This will be my first flashlight if I do decide to get it, so there are some things I don’t understand about flashlights.
Some lights have “drop ins” as I understand it, which is like a bulb assembly with the driver and reflector all built in. However other lights (like the SC600) don’t seem to support drop ins. Hence if the bulb on this flashlight dies or something goes in its circuitry for some reason, does it mean I need to get a new Zebralight?
The drop-ins are there for customisation, rather than replacing failed components - the LED “Bulb” should have a lifespan of thousands of hours continuous use and isn’t damaged by dropping etc - it should last as long as the rest of torch
The Zebralight is pretty much not repairable by owner. If the driver, led, or electronic switch go bad, you will have to send it back to Zebralight.
Having said that, I have been pocket carrying mine for about a year and use it many times a day without fail. It has even survived a couple of hard falls to concrete. I would consider it a rugged light. There is alot of info online about this light and it is very popular.
The led of ZL sc600 is xml T6 and T5 for sc600w and its doesnt use a ” drop in”. The bezel, len, o ring and reflector can be removed,so gaining access to the led emitter is possible.( I done it with mine). If you can do soldering, changing the led emitter should be quite ok, think its a 14/16mm led base.Cant really recall. Access to any ZL flashlight driver normally is beyond easy means though. Please note that some people encounter difficulty loosening the sc600 bezel. Mine came off quite easily.
I also have a SC600 and I like it a lot, really bright in a compact package.
It’s got a nice solid feeling to it.
Though I can really recommend the Shiningbeam Blaze thats on sale for $30 right now, I personally prefer the beam on the blaze over the sc600.
The blaze is not as pocketfriendly though as its bit bigger, but its also a qualitylight.
Nah, not really, but the name is quite a refreshing breakaway from yet another “PantsOnFire” light. That said though, are there other lights with low voltage cutoff like this one has? I will be using this light as a EDC for the zounds of harvested 18650 cells that I got!
For your first flashlight, you’ll be jumping right into it. The sc600 is a favorite of many flashaholics, including myself. It’ll be sad when not many other lights live up to your first purchase hehe.
I have had the Zebralight SC600 since it first came out and have had a custom made leather carry pouch with a pocket for a spare 18650 battery made by Thor’s Hammer Custom Leather [sales@thorshammercustomleather.com] and I wear the pouch every day.
I am just wondering why you recommend the SC600W instead?
It is mostly just a personal preference. I think that cool whites wash out colors and create more glare. I was mostly throwing that out there so that wshyang knew it was an option.
Another reason to suggest the neutral over the cool white is the posibility of getting a green tinted light when ordering the cool white version . I actually prefer a “warm side of neutral” light but don’t have a problem with a nice bright white tint in a pinch. What I relly hate is a green tint. I own a couple of would be favorites made unusable(for this tint snob) by them having a greenish tint. The weird thing is, I rarely see this green tint in budget lights and it is rarely discussed. Go figure.
I also own a SC60 and a SC60w and the w is what started me down my road to being a tint whore. When the SC600 was first available for pre-order, I really really wanted to wait for the neutral version but pre-ordered anyway knowing I would also get the SC600w. I have no regrets. If the w had never been released, I would still be singing the SC600s praises.
I was also one of the unlucky early adopters that recieved the SC600 with the squirrelly switch. I had to send it back(a frustrating five week ordeal).
I have almost ordered one of those holsters on several occasions. They look nice. What other flashlight is so popular that it has a ready to order custom holster?
That is correct… the Zerbralight designs are one of the most difficult to mod and DIY repair, darn-near impossible if you ask me, although I have seen others pull it off.
I had an H501 that had a faulty switch boot and leaked water. It was under warranty so I just sent it to somewhere in TX and they sent me a new replacement. Pretty hassle free IMHO.
