After seeing the AW IMR 2000mAh outperformed by the Efest IMR 2000mAh and Panasonic CGR18650CH, I wondered how the AW IMR 1600mAh would fare against the Efest IMR 1500mAh and Sanyo UR18650W2.
At !A discharge the Sanyo edges it with AW and Efest looking very similar.
At 5A discharge the AW and Efest are almost identical to Samsung INR18650-15Q.
I'm guessing you mean 1A discharge?
My LED comparison thread with links.
Tint, Binning, and CRI Explanation (For the XM-L)
http://budgetlightforum.com/node
I think many would really appreciate 10A tests of these + the other cells.
The AW and Efest are too similar to the Samsung INR18650-15Q for coincidence.
Maybe 15A would be a better test.
10A, 15A, 20A.. whatever you like.
For these also, if possible:
http://budgetlightforum.com/node/11899
Much appreciated, I'm looking to get some IMRs in the near future..
Since IMR are supposed to discharge a high current without thermal build up, I thought a measurement of the battery temperature at 10A continuous current would be a relevant test:
I know Panasonic test at 60 degrees C, but I wanted a safety margin (don’t know how much higher the internal temperature is compared to the external) and set the cut off temperature at 50 degrees. s
Very interesting results. Thanks very much for doing these tests.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
I’m not sure why LG rate their discharge currents so low on their LiMnCo batteries:
http://www.batteryspace.com/new-generation-lg-linimnco-18650-rechargeabl...
http://www.batteryspace.com/New-Generation-LG-LiNiMnCo-18650-Cylindrical...
http://www.batteryspace.com/LiMnNi-Rechargeable-18650-Cell-3.7V-2000-mAh...
They don’t seem any better than standard LiCoO2
Sorry about the pictures, now updated
Thank you very much for doing all of these test result.
I’m expect for more of your updated test informations.
new charger : http://www.efestpower.com/Product/5163781547.html & http://www.efestpower.com/Product/483756337.html
Compa
Some of the images no longer show up, can you repost them?
www.edcplus.com
Is that any better?
I see them.
Helloguys,
Please keep updated efest bateries homepage on your list www.efestpower.com , check all new efest batteries from here. Or please just clink the efest banner on BLF left side. Thank you.
If there is any suggestion for efest, please do not hesitate to contact me.
Regards,
Jone
Compa
