Back in Black - SST-90 4D Maglite "Shower Head" Aspheric build.
151 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 11 months ago
feilox wrote:
1 question. Will you be making some to sell?
You mean drivers or lights?
If it's drivers, no, I would not be making any for sale. It's too much stress, LOL.
Seriously,  for me, it's very hard to do these, so I try to do them only when I have to.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Unkl Ian
Last seen: 8 years 3 months ago
Old-Lumens wrote:
I have found that Arctic Alumina does not like heat! What the heck is that? AA is supposed to be good for heat, but I’ll tell you what, I have had many instances where I soldered something like these chips and the chip came loose from the AA. I’ve seen it on led stars too, when soldering the wires on. I am not very happy about AA and if it is the best of the bunch, I can see why stars should always be screwed down instead of using thermal compound.
What do the hardcore computer people use on their heat sinks ??
Old-Lumens
Unkl Ian wrote:
Old-Lumens wrote:
I have found that Arctic Alumina does not like heat! What the heck is that? AA is supposed to be good for heat, but I'll tell you what, I have had many instances where I soldered something like these chips and the chip came loose from the AA. I've seen it on led stars too, when soldering the wires on. I am not very happy about AA and if it is the best of the bunch, I can see why stars should always be screwed down instead of using thermal compound.
They use thermal grease, not adhesive and they use all different types of clamping methods, to hold the heat sinks on. They don't use adhesive because they can't take if off easily and because clamping or hold downs are the only real way to hold two pieces together. We just don't have that kind of room in a flashlight.
mattthemuppet
Sorry, had to rant……. just had to.
AA needs pressure and a lot of it to work properly as it’s not an adhesive – alumina adhesive would be what you’re after AA on newegg Plain AA works fine on CPU heatsinks as the clips/clamps/screws provide an enormous amount of pressure, but wouldn’t be any good for a component left floating around Sad
I’ve always screwed my LEDs down on all of my builds, although I tend to have more room to play with. You can get sweet little allen cap screws with 4#40 threads that fit within the holes on the star, those might help. I have a draw full of them (scavenged off an old microscope filter wheel) if you want any – I’d have to build 20 or 30 lights to use all of them, which, you know might happen {tick, twitch}
Old-Lumens
mattthemuppet wrote:
Sorry, had to rant....... just had to.
AA needs pressure and a lot of it to work properly as it's not an adhesive - alumina adhesive would be what you're after "AA on newegg":http://www.newegg.com/Product/Product.aspx?Item=N82E16835100013&nm_mc=KN... Plain AA works fine on CPU heatsinks as the clips/clamps/screws provide an enormous amount of pressure, but wouldn't be any good for a component left floating around Sad I've always screwed my LEDs down on all of my builds, although I tend to have more room to play with. You can get sweet little allen cap screws with 4#40 threads that fit within the holes on the star, those might help. I have a draw full of them (scavenged off an old microscope filter wheel) if you want any - I'd have to build 20 or 30 lights to use all of them, which, you know might happen {tick, twitch}
I have 3mm screws. I just hate to do it. It's such a PITA. I will be using screws on the SST-90 instead of AA.
AA is good to 150c, but unfortunately, that is lower than the 185c-190c of 60/40 solder. No wonder it never works. So, that means solder before, glue after. Another PITA.
I think maybe it's just the 100+ degrees every day that's a PITA and it makes everything else seem to be. Wink
mattthemuppet
I dunno, it only adds 10-15min to my builds. Mark, punch, drill, tap, blast with compressed air and you’re done. 100% reproducible top notch thermal junction everytime plus replacing the LEDs with the next model out is a piece of cake.
texaspyro
Last seen: 2 years 5 months ago
Epoxy sort of has a “memory” for the highest temp that it has seen. Heat it above that and it softens. There is (somewhere) an article on boat repair on the Gouegon.com web site that talks about it. Gouegon makes the West Marine epoxies.
Real high temp epoxies have to be baked to set the epoxy and get the high temp capability.
MRsDNF
MRsDNF's picture
Blown away again. How do you get your soldering so neat? Lots of practice and ability I suppose. If I did what you have done with those drivers there is a 100% chance that they would never work again. The close up picture's aren't bad either.
Old-Lumens
Truthfully, I get nervous every time I have to go near something like that. I hate soldering those things! I have a table top light that has a big magnifying lens in it. I can pull it over top of the work area. I also have to position the boards in a small vise, where they cannot move and where I can rest both hands on it. Otherwise I can't hold still enough. It's hit or miss and y'all don't get to see the mistakes, LOL, but mistakes, they are a plenty, believe me.
I would love to buy a real micro soldering gun or station, but the good ones, with the really thin tips, are way too much money. I usually file my tips to a finer point, even though it ends up ruining the tip much quicker, but I can't solder that stuff with a regular tip. I know one thing, you want a good, hot iron. At least 40 watt or more. It is so much easier to just hit the spot for a second, rather than to have to hold in place, waiting for things to get hot. I never knew that, till I read it from another member. It works!
MRsDNF
MRsDNF's picture
If I may ask what mixture of lead/silver, flux or resin cored and thickness solder do you use. The array is amazing.
Old-Lumens
I use 0.032" solder,  60/40 rosin core. I get it from Radio Shack in spools and wrap a few yards at a time on a 3/8 rod, so I only have to hold the small coil when I'm soldering.
Rufusbduck
Rufusbduck's picture
Last seen: 7 months 2 weeks ago
That looks to me like some very fine soldering work. Mine is improving but not yet ready for prime time.
Scott
vestureofblood
vestureofblood's picture
Last seen: 1 day 5 hours ago
Hi Oldlumens,
I have to say I am very impressed.   Even at a glance the level of quality you are able to produce without the benefit of expensive equipment is clear.   The amount of patience shown in your work is admirable.
I think the upgrade to the battery carrier is probly the most creative part, it has a professional look about it too.
This is not a criticism, merely an observation based on my experience.   The addition of those extra chips being soldered on top of each other is probly going give you the opposite effect of what you are looking for.
Heat is a very serious issue with these 7135 circuits ( as you probly know).  Piggy backing those chips like that will compound the issue.   I have found without exception when these boards are slaved it also causes a heat issue.
My personal SST-90 mglite is powered by a set of 3 drivers like that ( not as pretty as yours Smile ), but in order to keep the current stable I had to heat sink both sides of the boards to fairly thick aluminum plates that touched the outer light wall.    Without this the current will fall like a rock around the 1 minute mark till it bottoms out at like only a couple of amps.
Thanks for sharing man.
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
Rufusbduck
My admittedly limited experience has been that the thermal issues can sometimes be attributed to excess heat from the LEDs. If the led sink is capable of maintaining a constant temperature then you could be okay. If the sink gets hot then the chips will get hot even if they are not being overdriven.
Scott
jmpaul320
jmpaul320's picture
Last seen: 1 week 1 day ago
very impressive build so far… i love the sst90 led… i have a 3d mag with der wichtel 9a buck driver… cool stuff Smile
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
Old-Lumens
Heat sinks arrived today. I bought these from Speedy Metals.
hs1
They measure 1.316-1.317" OD and a typical Maglite ID is from 1.340-1.344", so I will need anywhere from .010-.012" shim/sleeve, to make it tight in the tube.
hs2
They are 1-5/16" aluminum rod stock. It's as close as I am going to get for a Maglite heat sink, unless I have some machined. I will tell you why I do not have some machined. These are about $2.00 each, shipping included. I can live with having to sleeve them with 0.010" copper or aluminum sheet, to make them work. It's close enough for me and it works for the budget. That's what it's all about here isn't it? Trying to make something that works, with what you can afford. Even if it is just a shelf queen.
This week-end, hopefully, I will get to work on finishing this build up.
Old-Lumens
I would say that I'm surprised the couple of extra chips would do so much to overheat. I haven't experienced that yet, but there's always a first time. The drivers will have a heatsink, but I wasn't planning on a heatsink sandwich. I guess I will find out fairly quickly. Thanks for the heads up.
I also plan to include 3 dummy AA NiMHs, just in case I need to do the pack as 3S/3P, instead of 4S/3P.
Old-Lumens
Updated the first post. It works! Sort of.........
nofearek9
nofearek9's picture
Last seen: 6 hours 56 min ago
very nice project,nice mod you did with the drivers.
Manual Man
Last seen: 8 months 1 week ago
Very interesting idea regarding the LED on copper: reminds me of a Led Lenser H7 knockoff I pulled apart a couple of days ago, the leads were wired on the bottom (XR-E) and the center of the LED was pressed (no solder) onto a central plateau.
If you could find a way to electrically isolate 3 pieces of copper while still allowing them to shed heat-easily you could potentially have a quick and easy way of making direct copper bonded LEDs.. something like this would work well for isolation and heat transfer: http://www.e6cvd.com/cvd/page.jsp?pageid=309&prod=16 might get a pit expensive though Wink
Are there any real benefits to in increasing heat conductivity to the cathode and anode of the LED?
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 3 years 3 months ago
I wished I had your skill.
Very impressive.
MRsDNF
MRsDNF's picture
Its looking really promising. You will be in trouble when the people who were talking about the bright light find out who it is. Looking forward to your night shots.
Slewflash
Slewflash's picture
Last seen: 4 months 1 week ago
Looking forward to your beamshots OL!
Slewflash
mattthemuppet
ha, loved the comment about the neighbours commenting about the light – can’t get a better complement than that! Some of my neighbours told me they thought aliens had landed in my garden one night when I was doing beamshots. They seemed disappointed when I told them it was just some of my lights Smile
Old-Lumens
Manual Man wrote:
Very interesting idea regarding the LED on copper: reminds me of a Led Lenser H7 knockoff I pulled apart a couple of days ago, the leads were wired on the bottom (XR-E) and the center of the LED was pressed (no solder) onto a central plateau. If you could find a way to electrically isolate 3 pieces of copper while still allowing them to shed heat-easily you could potentially have a quick and easy way of making direct copper bonded LEDs.. something like this would work well for isolation and heat transfer: http://www.e6cvd.com/cvd/page.jsp?pageid=309&prod=16 might get a pit expensive though Wink Are there any real benefits to in increasing heat conductivity to the cathode and anode of the LED?
Depends on the led as far as electrically isolating. The crees and the SST don't have to be isolated, at least on the center strip that the die is on. That's where the majority of the heat comes from. I think I remember that the SSC leds had to be isolated on the die plate. As far as the +/-lead strips, I don't worry about heat dissipation from them. Maybe I should, but I don't think it's needed.
There are a few cree XML leds out there, on a copper star, but not too many.
Ledsmoke
Ledsmoke's picture
LOL! I love that last bit about shining it on the garage door! I once did something similar with a SST-50 in a homemade reflector driven at 7 amps.
My house is painted with chalk - I think you call that whitewashed in the states - and I just walked 10 meters from the wall and pointed the light directly at the wall, think 90° directly, and turned that thing on! I nearly dropped the thing. Ha ha. Still makes me laugh when i think about it!
Anyway I just wanted to say that so far it sounds really impressive. I've never had me one of those SST-90's to work with so I've no idea about how nice they are. But I sure do look forward to some beamshots.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
noboneshotdog
“lumens”, Your a beast! Nice work!
Thier ain’t no bones in a hot dog. F. York
Old-Lumens
New photos at the bottom of the First post.
A couple teaser beam shots in POST #35
The real beam shots, for distance, will happen Saturday night, if it don't rain...
Chicago X
Chicago X's picture
Last seen: 8 years 5 months ago
Wow.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Suncoaster
Suncoaster's picture
Last seen: 3 weeks 4 days ago
Location: Where the girls are green and the grass is pretty.
Nice work OL.
That shower head reminds me of an exhaust on a motorbike.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
