The BLF Battery Data Base
163 posts / 0 new
ralf
Last seen: 2 years 11 months ago
…………………….……Battery……..Claimed.Capacity..Discharge.Results..Cell.Dimensions..Protected.……..Charger……..…..Cell.Type……..
Soshine LiFePO4 (3.2V) AA/14500700mAh (min 550mAh)562mAh, 0.5A to 2.0V
 L-50.3mm
D-14.0mm
 No Imax B6 Button Top
Yes, that 550mAh minimum spec is correct. It’s in really tiny print, while the 700mAh claim is in even bigger type than the brand name….
ralf
Powerlion LiFePO4 (3.2V) AAA/10440250mAh (min 200mAh)
133mAh at 0.3A to 2.0V
138mAh at 0.2A
 L-43.7mm
D-10.2mm
ralf
...............................Battery........Claimed.Capacity..Discharge.Results..Cell.Dimensions..Protected.........Charger.............Cell.Type........
4x Lenmar R2G AAA (LSD)
850 mAh
272//322/305 mAh out of package
750/741/756/738 mAh @ 0.5A
756/758/757/743 mAh @ 0.5A after break-in
 L-44.2-44.4mm
D-10.3-10.4mm
 NoMaha C-9000 Button Top
 4x Lenmar R2G AA (supposedly LSD)2150 mAh
192/0/0/305 mAh out of package ("Used [sic] by 4/2013")
1996/2083/1938/2000 mAh @ 0.5A
L-50.3-50.5mm
D-14.2-14.3mm
NoMaha C-9000Button Top
 4x Maha Imedion AA (LSD)2400mAh (min. 2250)
1766/1806/1755/1764 out of package
2224/2279/2217/2252 mAh @ 0.5A
L-50.2-50.3mm
D-14.2mm
 Generic RCR123A "3.0V" LiFePO4 (blue wrapper)500 mAh
270 mAh remaining when received
375 mAh @ 0.5A to 2.0V
L-33.7mm
D-16.5mm
NoImax B6Button Top
 2x Sofirn AAA (LSD)1800 mAh (min 1750) !!!!
272/264 mAh out of package
740/769 mAh @ 0.3A
L-44.5mm
D-10.3mm
 The Sofirn are good mAh/$$ ($2.82/pair at FastTech), but the claimed capacity is far out even by Chinese-lumens standards (either someone got cute in adding a "1", or they mislabeled them with the capacity of their AA batteries....).
The Lenmar "Ready2Go" AAs are clearly not low self-discharge, being empty (or nearly so) even before the labelled "use by" date, and are a poor value compared to the Imedions -- both sets were $10.97.
The Lenmar "Ready2Go" AAAs aren't too bad, and were about half the cost of Eneloops at $5.97/four on sale.  Manufacturer only claims 80% charge retention after 6 months, which is on the low side for LSDs.  The capacity recorded during the discharge portion of the break-in (at 0.18A) was 772/771/773/761 mAh.
snakebite
snakebite's picture
Last seen: 3 weeks 12 hours ago
26650 kingkong from mountain electronics 4/2014
30milliohm
4212 mah@1a
tools used are dick smith esr and original triton.
old4570
Last seen: 2 days 6 hours ago
Hi there!
I saw your battery database thread from 2011 and also that you tested GP AAA Recyko batteries back then. For what it’s worth I wanted to share my results of a 4-pack that I bought today in South Africa. GP ReCyko+, “Stays charged for longer, use 1000 times” AAA size. On the blister pack the capacity is stated “min. 800mAh”.
I’ve tested a single battery from the pack so far and wanted to know if you’d like me to continue testing all 4. The reason why I am PM’ing you is because that thread had useful info for someone like me because I can’t buy Eneloops in SA, they’re simply not being imported here.
Results:
Out of the box the voltage was 1.28V, I discharged it as it was and the capacity was measured as 690mAh or 86.25% of the claimed capacity.
I then charged it full, let it rest for maybe around an hour, before the next discharge which showed a capacity of 824mAh
I tested on a Turnigy Accucell-6, charge/discharge current set at 0.5A, cutoff 0.9V, ambient temperature was 19 degrees C.
Kind regards
This thread/post/topic belongs to the BLF community , and anyone wishing to share ..
2012 I went to school so I could get my Double Diploma in IT , and I completed it in Dec 2013 .
So for two years I was too busy to do this thread / post justice . And it looks to have taken a life of its own ( Thats good ) , so please feel free to share .
Matt
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Agro
Agro's picture
Last seen: 3 weeks 3 days ago
This thread seems pretty outdated. In particular, the table in the first post has seen not updates since 2012. Does it still deserve to be a sticky?
teacher
teacher's picture
Last seen: 2 years 1 month ago
Yeah, as far as I am concerned it does. It still has some good info in it.
Welcome to BLF also. Thumbs Up
old4570
OP is not testing batteries .. ( Well – other batteries )
+ The thread has taken a life of its own .
6 Years ago it was started .. How relevant is this thread ? ( How relevant do people want it to be ? )
It’s not just about the first post , but the information people add to it .
I have seen posts on other forums that are over 1000 pages , now that is a lot of information .
There was even one post that went Volume 2 ( Original post was abandoned and a 2nd started due to the volume of information and posts )
If some one were inclined to DO ( something ) , they could take all the info in this thread , create a data base and post said info in a new thread .. ( which may become a sticky )
It would be a lot of work , ……………….. Hmmm , who would be prepared to do such work ?
teacher
teacher's picture
Well said…. Thumbs Up
Maybe Agro will jump on that little task you mentioned. ……. Wink
CRX
CRX's picture
I did make a similar cell database a couple years ago but got bored maintaining it…
HKJ
HKJ's picture
Last seen: 5 hours 18 min ago
There is always my comparators and reviews, they are being updated multiple times each week.
I have given up on the charts showing all the cells, because I have tested too many cells to make decent looking charts.
Agro
Agro's picture
Sorry, no.
I think there’s a huge value in having a database with all top choices (or better: all known choices). But I don’t have the time to create it, let alone maintain it.
HKJ’s site is superb. But nevertheless, it’s not good enough because it misses some important batteries.
www.dampfakkus.de is similar (tip to HKJ: tables that can be sorted by any column are great).
Digging on both sites is what I do now and I believe it’s about the best battery-finding strategy, for now.
I find searching this thread to be redundant as it’s unlikely to give me a better choice.
So for a question ‘Which battery should I use?’ this thread is no good.
There’s another important question that databases like this answer:
‘How good is this battery?’. This thread would help with such questions about as well when unstuck because a person doing such search would probably use a search tool anyway.
Am I missing something?
