need a 3000-4000 lumens torch.
i dont need a mid or low or strobe modes. i need a just one mode the high mode.
and not fixing on/off switch just like touch button.
any one can help?
something like
any one can help?
something like
Welcome to the madness, Big_White!
About those flashlight auctions you linked to...
The batteries (and chargers) look pretty bad. In fact, flashlight + battery + charger combos on eBay are almost always bad. I'll let the experts recommend a better flashlight, along with nice batteries and a charger.
dont have too much $$$ for now, in future i will buy better charger and batteries…
TNX.
You can get decent batteries and a charger pretty cheaply.
Cheapest 18650 batteries that I recommend:
TrustFire Protected Flames. I would buy from DinoDirect or Manafont.
http://www.dinodirect.com/TrustFire-Rechargeable-Li-ion-Battery-Protected-2400mAh-TF18650.html
Cheapest charger that I can recommend:
TrustFire TR-001. (These have a US plug format. What do you use in Israel?)
http://www.dinodirect.com/trustfire-tr-001-charger-multifunctional-ac100-240v.html?DDID=3520-616
By the way, do you know the dangers of using a flashlight that takes more than one li-ion battery? You will need a multimeter to frequently test the batteries.
in israel we use europe format.
i need that flashlight for a 10-15 minutes for week, i have a multimeter.
I prefer to buy everything in one package, and later upgrade the batteries and charger.
Here's the TrustFire TR-001 with europe format:
I don't know about getting everything in one package. I would be surprised if anyone could find a respectable (yet inexpensive) combo on eBay. Good luck in your search!
whitch of the models is Recommends for my uses?
TNX for the MANAFORT link’ the have few nice stainless steel lights:)
ME GUSTA
Welcome to BLF, Big_White!
None of the lights you listed provide you with your criteria. The closest I can think of for you is a Skyray King. Electronic switch on the side with only two modes plus a hidden strobe you never have to see if you don’t want to. It always starts on High, has fantastic heat sinking and a throws better than most multi-XML torches while giving excellent flood. It’s also jacket or cargo pocket friendly due to it’s short format (about the size of a soda can). I can’t recommend it enough!
it is a weapon light for airsoft. that why i need one mode
sky king is too big.
there is no moddification or way to convert the circut or some thing?
my current setup is UltraFire WF-501B with XM-L with modded switch fouch button.
and now i need a more lumens.
some model from that i linked always starts on High?
TNX.
Romisen RC-T602 might suit your needs. Great throw and pretty smal.
http://www.shiningbeam.com/servlet/the-69/****NEW****-Romisen-RC-dsh-T602-II/Detail.
Seen lots of good reviews about the HD2010 aswell.
750 is not enought, now i have a XML. and need more…
I play airsoft too. I have numerous G&P, G&G, KWA, and King Arms M4s. (I have spent way to much on airsoft)
I think it depends on whether you are playing woodland or CQB?
For woodland a 1-Mode C8 style light would be ideal because of its throw/flood combination.
For CQB I actually think a 1-Mode 501/502/504 with an XM-L would be a good light because of the flood and light weight.
I personally use a SolarForce L2 with a 1-Mode R5 and pressure switch mounted to a vertical fore grip.
The best light for airsoft in my opinion would be a 1-Mode XM-L U2 C8 pulling 2.5 amps and an OP reflector.
