Review: ML-102 Charger
199 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 days 12 hours ago
Charger ML-102
DSC_0065
This charger is a very small 18650 charger, it need an external USB power source to charge, and can also work as a USB charger. It only charges one battery at a time.
DSC_0064
Only a USB cable is included with the charger, I did also order some spacers, making it possible to charge smaller batteries.
DSC_0070 DSC_0073
The charger is powered from any USB source that can supply 1A, sadly it uses the mini and not the micro USB connector (The micro USB is much stronger and is the common charge connector on phones). Because the connector is on the side of the charger it is not possible to place a couple of these chargers beside each other.
DSC_0067
The charger also has a full size USB connection for power out, it can be used to charge a phone or other USB equipment.
DSC_0313 DSC_0315
DSC_0319 DSC_0321
The charger has a couple of leds, one is placed on top of the charger and some other inside the charger.
The light is red when charging, both red and green when nearly full, green when finished and blue when supplying USB power.
DSC_0074 DSC_0075
The plus connection is slightly raises, making it possible to charger flat top batteries, the spring at the minus connection is rather short, but long enough to support unprotected 18650 batteries.
DSC_0076
With the two spacers (Each 15.9 mm long) I included in my order the charger can also handle xx500 and xx340 cell, but the charger current is too high for many of these batteries.
supportedBatteryTypes
supportedBatterySizes DSC_0310 DSC_0069 DSC_0071 DSC_0324
The charger can handle 69.6 mm long batteries, including flat top cells. Not all 26650 can be charged, it depends on the size and shape of the plus pole on the battery. With the spacers it is also possible to use smaller batteries, but watch the maximum charge current for the battery type!
Measurements
Below 2.8 volt the charger charges with 130 to 170 mA (Highest current at lowest voltage).
Between 2.8 volt and 4.2 volt the charger is applying regular charge current (See curve below).
When the charge current goes below 70mA the charging is stopped and it will discharge with less than 75 uA.
The charger will restart when the battery drops to 4.12 volt or power is cycled.
Reinserting the battery will not restart charging.
When charger is disconnected from power, but with a battery in, it will draw below 75uA from the battery.
ML-102%20(AW18650-26)
The charge curve does not look like a CC/CV charger, but the only disadvantage with this type of curve is the slower charge speed, the final result will be just as good as a CC/CV charger. The termination current is around 80mA, this is a good value.
The above curve is done with a USB power supply (or more correctly a lab power supply adjusted to 5 volt).
ML-102%20(AW18650-26)%20Vusb=PC
Using a laptop as power supply does not change the charge curve significantly. The charger is using nearly 1A from the USB connector, this is more than allowed in the USB specifications, but nearly always works fine.
ML-102%20(AW18650-26)%20Vusb=4.5V
What happens if a weak USB power supply is used or long cables, to simulate that I turned the power supply down to 4.5 volt. The charger continues to charge and stops when the battery is full, but it takes considerable longer time (nearly 10 hours).
ML-102%20(AW16340-IMR)
The charger also handles my old IMR cell without any problems.
Measurements on USB power
The charger can supply USB power while discharging the battery. It is possible to connect a USB power supply to the charger and connect the charger to some USB equipment and charge both at the same time.
USB specification says the voltage must be between 4.75 and 5.25 volt, I have placed a yellow line at 4.75 volt in the charts.
ML-102%20USB%20out%2020%20ohm%20(AW18650-26)
The first curve is with a 20 ohm load, this gives a load current of 250 mA, the usb output stays exactly at 5.13 volt, until the battery is empty. It keeps a very good efficiency at about 90%.
The power is turned off when the battery is down to 3 volt and it does not turn on again when the battery voltage increases, this is a good design.
ML-102%20USB%20out%2010%20ohm%20(AW18650-26)
Reducing the resistor increases the current to 500 mA and drops the voltage to 5.1 volt (probably due to cable losses). The efficiency is still very good at 85% to 90%.
ML-102%20USB%20out%209.1%20ohm%20(AW18650-26)
Reducing the resistor again increases the current to 550 mA, the efficiency is starting to drop now, but the voltage is stable.
ML-102%20USB%20out%207.7%20ohm%20(AW18650-26)
This time I have increased the current to 650 mA and this is at the limit of the circuit, the voltage is not stable anymore, but it can still supply this current for two hours and stay within the USB specifications.
Conclusion
This charger is a very compact LiIon charger with dual functionality (Can both charger USB devices and 18650 batteries), the charging profile is good, but not optimal for speed. I can see two obvious applications for this charger, one is for people with only a few 18650 batteries, the other is in a travel kit, where the ability to charger USB equipment from an 18650 battery can be very useful.
I like this charger and is going to add it to my traveling kit.
Notes
Edited by: sb56637 on 06/25/2015 - 14:19
JohnnyMac
JohnnyMac's picture
Last seen: 1 week 2 days ago
That looks like a great little charger. Where did you get it and how much are they? I may have to get one as a spare charger.
Edit: never mind, just saw the other thread on it. Thanks for the great review on it. Smile
HKJ
HKJ's picture
JohnnyMac wrote:
That looks like a great little charger. Where did you get it and how much are they? I may have to get one as a spare charger. Edit: never mind, just saw the other thread on it. Thanks for the great review on it. :)
It is from intl-outdoor and is only $9.
alex21
Thanks for the review. Think I should buy another of these. Word of caution, as mentioned some protected batteries like the popular Hi-Max 18650 don’t fit, but flames do np. Smile
HKJ
HKJ's picture
alex21 wrote:
Thanks for the review. Think I should buy another of these. Word of caution, as mentioned some protected batteries like the popular Hi-Max 18650 don't fit, but flames do np. :)
Then there are variations in the size, Hi-Max does fit in mine:
alex21
Thanks for the correction. Do you need to apply much force to get it in? Maybe I am worried about breaking something Smile
HAL
Last seen: 6 years 4 months ago
Thanks HKJ. Received mine a view days ago from Hank, shipped to Finland in a week! Great build quality and works flawlessly. I use mine mainly to charge my phone on the go since the battery life is crap.
HKJ
HKJ's picture
alex21 wrote:
Thanks for the correction. Do you need to apply much force to get it in? Maybe I am worried about breaking something :)
I just press it against the spring, then it goes in without any problems.
NightCrawl
Last seen: 6 years 6 months ago
Great review, thank you!
That cleared half of my "waiting for review" list. Big Smile
Philipp
Philipp's picture
Last seen: 8 years 11 months ago
I always liked this charger a lot, particulary the ability to charge other devices with it and the travel aspect you mentioned, because it is also quite small.
Though I hesitated to buy it because no one ever reviewed it and I was really interested in the graphs you just presented us!
So… mange tak! :bigsmile:
Now to the charger:
The problem with the high charging currents for smaller capacity cells could easily been solved by using a lower current USB power supply (I got a 650mA one, I think this should be ok for 14500er) or am I missing something?
I really liked the ability that you can charge a cell with the carger and the charger can put out to other USB device at same time for the travel aspect, but than I realised that you wont save any time doing this, because the current from the USB power supply will split up to power both the charger and the second USB device.
You will end up with the same charging time as if you connect the charger first and after that the second device directly to the power supply. Correct me if I am wrong.
The ideal addition to this charger would be a small adjustable USB power adapter. Does anyone know something like this?
CNQ also has it for 8,50 but with 1000mA USB power adapter. Although it is described as ML-10*3*… or is it a different one?
HKJ
HKJ's picture
Philipp wrote:
Now to the charger: The problem with the high charging currents for smaller capacity cells could easily been solved by using a lower current USB power supply (I got a 650mA one, I think this should be ok for 14500er) or am I missing something?
That might work fine, if you can trust the supply to reduce voltage when overloaded, without blowing up.
Philipp wrote:
I really liked the ability that you can charge a cell with the carger and the charger can put out to other USB device at same time for the travel aspect, but than I realised that you wont save any time doing this, because the current from the USB power supply will split up to power both the charger and the second USB device. You will end up with the same charging time as if you connect the charger first and after that the second device directly to the power supply. Correct me if I am wrong.
It might take the same time, but for me the advantage is that I do not need to do anything while it is charging, i.e. I can start the charger when I go to bed and both phone and 18650 battery is filled the next morning.
I am using a SKROSS dual USB charger, it is not adjustable, but it is small and works fine (I have not tested it, only used it).
Philipp wrote:
"CNQ":http://www.cnqualitygoods.com/goods.php?id=1331 also has it for 8,50 but with 1000mA USB power adapter. Although it is described as ML-10*3*... or is it a different one?
It is not the same, it uses different connectors and I do not believe it has USB power out.
The charging might be the same.
wshyang
Last seen: 9 years 6 months ago
Thanks for the review HKJ, does the ML-102 work for reviving overdischarged 18650s too?
alex21
Very nice Smile Charge your battery and phone at the same time.. awesome charger just got better thx Smile
HKJ
HKJ's picture
It will try to charge them at a lower current (below 170mA), how wise it is can be discussed.
wshyang
I’ve tried it earlier with a 0.2V 18650 and it keeps flickering with a green and red LED pattern, as though there is no battery inserted. Does yours do the same too?
HKJ
HKJ's picture
wshyang wrote:
I've tried it earlier with a 0.2V 18650 and it keeps flickering with a green and red LED pattern, as though there is no battery inserted. Does yours do the same too?
No, it goes a solid red.
I did not try with a battery (I do not have one with 0.2 volt), but shorted the plus and minus connection with a ammeter.
garrybunk
garrybunk's picture
Last seen: 1 week 1 day ago
Thanks HKJ!  I really like the two of mine, although I had to file down the edge of the charger so that my King Kong rasied top INR's would fit better (the raised top causes it to pop upward.  I don't have a photo of the filing, but my initial issue was documented in the other thread with photos.  I power mine with the USB A/C adaptors from Manafont (clones of the Apple iPhone ones) rated 1A output.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
scaru
scaru's picture
Last seen: 5 years 9 months ago
Garry, do you have a link to those USB power supplies?
fishinfool
fishinfool's picture
Last seen: 3 years 2 months ago
Thanks HKJ!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Suncoaster
Suncoaster's picture
Last seen: 1 month 1 week ago
Location: Where the girls are green and the grass is pretty.
I’ve just added on to my order from intl-outdoor.
It’ll go in my travel kit.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
garrybunk
garrybunk's picture
Here ya go.  $1.96 each.  I bought three and wouldn't mind having more.
-Garry
P.S.  I tried to give a link earlier, but I was in a hurry and couldn't find them.
scaru
scaru's picture
-Garry
Thanks, I saw those a while ago but haven't been able to find them since.
wshyang
Hi HKJ,
Do you happen to know how much current the charger is pulling from the 18650 when charging a phone too?
Ledsmoke
Ledsmoke's picture
Last seen: 2 years 3 months ago
Thank you for the review HKJ.
I've been curious about this charger ever since I saw it the first time. Found a review on "taschenlampenforum.de" or something similar and they said it was good but no where as detailed as your in depth reviews.
Thank you for using all that time and money for us guys out here. We enjoy it Smile
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
HKJ
HKJ's picture
wshyang wrote:
Hi HKJ, Do you happen to know how much current the charger is pulling from the 18650 when charging a phone too?
That depends on the phone and how much current it is drawing. In my charts for usb out there is a current line.
Hikelite
Last seen: 3 days 7 hours ago
Don't try charging 0.2V batteries, those are dead.
Hikelite
This is an awesome charger, the plastic is really tough.
Reverse polarity protection works. Resets the protection after has kick in protected cells and the voltage is 0.00V
When the battery voltage is too low cannot charge other devices, the blue light will not turn on and, the light not being on is a good thing because you have a visual representation of what's actually going on.
sb56637
sb56637's picture
Last seen: 3 hours 51 min ago
Thanks very much! Frontpage’d and Sticky’d.
Ouchyfoot
Ouchyfoot's picture
Does anyone know if this can charge an IPad?
rufus001
I charged my iPhone fully without it blowing up. I can’t verify that it is a recommended practice though.
Suncoaster
No, it doesn’t.
I just tried it and the Apple says “not charging”.
It works on the Android Samsung Galaxy Tab though !
