Note: This is not a finished project and what is seen in the below post may not be up to date. The way I do my projects is make something functional and then continually improve it.
I am installing it in a 3d maglite modified to run off of 3 18650 batteries.
First remove the switch using a 5/64 hex wrench.
Note: not my picture. I forgot to take a picture.
Using a hacksaw cut along the blue line.
Here a picture of the rest of the switch is.
Re-install it in the maglite. Then realize you need to solder wires to it and heat up your soldering iron and solder some wire to it.
One wire gets soldered to the center and the other to the wire that is already there.
Now we need to modify it so 3 18650 batteries will fit.
First remove the tailcap and take out the spare bulb and the spring. You will not need these.
I then cut a piece of 1 inch pvc pipe to the correct length so it fits into the tube. Then wrap it with electrical tape until it is a tight fit in the tube.
Here all the parts are layed out. I will talk about the heatsink later.
Then you need two small springs. I got these at my local ace hardware. These are in the above picture. I then took a small magnet and attached it to the top battery on the negative end.
Edit: The magnet was replaced by solder on the negative terminal of the battery.
You also need to take a drill bit and remove the anodization on the inside of the tailcap. Screw down the tailcap and you are done.
For the heatsink I decided to attempt to make my own similar to how OL does it. I went to the hardware store to look for copper fittings. They had 2 that were fairly close but that was all. I got a length of aluminum rod.
First, I placed the first copper fitting in the other and then filled the gap with other fittings I chopped up and some solder. I then cut the aluminum to the right length and stuck them in there. I just filled all of the space with aluminum.
Edit: I filled all of the gaps in this with solder.
Edit: I followed kramers advice and made a second one out of copper fittings I cut up and solder.
Then place it into the maglite and fill the gap between the body and the heatsink with aluminum sheet.
Here the completed maglite is hooked up to my dmm to check that it works.
Now I just need the module and then I will install it. :)
To be continued...
