Test / Review: Panasonic NCR18650B 3400mAh (Green)
82 posts / 0 new
Sirius9
Sirius9's picture
Last seen: 1 week 4 days ago
It depends if he needs protected or unprotected cells!
light-wolff
Last seen: 4 days 21 hours ago
Protection affects all cells in the same way, i.e. it won’t change the ranking (provided the same protection circuit is used).
akoposilester
akoposilester's picture
i was wondering why are there gold plated and non(plain silver) negative terminals? is there any difference? these are both originals right?’
thank you
FL Newbie
Ramblings
Ramblings's picture
Last seen: 3 months 4 days ago
That would be the colour of the protection board's contact, not the battery itself.
There are different protection boards, some better than others.
You are the light of the world. Like a city on a hill, you cannot be hidden.
People do not light a lamp and then hide it away, instead they put it where it gives lig
akoposilester
Ramblings wrote:
That would be the colour of the protection board’s contact, not the battery itself.
thank you for the clarification.
FL Newbie
will34
will34's picture
Last seen: 58 min 16 sec ago
Generally a gold plated board means it is a better quality circuit and most likely seiko. Most cheap protected cells I’ve seen don’t have gold plated contacts.
Caleb
Caleb's picture
Last seen: 19 hours 52 min ago
Hi, I’m using 2 of these protected green batteries to power a Nitecore EC4SW.
I’m wondering if there would be a noticeable difference between these vs more expensive protected NCR18650B based cells from EVVA, KeepPower, Orbtronic, etc.
Or if there are other batteries better suited to maximize safety, runtime, or output in the EC4SW.
Specific make/model info would be appreciated.
Thanks for sharing your knowledge.
Sirius9
Sirius9's picture
No, you wouldnt have any noticable difference.
You could try something like: Samsung INR18650-30Q or LG HG2…
Speed4goal
Last seen: 11 months 2 weeks ago
I have a feeling this battery will continue to live in for long time it’s a classic. Most edc lights are 3amps and under anyways. They work great in my powerbank. GB has them on sale from to time. The price isn’t always the same from the listing until you click to open the page. The ones I got I played $27 for 8.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
OrcaTorch
OrcaTorch's picture
Last seen: 4 years 5 months ago
Nive review.
☆☆☆ Personal lighting solutions provider for safe diving ☆☆☆
Kinetic
Last seen: 8 months 1 day ago
Is it OK to replace Samsung ICR18650-26F 2600mAh included in the OEM Laptop battery with the more powerful Panasonic NCR18650B 3400mAh
I’m worried both batteries have different power output and might cause any problems with the laptop.
ICR18650-26F 2600mAh Specs:
http://budgetlightforum.com/node/33814
NCR18650B 3400mAh Specs:
http://budgetlightforum.com/node/33814 [NCR18650B]
dentrangtrihanoi
Last seen: 4 years 2 months ago
I like the color of it.
How long is it used?
Dia chi ban den chum trang tri noi that phong khach uy tin chat luong nhat tai Ha Noi
Kingjohn
Kingjohn's picture
Last seen: 5 months 3 days ago
Has anyone tried those cells in a high current drain flashlight?
They are only rated at:
Discharge_Current_max = 6.5A
What will happen if you stress them?
After what time and at which current will it happen?
(they will probably catch fire and explode…?)
Agro
Agro's picture
Last seen: 2 min 35 sec ago
I tried a half-discharged 18650B in Emisar D4 with 219c. Worked OK for a couple of minutes, then I got bored. I think there was a thermal stepdown.
Kingjohn
Kingjohn's picture
What was the discharge current?
Jerommel
Jerommel's picture
See the graphs and read the text in the OP.
It’s not a high drain cell at all, so you don’t use it for high drain appliances.
It’s a great battery up to 3 Amperes, but with the high internal resistance you get too much voltage sag when you draw more current from it. The losses are translated into heat = the battery will get warm.
Agro
Agro's picture
Haven’t measured. And I don’t have the hardware to measure it really.
Barkuti
Barkuti's picture
Last seen: 1 day 1 hour ago
Kinetic:
As you can see in this graph I've obtained from HKJ's comparator, at typical laptop discharge currents the Panasonic NCR18650B should give you some advantage, but can't say for sure how much will it be as it depends on the particular battery controller IC of the laptop and the OS. As smartphones and tablets, the computer will start to moan low battery before the stuff hits an average of ≈3.4V per cell under a typical load. I am pretty sure it'll need at least one or two full charge and discharge cycles before the thing will start to see the additional available capacity, if able it is. There's no guarantee this will happen as I don't know if the battery IC will reprogram itself to the particular shape and extra available energy the NCR18650B provides at lower voltages.
I'd be far more confident doing the overhaul with Samsung ICR18650-30B cells. These won't provide you with any extra capacity as they need 4.35V for it to happen, this however means they'll enjoy much more cycles in the stressful environment of a laptop (high voltage). See: BU-808: How to Prolong Lithium-based Batteries
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
Kingjohn
Kingjohn's picture
I know that this cell is not really suited for high current applications. (it’s rated 6,5A max.)
But I have 100 pcs here, that somehow want to be used. (I have to desolder them first from a battery pack, that was never used…)
My interest was in: which currents are still safe, so that this cell won’t burn or explode…
(specs are one thing, but panasonic is know to have a good quality, so I guess there is some safety range… )
SoCalTiger
SoCalTiger's picture
Last seen: 2 months 4 weeks ago
For sustained usage, I think that more headroom is better. Maybe 50%? So for a battery rated/tested for 6.5A continuous, I’d feel comfortable using it in something that draws ~3A.
kwcha333
thank you for your sharing
