Test / Review: RediLast 2600mAh (Black)
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 5 days ago
DSC_0461
Official specifications:
  • 2600mAh Capacity
  • Protected against: overcharge, overdischarge, short circuit
  • Cell Made in Japan
  • 4.20v±0.05 charge voltage
  • 2.75v cut off voltage
  • 3.7v Nominal voltage
  • Charging type: CC/CV
  • Max charge current: 1C (2.6A)
  • Recommended charge current .5C
  • Max discharge current: 5.2A
  • Cell Size: ~18.5mm x 68.5mm
RediLast%202600mAh%20(Black)-info
DSC_0448 DSC_0460
DSC_0464 DSC_0465
DSC_0462
DSC_0463
RediLast%202600mAh%20(Black)-Capacity
This battery has a high voltage at low loads.
RediLast%202600mAh%20(Black)-CapacityTimeHours
RediLast%202600mAh%20(Black)-Energy
RediLast%202600mAh%20(Black)-PowerLoadTime
RediLast%202600mAh%20(Black)-TripCurrent
RediLast%202600mAh%20(Black)-Charge
Conclusion
The high voltage at low loads can be an advantage in smaller (i.e. 3-4 watt) lights where the battery replaces two CR123 cells.
All in all a very good battery.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
fishinfool
fishinfool's picture
Last seen: 2 years 4 months ago
Thanks as always for the review HKJ!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
scaru
scaru's picture
Last seen: 4 years 11 months ago
Thanks for the review HKJ.
Rusty Joe
Rusty Joe's picture
Last seen: 1 hour 59 min ago
What I want to know is what is the best of the best of the best 18650s?
HKJ
HKJ's picture
For most applications it the the new Panasonic 3400 mAh cell (NCR18650B).
march.brown
Last seen: 5 years 7 months ago
What is wrong with the 3100mAh Panasonic ? … It’s only 300mAh lower in capacity and much cheaper than the 3400mAh Panasonic.
march.brown
HKJ
HKJ's picture
march.brown wrote:
What is wrong with the 3100mAh Panasonic ? ... It's only 300mAh lower in capacity and much cheaper than the 3400mAh Panasonic. .
Nothing, both the 2900mAh and 3100mAh Panasonic are very good cells, but the 3400mAh cell is slightly better, it has higher capacity and it also looks like it has a higher voltage under load.
But if you ask what battery is best for the money, it will be the 2900 or 3100 mAh cells.
march.brown
HKJ wrote:
march.brown wrote:
What is wrong with the 3100mAh Panasonic ? … It’s only 300mAh lower in capacity and much cheaper than the 3400mAh Panasonic. .
Great news because I’m standardising on the 3100mAh Panasonics and will be retiring the old Ultrafires as soon as I have enough of the Panasonics … Many Thanks for your input.
march.brown
Ecig
Last seen: 9 years 1 day ago
Is buyincoins reliable supplier of Panassonics? Wich site has best price for them?
march.brown
I bought my Panasonic 3100mAh cells from here … They send the cells by “International Signed For” … It takes about 10 to 14 days to South Wales … I’ve just sent for some more.
http://www.ebay.co.uk/itm/270860995573?ssPageName=STRK:MEWNX:IT&_trksid=...
march.brown
