6 Xm-l light bar build
198 posts / 0 new
nofearek9
nofearek9's picture
Last seen: 1 week 6 days ago
thanks.
this is my actual car Smile
ek9 is the chassis code for the car. (honda civic type R 1997-2000)
Rufusbduck
Rufusbduck's picture
Looks like a Troutie got bit by a radioactive spider. Nice board. Nice housing. Also make a good back up light for say, the Space Shuttle.
Scott
Bigtoy302
Bigtoy302's picture
Last seen: 1 year 6 months ago
Vieplis wrote:
You should measure the temperature of a LED. I guess it is rather high. What kind of PCB?
.031 FR4 with tons of vias under the leds. I have hit the board and leds with my infrared gun and they measured 70c, this is where thermal rollback is. This was with no air flow. Housing temp is barely over ambient when traveling 50+ mph.
Yellowhorse
Yellowhorse's picture
Last seen: 7 years 2 months ago
Sweet! I would be interested in one. Probably need to machine a groove in the housing to solve your o-ring/gasket issue.
amraspalantir
Last seen: 1 year 1 month ago
Great build Bigtoy! Hope you could deliver to Philippines once its available.
Can your setup support dimming via potentiometer ? exploring possibility of having a High and Low setting so we can have low for non off-road use and high for off-road sorties.
W30,K70,sc600w, Aspheric DBS V3, Sanmak 5500 HID,Costco HID, TK-40 and my reliable FJ-40.
Bigtoy302
Bigtoy302's picture
There is a groove in the housing. It is the lens cover that is flexing between the bolt holes.
No pot. Light can be programmed for up to 16 modes. The light has low,med,high now.
Yellowhorse
I missed the fact that there was already a groove for the 0-ring. DUH. 4 more screws in the ‘corners’ would certainly help but have you given any thought to just using a thicker piece of lexan/plexiglass or whatever it is you are using for a lens? Just a thought.
Bigtoy302
Bigtoy302's picture
It is the aluminum cover that is flexing not the lens. Adding more screws will fix it.
Yellowhorse
Gotcha. Really nice work. I want one to light up my workbench. Yeah, I know. Sounds a little crazy but…………
WastedNihilist
WastedNihilist's picture
Last seen: 4 months 6 days ago
Very nice work. Too bad they’re a little out of my price range. I’ll have to stick with cheap hid’s in cheap housings until I can afford a nice LED light bar like that.
wquiles
Last seen: 5 years 7 months ago
Man, great project. That unit looks both serious and professional – nice board by PilotPTK Smile
Will
Custom machining and electronics - www.atdms.com  Email: wquiles (at) gmail [dot] com
Rockspider
Rockspider's picture
A beamshot with the two outer elliptics now would be nice, curious to see how much better side lighting you have now!
Do you have an idea on availability date? weeks, months, years… Silly
Also, any chance the final product will have a lower price tag?
Bigtoy302
Bigtoy302's picture
I will get some beamshots tomorrow night.
I am hoping to have lights ready by the end of the year. I want to test his one some more and finalize the wiring.
Pricing will not change unless you want to buy in bulk.
trooplewis
trooplewis's picture
Last seen: 3 years 1 week ago
Great idea and awesome craftsmanship on the unit.
If you have the time, you might also want to experiment with a 5-unit design where the middle three emitters have larger reflectors (say 55-57mm) and the ones on each side have smaller reflectors and are angled out a few degrees. That will greatly enhance the throw down the center, as well as the flood off to the sides.
Also, when you do the beamshots, try a couple different shutter speeds, say from 2 sec to 6 seconds, I bet it will give you a better depiction of the beam.
Best application I have seen of XM-L technology outside the flashlight world.
Oh, almost forgot. You mentioned the optics being 26.5mm narrow; looks like they use aspherics. Have you tried it without the aspherics?
Rats, finally sold my 2010 509hp Mustang...now I can buy more lights!
Sold the red one too! Now guess what I drive, doing my penance for 500 hp commuters...
http://dreammustang.com/
http://i884.photobucket.com/albums/ac47/Ha
Bigtoy302
Bigtoy302's picture
The board is one piece, so angling the side ones is not possible. The elliptcals give plenty of light to the side.
Leds are in strings of 3, so 5 is not logical. I am trying to make the light small, I do not want to use any larger optics.
The optics I am using are not aspherics.
Pics are F4.5, ISO 100, 6 seconds on a tripod. Canon T3i.
gords1001
gords1001's picture
Last seen: 4 years 3 months ago
I’m thinking one of those would be an awesome compliment to a safari rack on my landcruiser, no bashing lights on low branches when green laning 8)
Bigtoy302
Bigtoy302's picture
Beam shots with outer two optics swapped out for ellipticals.
Rockspider
Looks like a perfect mix of hotspot and spill now, very good! :bigsmile:
Would you say the exposure of the picture reflect the same amount of light your eyes were perceiving? If so that’s really a great offroad light for sure, the wait will be worth!
In the picture, was it still mounted on top of your DR Suzuki? I may be wrong, but light seems to be aimed slightly downward, and maybe it could result a bit more throw if aimed a little higher, don’t you?
Volk
Volk's picture
Such an impressive build. One of those would fit perfect in the front of my car, that’s for sure.
Bigtoy302
Bigtoy302's picture
Would you say the exposure of the picture reflect the same amount of light your eyes were perceiving? If so that’s really a great offroad light for sure, the wait will be worth! In the picture, was it still mounted on top of your DR Suzuki? I may be wrong, but light seems to be aimed slightly downward, and maybe it could result a bit more throw if aimed a little higher, don’t you?
The pictures are very close to what you actualy see.
Yes, these pics are taken with the light on the DRZ. I do have the light aimed down. Aiming it up did not gain any throw. It just took away the light righ inf ront of you.
fishinfool
fishinfool's picture
Last seen: 3 years 2 months ago
Wow, that's friggin' amazing!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Rockspider
Ok, understand what you mean. There would be some personal preference in choosing aiming, depending on terrain and use. Now hurry up and finish them, you have customers waiting! :bigsmile:
WalterK
Last seen: 3 years 5 months ago
Very nice!
Will it run on 24V as well?
My mods in my flickr sets
Bigtoy302
Bigtoy302's picture
WalterK wrote:
Very nice!
9-24v input.
Bigtoy302
Bigtoy302's picture
Circuit boards are in hand, leds and components are ordered. I am hoping to have these ready in 4-6 weeks.
tkmckay
Last seen: 2 days 1 hour ago
I’m thinking the same thing, one should fit perfectly into the centre opening of my bumper!
Bigtoy302
Bigtoy302's picture
Aluminum, boards and components. I drove them up to the assemblers Yesterday. I should have them back in a week. Time to start machining on the housings.
Jinx
Jinx's picture
Last seen: 2 weeks 5 days ago
Looking good, did you consider the U2 binned emitters?
Bigtoy302
Bigtoy302's picture
Nope. I will not go over 5000k for these. Any higher then that and it causes eye fatigue and no color rendering. Not good for fast driving. Maybe if they came out with a U2 neutral. I can get T6 neutrals, but they where not in stock and cost a lot more. With this much light you are probably not going to notice a few hundred lumens.
Jinx
Jinx's picture
Cool, I thought it maybe due to the tint but that also explains why not the T6. Looking forward to seeing more Smile
