just been doing some maths on the length of batteries....
29 posts / 0 new
adyscarborough
adyscarborough's picture
Last seen: 7 years 7 months ago
just worked out all the measurements of this battery problem ( think its the batteries) for my olight m3x…..
ok……
4 of the sysmax cr123 measures in total 133.6mm THE LIGHT WORKS FINE ON THESE….
2 of the tank 007 18650 measures in total 137mm THE LIGHT REFUSES TO WORK ON THESE….
2 of the xtar 18700 measures in total 138mm THE LIGHT REFUSES TO WORK ON THESE…..
By refuses to work i mean…
It may come on, it may not. if it does come on if i point it downwards it goes off or if it gets knocked it goes off…… this thing is too expensive to run on primarys so i need to find some 18650 that will actually work in it.
I have found some aw 18650 2200mAH that in total would measure 134.6mm….. just 1 mm more than the primarys, should these work as im getting sick of buying batteries for this thing now!!!!!
Is the difference of 133.6mm and 137mm really that much?? 3.4mm and the light refuses to work??!!!
Its been back to the dealer now and they say its fine its the batteries im using, so could someone please inform me if this 3.4mm is actually the cause of all this grief????!!!!
HELP!!!!!!! :~
scaru
scaru's picture
Last seen: 5 years 1 month ago
Does your tailcap have a brass plunger covering the spring?
adyscarborough
yes, and i bet im thinking the same as you!!!…. im thinking of somehow modding the thing to be just a spring at the tailcap. are we thinking along the same lines??!! lol
scaru
scaru's picture
adyscarborough wrote:
yes, and i bet im thinking the same as you!!!.... im thinking of somehow modding the thing to be just a spring at the tailcap. are we thinking along the same lines??!! lol
Yes, that thing is the problem I am on a iphone but I will be on a computer in 10 minutes so I'll explain how to fix then.
adyscarborough
Yes, that thing is the problem I am on a iphone but I will be on a computer in 10 minutes so I’ll explain how to fix then.
ok thanks :bigsmile:
scaru
scaru's picture
This assumes it works with the paperclip trick. Essentially what is happening is the brass plunger is getting pushed up to far jamming the switch. The same thing happened on my marsfire stl-v2.
First you need to disassemble the switch. This is generally done by sticking needle nose pliers in the 2 holes and twisting. Separate the brass plunger part. Then you take a file and file off the top 3-4 millimeters. If you want I can take some pictures.
BetweenRides
BetweenRides's picture
Last seen: 3 years 5 months ago
I would say yes. I have 8 different brands of 18650 batteries. My Roche F12 works with only one of them. Some lights are just finicky about battery length.
adyscarborough
yes thats exactly what i was planning on doing, first though im thinking i will take the plunger out and reassemble and try the switch back on with no plunger at all…. if this works the file is coming out!!!!!
this is the tailcap…..
JohnnyMac
JohnnyMac's picture
Last seen: 2 days 22 hours ago
!http://img801.imageshack.us/img801/9505/dsc03702mm.jpg!
Female threading in the cap is anodized which means the battery tube needs to contact the retaining ring for the switch. If your batteries, when inserted in the battery tube all the way, do not sit below the lip of the battery tube you will not get the light to work no matter what you do with the brass plunger.
adyscarborough
yes but i can feel that when the tailcap gets srewed on its that pertruding plunger thats wanting to stop it going all the way home… if i slightly unscrew the extension tube the tail cap goes on all the way so surely if i take a bit off the plunger its going to give me a couple more mm to play with??
scaru
scaru's picture
Yes, it will that is what I did with my stl-v2.
adyscarborough
thats the copy of the m3x right?? does my tailcap look similar to yours??
scaru
scaru's picture
Yep, here a picture of mine is.
adyscarborough
thats exactly what i was going to do… so was yours acting in a similar way and has this 100% fixed the problem??
BetweenRides
ady, it could be a comibination of things. First of all if the battery you're using is too long, nothing else is going to help, and if your measurements are correct, they are. Try to get ahold of an 18650 that is actually close to 65mm long. I just ran down to the office and checked the length of a few:
Callie's, Hi-Max, Solarforce:  68.5mm
Trustfire, Xtar: 69mm
Ultrafire: 66mm
In my N-Light ST50, the Trustfire and Xtar will not work - the .5mm makes a difference. All other cells I have work in it. You might find that the battery length and/or removing the tailcap plunger is all you need to fix it. As JMac mentioned, too long and the unanodized portion of the body tube is not seating properly, or the spring is getting crushed.
scaru
scaru's picture
Yep, it totally fixed the problem. Here the insides of the switch are.
scaru
scaru's picture
Forgot to mention it but it also works without the brass plunger.
adyscarborough
i think im going to take the plunger out first…. if this doesnt work ill have to buy MORE BATTERIES!!!! i dont know anyone with any so ill have to get them…. the aw at 67.3mm are the shortest i can find. im really hoping its that plunger as its been bugging me for ages with this thing now!!!!
scaru
scaru's picture
Couldn't you just use unprotected batteries?
adyscarborough
yes thats my first move before i start messing with it too much, im hoping this will solve it as its getting silly now lol
scaru
scaru's picture
Have you tried taking apart the switch yet?
adyscarborough
no as the light is up at my girlfriends but im off work friday so ill have all day to mess about with it then…. im actually tempted on going round just to take that plunger out and put my mind at rest!!!!!
scaru
scaru's picture
Oh ok. Good luck!
adyscarborough
thanks…. if this doesnt solve it ill be gutted, im confident its going to though.
gords1001
gords1001's picture
Last seen: 3 years 7 months ago
She’ll love that, “oh hi hun, just need to grab my light, have you got any tweezers?……” 8)
I’ve been getting home late, and had to let slip I’m waiting on another light….. I didn’t mention the other two that may show up in the next couple of weeks lol, ignorance is bliss.
It’s too bad we’re not closer, you could have helped yourself to any of my cells to see if they fit. You could also pm torchy the battery boy on here, he’s Glasgow based and has an eBay shop with a fair stock of decent cells. I’m sure he could fix you up with something, I’ve had a few bits off him now and they’ve always come really quick with excellent communication. Worth a try. :bigsmile:
Dimlock
Dimlock's picture
Last seen: 8 years 7 months ago
Just to add a couple of data points…
My M3X works well with TrustFire flames (68.5mm each), and Trustfire 3000mAh (68.8mm each)
It does Not work with Intl-Outdoor NCR18650A 3100mAh (68.9mm each).
I really would not have imagined that one tenth of a mm would make any difference, but I think it does. If you’re going to get new batteries, I would keep them under 68.8.
(Not my measurements, but from: http://lygte-info.dk/review/batteries2012/Common18650Summary%20UK.html )
http://www.brainyquote.com/quotes/quotes/w/waltwhitma146847.html" title="view quote" style="border: 0px;
adyscarborough
FIXED!!!!! Thanks for everybodys input on this….. simple fix….. took the plunger out and it works perfect now….. not even going to shave it down….. im now happy!!!!! :bigsmile:
kramer5150
kramer5150's picture
Last seen: 1 week 5 days ago
Nice investigative work Andy. Hopefully I’ll remember this if I ever encounter it too. Good to know you got it all sorted out. I usually have the opposite problem (loose rattle cells and intermittent cell contact) since I only use unprotected cells.
Dimlock
Dimlock's picture
I just realized the easy way to check for this. The tailcap threads are anodized, so the current cuts off if you back it off by unscrewing it a bit.
However, if you unscrew the extension tube from the side closest to the emitter, the light will turn on when the tube has enough room to accommodate the batteries you have used. Those threads are not anodized.
I should have thought of that before. But, if anyone else is having problems with this, it will help you troubleshoot your issue.
