Review: NANJG 105A 2800mA driver
193 posts / 0 new
Don
Don's picture
Last seen: 11 months 6 days ago
We need someone to forward orders in the Channel Islands which are sort of a part of the UK and sort of not. One thing they don't do is VAT.
I believe the Canary Islands have a similar status in Spain.
But the Channel Islands count as part of the EU for Customs purposes.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Budgeteer
Budgeteer's picture
Last seen: 7 years 12 months ago
I'm in for the international flashlight smuggling operation. Smile
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Nautic
Nautic's picture
Last seen: 2 years 3 months ago
Maybe you could be the european importer of lights as in Slovenia all valued under
22€ is free from import dues. Could be that its cheaper to pay you for postage to
me, rather than import direct and pay some hefty dues here.
Cheap quality is good - Expensive crap isn´t
FlashPilot
FlashPilot's picture
Last seen: 1 hour 21 min ago
Nautic wrote:
FlashPilot wrote:
Nautic wrote:
Installed in the light I measured 2.4 amps
Looks like a good driver. Was that measured at the LED or tailcap?
I measured it by connecting the possive to the +spring up through the light
and the negative to the threads at the tailcapend of the tube.
I have now tried to put the + to the +spring as last time, but now put the negative
to the spring in the tailcap and this to the threads on the tube. Now I measure 2.2 amps.
A small loss in the switch apparently.
Thanks for checking! Smile
Budgeteer
Budgeteer's picture
Ocassionally i can do. Regularly hell no. Our regulations have us make a statement that is for personal use. I'm being a tax evader if i just gift it to someone. Yep. I cannot even help paint heighbour's fence without risking to be fined.
From Slovenia to Germany 0,7Kg parcel with tracking number 12,90€ and that was with a discount, owning a business package deal with postal service... I doub't it is worth it. Also my customs are very strict for fakes, phones, and all household voltage device requiring perfect CE certification.
Nautic
Nautic's picture
Dont be nervous Budgeteer, I was only joking. I know too well the high postalprices her in EU
Nautic
Nautic's picture
Just got this driver from KD.    (ordered the 17th and arrived today. They get faster and faster!)
On it is printed 105C not A as shown elsewhere. Dont know of its an approvement or not.
Driving a XM-L led it draws 2.8 amps on high, 0.8 on mid and 0.1 on low.
brted
brted's picture
Does the big chip say ATMEL on it?
Nautic
Nautic's picture
There is nothing printed at all on the big microchip.
Nautic
Nautic's picture
Hi again brted
I check it again with a better light and a magnifying glass.
On it is printed:
Atmel 1017
TINT 13A
brted
brted's picture
It can be hard to see without a magnifying lens and getting the light just right. Thanks for double checking. The ATMEL chip can be programmed with an AVR setup, but the blank chips can not.
Nautic
Nautic's picture
Yes, and my eyes are not what they where years ago!
Thanks for info. I dont program though, but Im very satied
with the modes as they are.
Does the C means something? Used to be 105A.
brted
brted's picture
I think they are using it to identify different versions of the driver. The pictures on KD show a 105 and it has 2 little resistors soldered on the bottom of the board. But the 105A picture above shows a capacitor on the bottom. So they are tweaking the design, but I'm not sure why.
Nautic
Nautic's picture
I asked as I thought you maybe knew the difference between the various versions.
Mine has a single capasitor at the bottom.
sixty545
Nautic wrote:
Hi again brted
On it is printed:
Atmel 1017
TINT 13A
Because you got the Atmel kind, I just ordered 3. The last time I ordered I got the PIC type but I have hopes that the PIC era is over now.
Nautic
Nautic's picture
Glad I can help you sixty545. I myself are thinking of ordering a few more to
swap with some of my other drivers which dont deliver so much punch like
this one.
pounder
pounder's picture
Last seen: 7 months 4 days ago
so I orderd this driver for my xml drop-in..what about the positive contact spring? is it long enough for the p60 module to make contact? or do I solder on another spring..the contact patch isn't large enough for the tupical p60 spring..confused...
Budgeteer
Budgeteer's picture
It is possible by fiddling to have the driver do this (mode 2):
Hi 2450mA (kill an amc)
Med 1200mA
low 100mA
I bet not but it does not hurt to ask right?
Nautic
Nautic's picture
I had to solder a lengh of copperwire on the end of the spring to make contakt. No big deal as you are to solder anyway.
Works fine now in all my lights.
pounder
pounder's picture
Do you happen to have a picture of the mod with copper wire?? I'm just trying to grasp what was actually done..thanks
Sparktastic
Last seen: 10 years 2 weeks ago
Does anyone know if the diode is in series with the 7135's as well as the MCU?
Am just wondering if the diode drops the voltage to the emitter, or whether it is just in series with the MCU to protect it.
Thanks.
Nautic
Nautic's picture
I just took a small piece of thick cobberwire. Bented it, so it formed a loop. I then
put the 2 ends into the spring and soldered them to it. The loop now protutes from the
spring about 5 mm.
sixty545
Thanks.
The last is true. Only the MCU.
Sparktastic
Thanks for confirming this.
pipopopo
Last seen: 7 months 2 days ago
I  have just installed a 105A in a XM-L T5 light
I get 2.5A tailcap (got about 3 A with same batt in direct drive)
Any ideas on how to squeeze the last 0.3 A out of the driver? (bypasing the diode?)
and does the driver self needs additional cooling?
btw. I like the memory function with blink confirmation
fran82
Last seen: 9 months 3 weeks ago
Probably you have bad multimeter
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
brted
brted's picture
What is "blink confirmation"?
The linear regulators are pretty accurate in letting exactly 2800mAh through as long as the battery can deliver 2800mAh and there are not bad connections or undersized leads to the LED. I'd suspect the multimeter leads too, partly because 3A seems low for direct drive of an XM-L. Other people have been getting more like 4A, but it really depends on the battery.
fran82
This driver produces a "Blink" to confirm that memory has engaged
Nautic
Nautic's picture
I have just got the 105C 5-mode version and it does not have the "blink".
boffid
Last seen: 6 years 7 months ago
With a slightly bad connection my multimeter reads 2.5A as well. The max I was able to get (with x-l) is 2.64A. I guess there is some variation on the current the 7135s provide. However, I doubt I'll notice the difference in 2.8A and 2.6A by eye.
