I have that TK-568, with a nimh it is a bit less bright than a Fenix LD15 (115 lumen).
With a 14500 lithium-ion it is much brighter.
The beam is a bit ringy with a smaller spot than the Fenix LD15.
The color is also much cooler (whiter) than the Fenix.
Build quality is very good, mode memory works like it should
I think it is about 100 lumen on a nimh, and 200 on a lithium-ion battery.
Low is very low, and should last for many hours.
I have the two lights you are entertaining. I would add the Balder SE-1 neutral. A favorite of many on BLF and still in the price range you desired. The Balder XM-L is best with 14500 Li-ons and most bright. DQG is much smaller though.
Two different and good choices. Keep us posted and good luck.
I think that what you should be looking for is XX-lm that lasts for 1-1.5 hrs because the high profile of flashlights differ greatly. There are high on some flashlights that are only equivalent to low of the other flashlights.
I suggest you look at Xeno E03 if you can extend your budget a little more. It is very versatile, you can use either AA or 14500. It can out put 430-lm on high with a single 14500 battery. Plus it has very good flood. When using 14500 it can last up to 20mins at high output and 2.5hrs at low with 14500.
This was my test throw for my E03 months back. The far wall is around 28m from where I was standing. The whole area was lighted only by my E03.
Too bad the trunite deal is probably over a t10 and ti could be had for $25, I got the pair for my mum and am so impressed I’ll be getting a pair for myself next deal time.
Oh, for run time, a 1000mah battery can deliver 1a for 1h so a 2000mah battery should run a light with 1.5a draw for an hour and a half. Hope this helps.
Ah you mean the single Ti light, for which one has to pay 5$ shipping?
yah that's lame i agree.
well, unless i get FREE review samples from them, i cant be bothered with their catalog or offerings. there are much nicer website names such as Dinodirect.com or Balder
I was quite happy with my Ti from the first promo so I thought I'd order a few more to give as gifts, $5 shipping didn't sound so bad. However after adding a couple to the cart I noticed the shipping was $5 per light which was a deal breaker for me. Why not simply state the real price instead of "hiding" it in shipping cost.
X2 – a high output keychain flashlight manufactured by Solarforce for our valuable customers, using premium CREE XP-E (R4) LED to produce up to 100 lumens white light with just a single AA battery. The body of X2 is mainly constructed of high quality polished S304 stainless steel. The LED engine part is protected by copper alloy to ensure efficient heat transmittance. Unique rhombus-shaped knurling is chosen at the head to provide users with non-slippery surfaces. X2 is definitely a powerful and collectable every-day-carry keychain flashlight for professional users and flashlight lovers.
Specifications:
Constructed of S304 stainless steel
CREE XP-E (R4) LED with lifespan up to 50,000 hours
Strengthened ultra-clear glass lens with two-surface coating
Battery type: AA (alkaline or rechargeable 1.2V) x 1pc
Structural reversed polarity protection
Two modes: high & low (turn off and on within 3 seconds to switch between different modes, and direct access to high mode after 3 seconds)
