Picture Heavy - 3xAAA Copper Smoothy, Penlight (well almost) - Scratch build & A GIVEAWAY AS WELL - We have a Winner!
It rained today!!!!
It rained today!!!! So, since it was a little cooler, I did a one day wonder, using the components below:
1
Some 3/8 copper pipe, two 3/8 couplings, a 3/8 end cap, a Nichia 219, a tail cap switch, a tiny OP reflector, a Maglite clip and some Eneloop AA batteries.
I call these things Copper Smoothies, since they are Copper and Smooth, LOL. Hopefully, this one will fit in a pocket - Maybe...
2
Since the copper end cap is short and the switch is long, I am going to use a combination of the end cap and a coupling, for a longer tail cap. Here I am marking where I will cut the 3/8 pipe, so I can solder the two pieces to it and tie them together. I only want to just catch in the coupling, because it will be going over the pipe/body.
3
Here's how it looks inside, before soldering.
4
I use a brick, for my larger soldering tasks. It works great, since it doesn't absorb heat worth a darn, so the heat stays in the parts I'm soldering. That's Radio Shack 60/40 solder.
5
The end cap is a little thicker wall than the coupling, so some filing and sanding will be needed.
6
Working the copper down, to get to the seam and get all the solder off it.
7
Now that's better looking. Still needs a smoother finish, but the seam is almost not visible.
8
Hole drilled in the end cap and switch is just pushed in, It fit well and I didn't need to glue it in.
9
The tail cap will be a slide on and twist fit. I've done these before. I use 1/8" brass rod, drill the copper, cut and press fit the rod in the copper and solder them in.
91
The tail end of the body gets slots, that the brass pins fit into. Then I cut a "J" into the slots, so the pins will twist into them. Keeps the tail cap on. The initial cut is with a hacksaw and then a small round file does the rest.
92
The pins are filed and sanded flush to the tail cap after soldering.
94
The pill was a piece of 1/4 copper tube, with a .024" thick copper sheet wrap around that and then filled with copper shot. A piece of copper sheet on top and fill it all with solder. Clean it up a little and mount the Nichia on one end. The positive comes out the center of the other end and there's a plastic isolation disc and a copper round tab that the positive wire is soldered to. The negative will just be bare wire between the pill and the body.
95
The reflector is a tight fit into a 3/8 copper coupling and I did not have a lens, so I made one out of a 2D plastic lens.
96
I just used a hot razor blade to cut it out and then filed and sanded till it fit the coupling.
99
I slid the pill in the body and then slid the coupling with the reflector and lens, over the body and pinned it in place. Unfortunately, I did not get it on straight. It's cocked at an angle and it's a done deal.
Here's the finished light:
f1
It is not the best I've ever done, but it works and it's bright with the Nichia and 3AAA NiMH direct. Here's a couple quick shots of the beam.
b1
b2
It's all flood and it will light up a room very well, but there's no real spot at all. I like these Nichia LEDs more, every time I see them. Great color rendition.
Now we go to the giveaway. Look in the next post for that.
Ok, so I figured that I might as well give this light away, since I really don't want to keep it and I really don't want to sell it.
This give away is open to ANYONE WORLDWIDE, who was a member as of 08-15-2012. I will ship anywhere in the world. Maybe Mars, if I can get it on the next rover.
You must Post in this thread, that you want to be eligible. Like "count me in", etc.
I will have this giveaway open until 08-26-2012 at MIDNIGHT CST.
Then I will use Random.org to pick a winner using your Post#. The winner will be announced within a couple hours after the end of the giveaway.
Simple enough?Wink
WE HAVE A WINNER
Forum Member Triple A
Just PM me with your name and address and I will send it out.
If you don’t mind me asking, where did you get the reflector for this project?
CNQG - cnqualitygoods
I'm very impressed, being only vaugely mechanical (and without equipment) I can barely fathom the designing, fabricating, and execution of this light out of almost nothing! Thanks for sharing, Old-Lumens. By the way, will it take 14500 LiIon?
Please include me in the drawing, I would be very very honored to be a recipient of this beauty!
Many thanks!
14500 is AA not AAA and this takes AAA, so no, it won’t take one of those.
bort likes the light and wants in
I see it, thanks!
Also, I’m sorry for being a hassle, but would it be possible if I opt out of the giveaway? I’m not able to receive packages in the mail at the moment.
I want in! BLF is lucky to have guys like you. Beautiful work.
That is brilliant o-l, count me in :bigsmile:
Count me in!
Nice work Old L. Count me in!
Count me in, Justin.
Beautiful craftsmanship as usual! I would be honored to have a piece of your handywork. I already have the switches enroute but it looks like I will be placing another order for some more parts. I see one of these in shorty form running off of a 10440 in my future.
You are an inspiration!
Count me in. :bigsmile:
Wow! Looks awesome!! Count me in as well:)
Wow! Great job as always O-L!
That light looks very cute, so: Please count me in.
Count me in please!
Nice job man! very skilled work!
Please count me in!
My wife really likes it. So I’m in.
I’m impressed !
Count me in please.
