Test / Review: AmpMax 18650 3100mAh (Black)
8 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 5 hours ago
DSC_2166
Official specifications:
  • Original Panasonic cell from Japan
  • Built-in protection circuit, guards against - Over-charge, Over-discharge and Over-current
  • Triple MOS's for superior high current discharge
  • Improved voltage stability due to low internal resistance
  • PET sheath, environmentally friendly and not easy to crack
  • Steel flat button design
  • Voltage: 3.7V (4.2V when fully charged)
  • Capacity: 3100mAh (discharged at 0.2C)
  • Dimensions:18 mm x 68.5 mm (+/-0.3 mm)
  • Current over-flow protection: 5A+
  • Weight: 48g
AmpMax%2018650%203100mAh%20(Black)-info
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
DSC_2165
DSC_2167 DSC_2168
DSC_2170
DSC_2171
AmpMax%2018650%203100mAh%20(Black)-Capacity
AmpMax%2018650%203100mAh%20(Black)-CapacityTimeHours
AmpMax%2018650%203100mAh%20(Black)-Energy
AmpMax%2018650%203100mAh%20(Black)-PowerLoadTime
AmpMax%2018650%203100mAh%20(Black)-TripCurrent
AmpMax%2018650%203100mAh%20(Black)-Charge
Conclusion
This battery uses a good cell, this secures many things:
  • The batteries does match in capacity, i.e. they can be used in series.
  • The battery is very safe.
  • The battery has the specified capacity.
There is not anything to say about this battery except it is a very good battery.
Notes and links
The batteries was supplied by AmpMax for review.
Edited by: sb56637 on 08/26/2014 - 17:45
fishinfool
fishinfool's picture
Last seen: 2 years 5 months ago
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
turboBB
Thx HKJ!
sb56637
sb56637's picture
Last seen: 3 hours 33 min ago
Thanks very much! Frontpage’d and Sticky’d.
ChangchungLeds
ChangchungLeds's picture
Last seen: 4 months 1 hour ago
Thanks a lot, again…
BTW, where can we buy it? How much?
Thanks again…
Zebralight Spark Princeton Inova Petzl Maglite Bushnell a lot of Cree XM-L Lights 18650's Intl-outdoor 3400 Panasonic 3100 Hobby Charger
HKJ
HKJ's picture
ChangchungLeds wrote:
Thanks a lot, again... BTW, where can we buy it? How much? Thanks again...
You can find the AmpMax website here: www.ampmaxworld.com, but they do not have any shop on it.
ChangchungLeds
Thanks a lot, again… BTW, where can we buy it? How much? Thanks again…
Thanks sir, I just send a mail…
Suncoaster
Suncoaster's picture
Last seen: 1 day 14 hours ago
Location: Where the girls are green and the grass is pretty.
Found these on Ebay.
Expensive: $39.90 for 2
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
