil thrower from Focalprice and it's not bad at all. Would be interesting to see how this one stacks up against it
Lights out! That's when things get interesting...
Tas62
yes, it's exactly the same as the uf-008 in throw and beam shape. Looking at it long enough and there is a slight difference in bin colour.....but hey!...this is DX.
Budgeteer
Budgeteer's picture
Which design is better for great throw anyway? Long smooth reflector with forward firing emitter or a recoil design such as the above mentioned?
Seems to me that recoils have virtually no spill as opposed to classic throwers. Non recoil could have greater range tho. Any1 knowledgeable on subject can comment on this?
Kokopelli
Kokopelli's picture
A recoil thrower may give further range but the reflection losses diminish the total light intensity. A forward looking R2 should shoot far enough.
I deleted my own sentence. I would write, you could upgrade the deep reflector shooter with a stronger emitter but you can't change a recoil throwers emitter, or pump more current due to lack of heatsink, but then I realized that a powerful emitter has a wider base and is more of a flooder in fact. These deep reflectors don't work well with even a tidy XM-L.
Budgeteer
Budgeteer's picture
I noticed almost all throwers are still using q5-R2 emitter class.
Kokopelli
Kokopelli's picture
XR-E leds have a tighter beam (90 degrees) while XP-G's should have somewhat wider (~135 degrees ?). So they have the advantage to focus the light to a point. These deep reflectors are designed for an emitter with 90 degrees output and they work flawlessly with them. But with a wider angle emitter their walls scatter the light to different angles and can't focus as good.
XP-G and XM-L leds need a totally different, wider head design to throw farther. I guess in the sake of size, portability and modularity (to keep the same parts and machine settings) manufacturers choose to continue their older designs. I don't think there is a real limitation in throw with just the size of the emitter. There must be a way to throw a 1000 lm light while you can easily throw 200lm to 200m's. Smile
pipopopo
That is because R2 is the highest bin for XR-E Cree leds (a XP-G would spill to much light to the side)
Budgeteer
Budgeteer's picture
There were also S1 and S2 cree's with a lumen or two more than R2 but actually never to be found on sale anywhere.
Kokopelli
Kokopelli's picture
Aren't they successors to XP-G family?
Budgeteer
Budgeteer's picture
Belongs to species XR-E but im unsure. Time to check...
It is XP-G... blah.
So the R2 are are about the best you can get without going into dedoming emitters.
pipopopo
Humm I am still in doubt between the Ultrafire UF-008 and this Sipik one.
I think the UF looks better but this one is less money  ..choices...
These recoil light are not very pracital as EDC but I think a flashaholic like me can't go without
Kokopelli
Kokopelli's picture
For what reason do people use these? I mean I understand it can work as a spotlight under the rifle or a remote signalling light but I can't find any uses other than a light show toy.
Budgeteer
Budgeteer's picture
I really don't have a pratical use for a recoil thrower but i would like to have one for no particular reason or greater purpose. Most of us have some flashlights we could live without yet we don't regret having them right?
Kokopelli
Kokopelli's picture
Yes like those 5 EDC lights I bought last week Smile Would make a triple battery SST-90 if I'd carry them altogether. Hımm, is this a sign, is it the time I should get an SST-90?? Laughing
Hrvoje
In fact, it is possible to change emitter in a recoil thrower, but it requires a lathe and a lot of work. I have experimented with different emitters in KD Viewfinder (KD version of UF-008), and I found that the best emitter is overdrived XR-C P3 thanks to smaller EZ700 die. Less overall output, but more throw. For the same reason, I changed R2 emitter in my HS-802 and put in Cree XR-C P3 from Romisen RC-G2. Less output, even smaller hotspot and over 30000 lux at 1 m.
Aleister
Aleister's picture
Quick question. A typical Q5 "recoil" thrower is going to throw further than a typical FTT (like Romisen RC-C6) zoomed in?
I have not real use of a thrower but I like these "recoils" (by the way, I don't have real use for 40 flashlights either but that didn't stopped me...  Tongue out )
Let a flooder be my wife and a thrower be my mistress
cabfrank
Last seen: 1 month 2 days ago
it will throw farther than that, but it won't throw farther than an R2 in a P60 host with an aspheric (plano convex) lens. i would have never thought this, but i now know from experience.
and yes, you should have one. if you're up to 40 lights, you might as well have 41...
uncajesse
Last seen: 1 year 5 days ago
yeah cool light technology for this flashlight, but if i wanted throw, i would also use a lens.  less loss of efficiency for starters.  an SST-90 asphyrical would throw, no?
for 14 bucks tho, this is cool if you just want one for no reason at all, other than to find out if you like it or not.  wouldn't be hard to re-sell it for 20-30 bucks anyways.
BanglaBob
Because it's fun Laughing and boys must have their toys LaughingLaughing
Seriously, if you're looking for pure throw, and want to achieve it as cheaply as possible, it's one way to go. My son's C74 throws 75% as far as my Catapult V2, at roughly 15% of the cost of it (the V2). The beam profile is not going to win any awards, though...
Oldienea
Oldienea's picture
Last seen: 6 years 5 months ago
recoil throwers, but even after I installed a new 1000mA single mode driver, I'm not really impressed. It does not much better than any of my other zooming lights.
I have an R5 that sits in a food can. It has a 66mm aspheric lens, along with a 1400mA driver and a 18650. This throws really well, but it's a bit bulky and ugly. I would say it reaches 300 meters easy. The bigger the aspheric lens the smaller is the image of the die. Fun to play around with, but no practical use either. As soon as China post finally decides to send my
http://www.lightake.com/detail.do/sku.Small_Sun_ZY_A8_CREE_Q3_3_Mode_130...
wich I ordered mid november from Lightake, I will try, what the R5 does in that one. I guess with the bigger lens diameter, combined with the R5, I should end up with a zoomie that does about the same as the smaller zoomies do (same die size in throw), but with an increased light output. All that in a 3C Maglight form factor, could be nice.
cabfrank
you are going to make a throw monster out of that one aren't you? i always liked the recoil thrower i had, until i found out that an R2 in a P60 host with and aspheric (plano convex) lens, all inexpensive, and all from dx and b.o.b. out-threw it. i still like them for the novel concept, but i found out lens-based throwers are better. so, i agree.
Budgeteer
Budgeteer's picture
This is often the case. For males there is a saying... The older, the more will toys get expensive or require more batteries...
Aleister
Aleister's picture
So true Laughing
Kokopelli
Kokopelli's picture
Always had toys, always will Smile
Anyway, I guess I'll try the aspherical lens solution instead. Lightake has some good looking lenses for 44mm-52mm range. I wonder how would an XM-L light throw with a lens.
Don
Don's picture
Last seen: 1 year 2 days ago
Aleister wrote:
So true Laughing
Absolutely!
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
