Recommend me a driver 17mm dia. 3V input with more than 1A to the led and modes
I want to mod the stock Fenix P1D XR-E twistie with something more powerful, XP-G is good but XM-L would be better and need a driver that can work only with 3 volts frpm a 123A battery (Li-ion RCR’s are too big to fit) need at least 1 amp to the led and at least 3 modes (L,M,H) and no strobes or flashies, memory of last mode would be icing on the cake :smiley:
Do you know something I can use? I would like a driver like the one the Eagletac D25CM Ti is using to drive its XM-l, any ideas as to where I can find one?
Thanks!
AlexGT
I realize this is a not-so-recent-thread but the Dx 7612 has 3 x 7135 chips for 1A and will work down to 2.7v. Can set mode for low-med-high with switch and has memory. Other 7135 boards from Illumination Supply, Kaidomain and others. The Vf of an XML is pretty low at 1A (<3v) so it should work fine but run time on high might be limited with 1 cell. The Kaidomain V2 1A boards have solder pads that can be jumpered for LMH and memory. You can get a bit more time if you remove the input reverse polarity diode and replace it with a jumper. See this thread for info.
The 7135 based drivers mentioned above won't work. They're designed to have Vin be slightly higher than Vout and are not boost circuits.
As far as I know, the drivers in higher end lights are not available for diy.
Your best bet at this point would be this driver here. My quick test results of it are here.
Hi Match, the cell Alex mentioned starts at ~3.3v or ~3v nominal and at 1A an XML has a Vf lower than 3v but you’re saying it still won’t work even without the reverse polarity diode? Could he use a 16340 instead?
Thanks for the replies, will check them out, the host P1D doesn’t take Li-ion but since its an emergency light and seldom used, I’ll just use regular 3v 123’s
I have not used the 123 primaries and am in error if Match says so. Good luck.
No worries, sometimes I mess up, but...I just did a quick check to confirm:
A fresh CR123 primary will pass 200ma of current through an XM-L direct drive. Putting anything other than a boost circuit in there will only lower that amount.
Again...for primaries, look at a good boost circuit like the one above.
Hope that helps.
Thanks, another neuron spent but it was worth it.
