New XM-L Light,, 26650/18650/4xAAA Good Price and 57mm head ......... NOTE: The star is solid aluminium !!! :bigsmile:
268 posts / 0 new
apt323
apt323's picture
Last seen: 1 month 4 weeks ago
Thanks Garry! I only get around 2 amps on any of my batteries and wanna pump it up. Have 26650’s on the way to see if that help I guess need to take the tail cap apart and do resistance checking to see if that helps. I did read that when i re-read the thread. Never done anything like that before.
Thanks again for your help.
cainn
There’s a ton of resistance in the switch, but the other thing you should do is replace the wiring between the driver and the star with some lower gauge stuff. My readings at the tail shot up over 3A (from around 2.2) after that mod alone. It seems common also for there to be some resistance at the contact point between the driver and the pill (especially if the driver is loose, and also if the screw in aluminium ring it sits in isn’t screwed in tight).
I’d be careful about removing too much resistance without also filling in the hollow pill though. It almost seems as if it’s constructed this way on purpose to prevent over heating (in other words, bad design as a feature).
apt323
apt323's picture
Thanks for the info. I replaced the wires when I filled the open hole. When you say lower guage do you mean thicker wire? Just rechecked my tailcap readings and my solar force blue and white protected pulls 2.7a on my hd2010 the pulled it out and put in this light and it pulls 1.8a granted that the the battery voltage was only 3.8v but it was the same for both lights. I also tightened the ring down earlier this week.
What kind of things can be done to the tailswitch? Also the light seems to flicker sometimes when turning it on. Think that it might have something to with the driver spring maybe.
cainn
Yes. Of course you did. I’d forgotten that it was you who detailed your efforts earlier in this thread. Please forgive my absent mindedness.
Yup.
I ran some copper tape from the part of the switch that springs out to contact the body up to the top of the switch, so the aluminium ring that screws down onto it makes contact with it as well. It seemed to improve things, but I think what I ultimately need to do is get an entirely new switch in there somehow. I’ve been meaning to take another look at it, but just haven’t gotten around to it yet.
apt323
apt323's picture
My middle name is absent mindedness so i definately understand. The wire was thicker also that i used after the build up. Have t ever really looked for a driver that size so may there is one out that fits my needs. After all that work on filling the pill up I would just like to see this thing screaming somewhere in the 3.5a+ range! See if it can try and compete with my HD2010 and hopefully wont lose the 4aaa feature to get there. Maybe it will help with the 26650’s that are one the way.
Thanks again and update here if u find a switch or just any general information that is good.
cainn
I just discovered that Solarforce inner switch sets fit into the tail on this light (with the exception of the boot). I used a different boot that I had laying around that is the same size as the original, but has a nipple inside it (the original doesn’t). I also used a round plastic spacer (reduced to the correct diameter) which happened to have just the right sized hole in the middle of it. The following pictures tell the story:
This has significantly improved total output. I can only measure it relatively using my Android phone running the beeCam lightmeter app during a ceiling bounce, but it’s a true story. Besides, it was visually noticeable anyway.
garrybunk
garrybunk's picture
Last seen: 3 days 23 hours ago
Thanks cainn! I'll have to order a couple of these! Can you measure resistance of the original switch and this one for comparison?
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
apt323
apt323's picture
Thanks for the info cainn. :bigsmile:
cainn
-Garry
To be perfectly honest, at this stage I don’t have much confidence in my ability to accurately measure resistance in something like a tail switch. What I did do was take some lux readings with the original switch and the Solarforce replacement. 152 with the former and 188 with the latter, averaged over 2 attempts. I started with the original switch, took a reading, swapped in the Solarforce switch, took a reading, swapped in the original again, took a reading and finally swapped in the Solarforce switch again, and took a reading. The difference was about the same each time, so the averages above are an accurate indicator of the difference (rather than just the average of 2 wildly different results). This was during a ceiling bounce, with the light tail standing in the exact same spot each time, about 2m from the ceiling.
garrybunk
garrybunk's picture
Any idea what diameter those solarforce switches are?  I'm wondering if I could just get a 5 pack of these Ultrafire's from Manafont (21.27mm in Manafont photo).  Then there's these Uniquefire's (20.56mm  in Manafont photo).  I have some of these basic switches, but they are kinda junky and are probably higher resistance than the other two options.  I would have sworn I'd seen some "Ultrafire High Current tail cap switches" at Manafont too, but I can't find them now.
Is there a reason for using the Solarforce switch?  Is it because of the retaining ring piece, or is that not needed?  I also don't have any other tail cap boots.
-Garry
chiefinspectorfinch
chiefinspectorfinch's picture
Last seen: 6 months 1 week ago
Location: Croatia, country with kleptomaniac clero-fascist government
Well I finally received custom pill and after some painstaking sanding and few “touches” with hammer this is final (almost :bigsmile: ) result.
Custom alu pill with opening for standard 17mm driver
I slightly miscalculated things so plunger on spring provides reliable contact with battery
Reliable negative contact is made with wire sandwiched between battery tube and pill part. Not pretty and elegant but it works reliably.
Holes for wires were bored at an angle
I still have to make some real world outside testing but so far things are looking promising Beer
Society is like a pot full of nuts and bolts, finest pieces always end up on the bottom...
apt323
apt323's picture
Looks nice chief
cainn
The Solarforce switch has a diameter of exactly 20mm, and measures about 24mm from the button to the tip of the spring. It’s the ideal size really because it’s only a touch shorter than the complete original setup. Using a switch that’s much shorter than that might result in decreased output due to exerting less pressure on the battery, although this could be overcome by soldering a bigger/longer spring to the driver (or even the switch itself for that matter). The retaining (screw-down) ring piece is important as you can’t use re-use the original because it would create a short between the spring and the body (making for an always-on flashlight). You could try to insulate it somehow, but it also has to make contact with the switches outer ring so it would present a challenge.
I’m not saying that you can’t make some other sort of switch work for you. I’m certain that it’s possible. It’s just that you’d likely end up doing something different from what I’ve done. I was simply lucky in the sense that I already happened to have parts laying around that were suitable.
Quote:
I also don’t have any other tail cap boots.
-Garry
Just look for 16mm/8mm (or 16mm/7.5mm) rubber/silicone tail cap boots with an inner button (not the recessed kind that IO sells). These ones are probably suitable, although they are currently sold out.
The other thing you could do is pull the original switch out, look at it, look at the tail piece, put it back together, think about it, pull it apart again, run through some hypothetical scenarios, scratch your head, become slightly irritated, put it down for a while, forget about it, pick it up again, and then hopefully come up with an entirely new solution using a unique collection of new and existing (possibly modded) parts. Then you could come back here and post about it!
cainn
Great stuff chiefinspectorfinch Smile
garrybunk
garrybunk's picture
Thanks cainn for that info. Sounds like I'll just get a couple of those Solarforce switches and hunt around for some tailcaps.
-Garry
garrybunk
garrybunk's picture
Found more 16mm/8mm tailcaps at KD so I placed an order.  Ordered 2 of the Solarforce switches too (and it was really hard to resist throwing in a Solarforce body too).  I know it's a Chinese Holiday so I expect delivery to be delayed.
-Garry
apt323
apt323's picture
Got 26650’s in from led-dna today and they were at 3.67v and at the tail cap they read 2.25a which is about as high as i even seen it. Have to charge them tomorrow and see if they sill put this thing up to 3a+. If this thing don’t get brighter then i might have to call this a waste of time without a better driver and positive spring along with other things maybe.
Put it like this built a xpg2 drop in for my l2m with a KD V2 2.28a version and it is brighter the the eBay 57mm head light. Kinda not happy with the ultraOk. Very happy withe xp-g2 though like the he k out of that build. Might have to try a different emitter or style to see if it is better or give it away to a non flashaholic. Crying
cainn
I’ve seen 3.56A at the tail from a freshly charged Panasonic 18650. Immediately afterwards I put the same battery in my HD2010 and it was delivering 5+ amps so despite my best efforts there’s still a significant degree of resistance somewhere. But it’s not a big deal because I don’t really want any of my XM-L lights to be pulling much over 3.5A anyway, so I think I’m done modding this one.
In the end this has been totally worth it for me. I was convinced that I was going to end up giving this light away but I’ve changed my mind. It’s finally hanging with the big boys. It’s certainly not winning, but it’s definitely up there. After putting all this time and effort into it, making it better and making it my own, I’ve grown attached to it, and am subsequently deriving increased enjoyment from using it.
garrybunk
garrybunk's picture
apt323 wrote:
Got 26650's in from led-dna today and they were at 3.67v and at the tail cap they read 2.25a which is about as high as i even seen it. Have to charge them tomorrow and see if they sill put this thing up to 3a+.
That cell at 3.67v is pretty well fully discharged.  You should see a huge gain in amps from it when it's fully charged!  Be sure to report back.  What brand of cells are they?  (I haven't tried any 26650's in mine since I haven't gotten the LED properly heatsinked.)  I would like to hear from ceHowardGS about his cuz I know he's using 26650's and hasn't done anything to the LED star/pill connection.
-Garry
apt323
apt323's picture
I finally got the 26650’s charged took probably like 12+ hours. After that check the current again and now I am over 3a’s and you can really tell the difference. The light is definately brighter! Ya finally! But the battery us to short for the light doeant want to stay on. I put a penny on the negative side and it stays on but im sure that is not a good way of doing it!
Ps now its brighter then my xpg2 driven at 2.3a :bigsmile:
apt323
apt323's picture
I think the cels are the king kongs they look like the ones HKJ reviewed. I got them at leddna for sweet price
cainn
I probably should have mentioned (especially to garrybunk) that I’m using protected button-top 18650’s, which are 68.8mm long. In other words, my particular method of getting a Solarforce switch in the tail might not work too well for anyone using significantly shorter batteries, unless they also put a longer and/or tougher spring on the driver and/or switch itself.
old4570
Last seen: 1 week 2 days ago
Could it do 3xAA ?
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
cainn
The inner tube diameter is about 26.5mm, so there’s no chance.
EDIT: Would be great if it did though. I’d love to see something like a Cyclone C88 with a 55+mm head. In fact it’s tragic that a HD2010 head doesn’t screw onto a C88 body. It’s not far off really.
Concept light:
garrybunk
garrybunk's picture
Oh that looks Swwwwwweeeeeet!!!  I want one!
Oh, and thanks for in the info on the Solarforce switch.  I think that spring on the driver needs beefed up anyway.  I'm about 2 weeks away from having the switch & tailcap parts.
-Garry
garrybunk
garrybunk's picture
Recv'd my Solarforce switches today - 8 days from order and ordered during the Chinese holiday!  My first experience with Solarforce.  Also received my aluminum heatsink pill "insert" from a generous BLF member the other day.  Now if I can only get some free time to work on this light!
cainn wrote:
apt323 wrote:
But the battery is too short for the light doesn't want to stay on.
I probably should have mentioned (especially to garrybunk) that I'm using protected button-top 18650's, which are 68.8mm long. In other words, my particular method of getting a Solarforce switch in the tail might not work too well for anyone using significantly shorter batteries, unless they also put a longer and/or tougher spring on the driver and/or switch itself.
cainn,  I should be ok.  I also use protected 18650's and a raised-top King Kong 26650 (which is a bit longer due to that "raised-top").
1
Just brought over this photo I've posted previously.  That plastic disk is 0.50mm so this raised-top cell is 68.05 - not that much longer.
-Garry
apt323
apt323's picture
i like those heatsinks, saw a pic of them the other day. Hurry up and get that sucker installed and let it sing!
Went outside with the light last night and thinking on the brightness issue. Maybe it is the tint of the led that is making it fill like it is underperforming in my eyes. Been thinking that maybe I should put that xml 1a in there and see if there is more perceived brightness.
Not trying to get it to perform like my HD2010 but atleast maybe put a little smile on my face. :~
garrybunk
garrybunk's picture
Yeah, for all we know these stock emitters could be a really low bin.  I wonder how often that happens.
-Garry
apt323
apt323's picture
cainn wrote:
apt323 wrote:
Nice mod cainn!
Does the head get warm faster now? When I did mine it seemed like it warmed up a little faster but never got real warm. 15 minutes of running and and it was just getting warm. The head has alot of mass and fins I think that it spreads the heat out good now! :bigsmile: Going to order some 26650’s and see how that works out!
Hey, it was yourself and a few others that inspired me Smile
It certainly gets warm more quickly now, but like yours it doesn’t go beyond warm. In fact the thermal path is so good that the star itself doesn’t even really get very hot, and that’s after I redid the wiring between driver and the star to get more current to it. Tail cap readings show 3.3A now, but even though I’ve done some work on the switch, it’s still adding quite a bit of resistance. I’m currently trying to figure out a way to get an entirely new sort of switch in there.
Turned mine on last night and left it standing on the head for 15-20 minutes. After 5 you couldnt tell much difference, and at the end of the time it was finally warming up the pill section, the head and body was getting a little warm also. Either this is a heat dissipating monster or ????????
apt323
apt323's picture
-Garry
Ya that is true, also the tint looks more like my 2B xpg2 than something like the MF 3 mode dropin.
