BLF Black spot
15 posts / 0 new
Elanzer
Last seen: 6 months 3 weeks ago
BLF Black spot
I received my Mr.Lite BLF a little while ago, it's a fairly impressive unit besides one thing: There's this big dark area in the middle of the beam. Anyone know what I can do to fix this?
FlashPilot
FlashPilot's picture
Last seen: 2 hours 24 min ago
Very strange. Carefully inspect the emitter, reflector and lens for any imperfections.
old4570
Last seen: 2 days 20 hours ago
Carefully , dis assemble ...  Have you got modified needle nosed pliers ?
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Elanzer
What do you mean by modified needle nosed pliers? I'm new to the flashlight biz, so I've never taken one of these apart before. Here's another picture to give a bit more of an idea of what the beam does.. when I put my finger over the beam the shadow gets sucked into the hole. Would this mean the lense has an imperfection?
Elanzer
I took it apart and found an imperfection on the bubble lense ontop of the emitter, so I polished it a bit with a fiber cloth (no liquid or anything) and seemingly got it removed. Then I put it back together, and the beam won't fire at all anymore.
old4570
You have lost contact ...
The pill needs , to make contact with the battery tube ...
First try swapping the battery tube around [ middle part of flashlight ]
If this does not work , you may need to solder the neg [ - ] board on the driver [ blob ] so that the body will screw onto the solder to complete the circuit .
Im sure I posted a picture somewhere .
old4570
http://www.imagebam.com/image/249a08107563793   Picture of what I mean [ solder ]
Elanzer
Ahh, that bit of solder did the trick. Now after the polishing the issue went away with the black hole, now it's a very clean beam. Thanks guys!
FlashPilot
Old4570 = Super Guru. Way to go Old!
old4570
Happy to be of help ....
fishinfool
fishinfool's picture
Last seen: 2 years 1 month ago
Question:  When the pill is nice and snug/tight, there's no light but when I loosen it a bit (to where it actually rattles), it works just fine.  Why is that?
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Don
Don's picture
Last seen: 10 months 3 weeks ago
Length of the battery tube. Some of them are too long and some of them a little short. Put a conductive spacer at the back of the battery to take up the excess length. Then you can tighten up the pill. Don't tighten it too hard or you can dedome the LED. Been there, broken that.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
fishinfool
Thanks Don.  I love your, "Been there, broken that."  Big Smile
Budgeteer
Budgeteer's picture
Last seen: 7 years 11 months ago
Mine worked perfectly out of the box... err... padded enevelope. There were a few who got it faulty tho. Maybe those were rushed a bit to comply with the demand.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Oldienea
Oldienea's picture
Last seen: 6 years 4 months ago
with one of my BLF lights after I disassemled the tail cap. The switch is very small and has a lot of free space around. That's why it was off center when I reassemled it (result is no contact to the housing). It's actually quite tricky to get that right again, once you put it back together. I used a disc with a hole, cut out of a piece of cardboard, which I put on the shoulder of the switch as a guide. That worked fine for me.
