TrustFire TR-J12, $54-Shipped, Aliexpress
76 posts / 0 new
kramer5150
kramer5150's picture
Just in this morning, REALLY fast delivery from across the Pacific.  Order placed on 5/15.  Delivered on 5/26, with great communication all along.
TAILCAP CURRENT DRAW, (Battery Space, 3.6Ah LiNiCoMn)
8.4Vin => Lo=.44A, Med=2A, Hi=3.4A (1.05 hour run-time)
12.6Vin => Lo=.37A, Med=1.27A, Hi=1.97A (1.82 hour run-time)
PWM on LO-MED=122Hz
Just some pics for now, 8.4V configuration... enjoy!!
Really nice kit overall.  With extra gaskets, instructions, extension tube and 18650 spacers... even a TrustFire warranty card.
Tactical logo, excellent knurl, battery tube is a little thin walled but nothing to get alarmed about.
Heatsink head, thermal warning.  REALLY tight/snug fitting O-ring between the trim bezel and heatsink.  I added a bunch of grease here.
Business end.  I removed the reflector and cleaned up a little dust on the back side of the window.  REALLY tight fitting O-ring infront of the glass, I think the bezel end of this light could very easily keep out water.
Tailcap and switch boot.  Will tailstand on a horizontal flat surface.
Switch pill area and -B brass plunger, with some extra grease I added to the gasket area.
Nicely machined tailcap end, with some extra O-ring grease.  Nice snug fitting gasket.  I think this area of the light could be water-resistant.
TF Logo.  Nice typeII anodize.
Heres the +B end of the battery tube.  Nice machined threads.
Engine compartment.  Easily accepts flat topped cells.
This gasket needs to be replaced.  It serves no purpose, it is completely under-sized and will allow water to pass.
One for throw the other for flood.  The J12 bezel is a little smaller than the HD2010.
EDC for the LARGE statured man.
Edited by: kramer5150 on 08/23/2012 - 16:11
Richie086
Richie086's picture
Last seen: 1 hour 45 min ago
Can't wait to hear the details and beam shots of this light.  Looks like the ones from Lightmalls are not true Trustfire's.
Richie
bose301s
bose301s's picture
Looks genuine to me, makes me happy because I ordered one too.
kramer5150
I wish I could take beamshots.... I'll try tonight (I know I've said that before).
Yeah that other member got a fake TR-J18 in the other thread.  This J12 from aliexpress DEFINITELY is legit (er at least it looks and performs/behaves like others are reporting).  This one definitely has rounded smooth contours on the body tube and I am getting similar tailcap current readings as others.
Shopbot
Shopbot's picture
Last seen: 6 years 9 months ago
hey kramer. Nice close up pics you have there.
I can say it looks identical to the one I got from DX for $70!! awhile back.
For $54, you picked up a deal there!!
Richie086
Richie086's picture
Thanks Kramer for the heads up on this retailer.   Glad to hear you got a good one.
Richie
kramer5150
Just a little update... Ran the light for 25-30 minutes straight, it definitely gets very warm but not alarmingly hot.  Checked the 26650 cells and V dropped to 3.85V, Tailcap current draw increased to ~3.56A (up from 3.4A).  So the regulation circuit is doing what its supposed to... although I was kind of expecting current draw to increase more rapidly than that.  But then again, 3.85V is still a good deal greater than nominal 3.6V.
kramer5150
During these thermal-runs and current tests the light started to get moisture condensation on the back side of the lens.  At this point it was hot to the touch.  So I dis-assembled it further...
Engine + dry threads and gasket.  I ended up smearing a bunch of AS-5 on these threads to help aid heat transfer.
Heres the screws that attach the reflector and sandwich the LEDs.
Another view of the engine.  Why do they scrape off the component ID numbers?  The only other place I have seen this is high-end custom audio DIY, where the circuit designer wants to hide the ID of the components used to help deter other DIY builders from copying the circuit.
Nice tight fitting O-ring... This junction should be water-tight.  Shown before the AS-5.
I let it run open like this for ~7-8 more minutes and get really hot, too hot to comfortably hold in my hand.  Hopefully this allowed the trapped moisture to vent.  One things for sure, this light generates a lot of heat... a good percentage of which needs to conduct through the entire heatsink area, and a small amount into the battery tube.
All dried out.  I buttoned it back up, with arctic silver-5 on the threads.  It has the consistency of white toothpaste, mixed with pine tree sap, and add some asphalt-tar for color... YUK!! Its a royal pain to clean up.  It took 5 minutes to apply, ~45 minutes to try and mop up.
After all these HOT runs I checked Vbatt and the cells 'finally' dropped to Vnom=3.6V.  I checked tailcap current at that point and measured 3.95-4A (fluctuated a little depending on how much pressure I pressed on the probes).  It looks like the driver is pulling more current as Vin drops, as expected.
So in summary, the $54 J12 lights form aliexpress are legit... no clones, fakes from this seller.  At this price its a really good deal if you are looking for a fat flood-beam from 26650 cells.
What I find most surprising is the performance of the 26650 cells.  Even with a ~3.5-4A draw, they seem to spend a LOT of discharge time ABOVE V-nominal  (3.6V).  Unlike even the best 18650 cells, which drop from 4.2 => 3.6 much faster.
kramer5150
Hmmm something isn't right.
Why are my cells rattling like crazy inside?  the light now flickers from intermittent battery contact.
whoa... what happened to the +B plunger?  and whats that smell!!? (before and after pics)
Hmmm cells look like they sit farther down now: (before and after)
TOAST!!  Poor little spring just can't hang.  Melted and smashed.  Time to go get some copper braid, and get current flowing properly.
bose301s
bose301s's picture
Noooo! Hope that doesn't happen with mine.
Pulsar13
Pulsar13's picture
Last seen: 11 months 1 week ago
Hold any more tests, annealed spring in my experience is normally a sure tell of a short somewhere. Those silvers you put could have dropped inside and doing the nasties.
Best bet if you would take a peek inside again.
kramer5150
It very well could, especially if you are using low resistance 26650 cells.  Its pumping a LOT of power+current through some very thin wire springs. It has a good heatsink design that can dissipate a lot of heat for long ON cycles.  So clearly the springs are under-designed for this application.  I didn't take pics of my tailcap spring but it too was rainbow + silver colored from heat.  That pretty gold plating just gets smoked.
I'm off to frys to get some copper braid....
Richie086
Richie086's picture
Thanks for the great photos showing inside the light.  Very unfortunate the spring got so hot.  I'm debating whether to purchase this one from AliExpress or take a shot in the dark on the UniqueFire UF-S7.  I'm going to decide by Monday morning on one of them.
Hope you can get your light fixed and all works out for you.
Richie
kramer5150
Just got back from Frys with some copper braid.  Wrapped some through each spring.  I'm not going to bother testing it, as I already am certain it will work and sufficient current will divert from the spring and through the copper wire.  It kind of brought back memories of my Mag-incan days.
Ready to rumble!!
benckie
benckie's picture
Last seen: 8 years 6 months ago
I brought mine from Manafont but payed a lot more, now the difference is $17.80 usd more to yours, i did not have a moisture problem with long runs or the spring problem or discoloration.
My driver base is different to yours mine is flat with no nylon ring and just uses a spring direct to the battery. I am also pulling a lot more current then your's and still have not melted the spring, but i did break off the tip of the spring, but the torch runs fine still.
Ive never had any flickering or any bad smells or driver or tail cap plunger discoloration any moisture problems and Ive had mine a lot longer then yours....
I believe 1.97 to 3.4 amps should not cause these problems as Ive drawn more amps then that through similar springs with out discoloration of parts or melting any thing and 3.4 amps is only approx 0.4 to 0.6 amps more then the TR-3T6 on 2 x 18650's that ive run a hell of a lot.
kramer5150
It funny because this light reminds me so much of the MAG-ROP (2x26650) that it replaces.  I have had that light for ~3+ years, and use it every now and then. But those ROP lamps will vent some strange foul smelling vapor/liquid, so you have to burn the PR lamp in by running it for ~15-20 minutes straight with the window glass off.  I also had to add copper braid wire to the tailcap spring on those ROP builds... just like this J12.  It took a little effort but I think I got it dialed in now.  I am a little bummed about my springs melting, I hope others don't have this problem too.
I hope mine lasts as long as yours benkie, its a great light so far.  I was doing some ceiling bounce comparisons and LO mode is a really nice floody, cool running ~250 Lumens.  Perfect for around the house tasks.
Yeah your driver setup looks completely different than mine.  I found your old pics from a few months ago...
http://budgetlightforum.com/node/6597#comment-116214
Mine has a brass retainer that clamps the driver board in place.
Manny
Manny's picture
Last seen: 3 years 2 months ago
After all that water proofing let's see some underwater beam shots ..... he he
Nice light This is my next light ........
benckie
benckie's picture
Yep thats our old kitchen table.
E1320
E1320's picture
Last seen: 8 months 1 day ago
You need to get some of these heavy duty springs for the tail cap. I have a couple extra if you want I can send you one.
http://www.cnqualitygoods.com/goods.php?id=1442
They are very difficult to solder because they are coil is so thick, you need to get them really hot for the solder to stick. Don't mind the lame braid attempt I was just demonstrating the technique for another thread.
I am already visualizing the duct tape over your mouth.
kramer5150
Thanks for the offer Eric... I think I am good though with the copper braid.  I just wove it around the spring coils and stuffed a wad of it inside the spring.
Switch spring:
I also played around with some old exhausted sanyo 18650 cells that were ready for the recycle bin.  These tired cells measured ~1000Ah capacity.  I ran them down to ~3V, where the tailcap current draw peaked at ~6.8A, and then rapidly dropped from there.  So I think this sample J12 falls a little short of the 7.5A claim, but its better for the well-being of the cell at that point in its discharge.
RedForest UK
RedForest UK's picture
Last seen: 1 year 11 months ago
The claim is 7.5A current output across the LEDs.
So with 8.4v x 3.4A in, and assuming 3.2A vf and 85% driver efficiency, that comes out at around 7.8A output. Just above the rated amount.
I wouldn't worry about it.
Shopbot
Shopbot's picture
hey guys,
I was doing a runtime test on my one with 3 partly charged Panasonic NCR18650A 3100mAh protected batteries.
It went for 1hr then all of the sudden the flashlight turned itself off (there wasn't any noticeable dim during the hour btw).
I thought the J12 meant to change to lower modes first before shutting down completely? Is this correct?
When I checked the batteries, they were around 3.05V left in them.
I thought these batteries can go down to 2.5V before the protection kicks in and also thought the J12 can run well below 3V as well.
Hmmm, what is going on...
Hikelite
Last seen: 7 months 4 days ago
Shopbot wrote:
hey guys,
This is not related to your particular case with the J12, but:
Just keep in minds that voltage on load is always lower and it's current dependent. A large current will cause a bigger drop on load vs off load measurement. But then your NCR18650A might simply have a 2.75V cut-off not 2.5V. What brand are they?
Shopbot
Shopbot's picture
These ones:
http://www.intl-outdoor.com/panasonic-ncr18650a-3100mah-protected-batteryone-p-333.html
Damn. Kinda confused on off vs on load voltage..
Hikelite
These ones:
Those can for sure go down to 2.5V, maybe even 2.4V
Off vs On load:
I am not familiar with how the J12 when it cuts and so, but as a rule what a driver sees is the voltage on load, the higher the current the stronger it affects the voltage. Once you take the cells out and measure  the voltage, the battery is off load, thus the voltage is higher than when it is powering something.
Hikelite
Shopbot, the protection on the batteries has not cut any power, if that would be so then you could not have measure any voltage but 0.0V.
kramer5150
Shopbot wrote:
hey guys,
After reading this I took some depleted Sony 18650 cells and ran two them down in my J12.  These cells were depleted previously down to 3V in a capacity test, and deemed too little capacity to be any use.  But they're suitable for tests like this when I want to see how a light behaves when the cells run down.  The cells had rebounded back to 3.8V.
I ran the light tailstanding for a few minutes, enough to get the head very warm.  Took a tailcap current measurement and the boost circuit was pulling 5.5A.  I noticed the cells were VERY hot at this time.  Too hot to comfortably hold in my hands, so I stopped the test here (fearing some kind of melt-down) measured the cells and they rebounded back to 3.5V each.
Paused here and let everything cool down for 20 minutes.
Ran the test again.  Cells started out at 3.5V each.  Re-loaded them and ran them in HI for 4-5 minutes (as I type this), long enough to get the light warmed up again.  Measured current draw, and it was still pulling 5A, down a little ~.5A from before.  The cells were once again very HOT, measured cell voltage and it had dropped to 3.3V.  So things seem to slowly be dropping, as the cells deplete.
Paused here and let everything cool down again.
Ran the test again.  Cells started at 3.35V.  Only this time (knowing the cells will be completely depleted) I ran the test without the tailcap, passing current straight through my Fluke meter.  Current topped of at 7.2A for a brief moment (maybe 10 seconds) and started to drop rapidly down to ~1.75-2A.  Went over to the wall and confirmed HI output had dropped to MED, so the circuit was doing what its supposed to.  Truncating the HI mode.  The other thing I noticed was mode switching began to "flicker" a little between modes as I flipped.  It wasn't a crisp HI-MED-LO cut.  Pulled the cells and they measured 2.85V each, and they rebounded back to 3.25V after a 3-4 minute rest.
I Re-loaded the cells and ran the light again.  At this point its clear the circuit is dropping both HI and MED output down to a lower mode, maybe a little brighter than LO.  At no point did the light output cut off completely.  I stopped testing here, bad/dangerous/explosive things can happen running Lithium cells  depleted this far.
BLF'er benkie and a couple others have been very vocal about the existence of fake Trustfire TRJ-12 and J18 lights... and from reading others comments and reports that appears to be a very likely scenario.  Personally I think it goes deeper than that... I think it has to do with the driver board supplier, and their ability (or lack thee-of) to manufacture the same DC-DC circuit form batch to batch.  I have always wondered why they take the extra time to scratch off the component ID and BIN numbers from the SMT components.  After reading threads like this HERE , I personally believe the driver board manufacturers are stuffing the circuit boards with whatever components they can get their hands on.  They may not always be 100% compatible or identically capable.  By the time you add together the cumulative sum of inter-mixed parts on each board, you end up with the variation we are seeing across the population.
Anyhow...  I think this particular J12 from the aliexpress $54 batch is a good one.  Just be careful with unprotected cells, and don't run them all the way down. Watch out for HOT cells, HI mode dimming down to MED, and a slight "flicker" between modes, these are all signs the cells are fully depleted.
Hikelite
The fake mentality is a bit exaggerated, sometimes they simply have another batch with another driver (or bad batch) coupled with some low QC on the machining.  Or they have chosen to sell the best then slowly offer the ones that are not that good.
As for that DX driver, the client is let known from the title, photos and description that is not clear what he will receive.
I have many Nanjg drivers, (eg.7135x3, more options than the DX one) and all are perfect and all use the same components.
I would agree, that on some drivers manufacturers are stuffing what they can find.
Shopbot
Shopbot's picture
Hey guys, I appreciate your inputs. I'm understanding things a bit better now cause of it.
The reason why my J12 suddenly shut down was because one of the batteries protection circuit kicked in. I did measure it at 0.00v and didn't think much of it at the time and thought it was my cheap DMM playing up so I placed it in my hobby charger in calibration mode to see the volt and now both the charger and DMM shows it at 3.05v. Prior to this, I did not know that once the protection circuit is activated, the battery will show 0v. Now I know (post #25).
So what happened was, during my runtime test, I guess there was high current flowing (high mode) thus the voltage decreased under load (as Hikelite explained) to a point where it hit 2.5v and therefore activating the protection circuit and shutdown the J12 immediately. During off load, I measured the one battery at 0v then 3.05v (as explained above). So under load vs off load, there was a difference of about 0.55v.
So now all my batteries are still > 3.00v.
So what that is happening with my J12 is that the battery protection kicks in BEFORE it has a chance to change to the lower modes (as with kramer's one). Hmmm, why is that?
I have also tested the batteries (cooled) now and it shows 3.15v compared to yesterday when the batteries were warm at 3.05v. A 0.1v gain overnight. Is this normal?
Thanks again for your inputs.
benckie
benckie's picture
Batteries climb back up in voltage after the load has stopped the longer the rest the more they climb.
Shopbot
Shopbot's picture
Thanks benckie. Oh yeah I see now, Kramers batteries also increased (posted #26)
Just one thing now, my damn J12 won't change down to lower modes using 18650.
Prior to receiving the 18650 batteries, I did use AA batteries and it did change down modes and flicker as well.
Not the case with the 18650's though (for my 1 test at least). Would be scary using unprotected batteries..
