Lego: E1320 modified UF-2100 vs Ultrafire C303
9 posts / 0 new
Suncoaster
Suncoaster's picture
Last seen: 3 weeks 4 days ago
Location: Where the girls are green and the grass is pretty.
I discovered that the dropin created by E1320 for the UF-2100 fits the C303, with just a small dremel mod of the reflector hole.
I much prefer the C303 body to the UF-2100 for it’s shorter length, no attack bezel, and it’s groovy finish.
Has anyone else changed the UF-2100 or C303 ?
Will the switch cope ?
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
Edited by: Suncoaster on 08/09/2012 - 21:14
Chicago X
Chicago X's picture
Last seen: 7 years 5 months ago
The stainless steel may make for a crispy critter.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Suncoaster
Yes, thanks, hadn’t really thought about that.
I like to use High most of the time too.
Maybe an excuse to get an IR thermometer !
How high can we go before the emitter or driver get damaged ?
Suncoaster
Actually the C303 18650 turned out to be some sort of aluminium
The C3 14500 has a Stainless Steel variant.
So hopefully heat won’t be a problem.
Chicago X
Chicago X's picture
Good news for the (be)holder. Smile
The max junction temp of the LED is 150C, but the light would likely be too hot to hold well before that – given a decent thermal pathway.
E1320
E1320's picture
Last seen: 4 months 2 days ago
Great info thanks for sharing.
The 14500 version of the C3 has the same pill as a R5A3 so mine has a modified 3 mode no flashy XPG in it.
I don’t own the 18650 version but this sounds really cool.
I am already visualizing the duct tape over your mouth.
Suncoaster
Wrapped the threads in foil.
Found the pill was a bit loose so wrapped one layer of aluminium foil on the threads, like plumbers tape on a tap. That made it a tight fit and will improve thermal efficiency.
It’s a nice light.
JohnnyMac
JohnnyMac's picture
Last seen: 2 days 4 hours ago
I find that my IR thermometer doesn’t like stainless steel very much. Too reflective perhaps.
budynabuick
budynabuick's picture
Last seen: 8 years 2 months ago
Put a piece of tape on it.
Keith
