Due to some misscomunication I’ve ended up with 50 unprotected Panasonic 2900 mah cells that need homes. I’m willing to sell them at cost, $5.00 plus shipping. I’d prefer to sell them in larger batches instead of 1 or 2.
These are genuine cells and I’ve tested a few and they meet the specs.
If anyone is interested in purchasing some please let me know.
Thanks Kevin, Count me in for 4 and I will send paypal payment today.
And thank you Raccoon City for the warm and thoughtful welcome.
I’ll have to get over to ‘Introduce yourself’ today and say hi to a great group on this forum.
Pretty new to this, so thought I might ask. Does these cells being classified as “unprotected” count as a selling point? I understand what protected cells do, would the only difference in a regulated light be that I’d have to pay attention to cell voltage so as to not over discharge them? Being unprotected, does that mean I can pull more than 3A from the cells?
-To those with lights that will not fit a protected yes (and others see point 3)
-you got it!
-This depends on the protection circuit. Some cheaper ones will trip at around that level.
-There will always be some resistance added to the system by adding the protection circuit, so if you are pushing a cell to its max discharge limits the protected cell may slightly diminish the peak output vs an unprotected.
Personally I have no issue running unprotected in single cell applications, but for a multi-cell high current light? Protected cells please!
I would never run a multi-cell light with unprotected (unless they are run in parallel).
Also, it’s a good idea to use a driver designed for li-ion cells; one that will shut down or drop to a low level, or give some warning when low voltage is detected. Another consideration is the integrity of the light against short circuit. If there is any possibility of a short (bent over spring, etc) the protection circuit will save you where the unprotected cell, capable of tremendous current delivery, I don’t want to think about what might happen here. You need to handle these cells with extra extra care, and never allow the terminals to short. Also, make sure you have a well behaved charger.
