First just do the math after a few times it is pretty easy to determine the mah of each cell in the pack from the voltage and capacity.
I had three HP pack go bad on me so I opened them up and tested.
short story is I have too many cells anyone want 6 samsung icr 1865022e
is it worth paying the shipping to you?
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
I can’t wrap my head around this, i recently found an HP laptop battery and when i looked at the specs it said: 10.8v, 55wh, 4910mah. So i crack it open and find 6 samsung icr 18650 “28a” cells inside, googled and they are 2800mah cells, what i dont understand is how do 6 2800mah cells equal 4910mah?
Try one of these packs if you like LG 4.35 volt cells. These cells willingly made available 2989mAh of power from 4.35 to 3.0 volts on my Opus BT-C3400 Ver. 2.1.
I love these cells!
Has to be that exact type and sticker though, Genuine Dell only.
Ebay item number: 121538052911
He has 2, I bought one. There's one left but his price almost doubled. I payed $30 in my offer. There are other sellers that have them too.
Just wanted to add that the new-ish Dell 60Wh T54FJ packs also contain 4.35v cells. I just cracked open a few and found both LG orange C2 cells (LGABC21865) and Samsung lavender 28A cells (ICR18650-28A). Good stuff!
Maybe it is a smart idea to harvest the 18650 out of this pack. But maybe the Sanyo 18650 aren’t worth getting out of the pack. Hopefully someone can help me
Well, my guess is that you’ll find 1500mah cells if there’s 9 of them, or 2200mah cells if there are 6. But the pack looks kinda old. I got 6 LGDB1 cells from an ancient (7 year old) pack, and the work just fine but lose their charge faster than my newer cells.
How about the other way around?
How does the protection/electronics in the notebook pack behave?
I mean, I have a big notebook, the working time on the pack is not very long.
I bet that is I open up the battery pack there is space.
Can I just put in high capacity cells to get longer runtimes? Go from 6 cell to 12 cells if spacepermists and from 2600 to 3400mAh?
@ Ansarogu; thanks for your answer. I will check the batterypack; my father has same the laptop with a non working screen. I can use his battery; i think it also in better condition.
I suppose it could be possible, maybe not the whole 6 to 12, simply because the battery pack usually don’t have “free” space. But i guess you could go for a replacement of the 6 cells for higher capacity ones. Just keep in mind the cost/performance/benefit of such a thing, not to mention the careful disassembly of delicate electronics etc.
I got 6 red batteries out of the acer laptop pack (2200mah). I testing now 4 in my Liitokala Lii-500.
How do you identify the right model Sanyo batteries ?
The battery got this serial number: first line; MCUA14 and the secondline: 064463 with an big B above the serial.
I made a picture of details: maybe someone can help me with this?
Since you say the pack is rated at 2200mAh, then they are probably standard 3.7V Sanyo UR18650A / R1112 cells. However, most of the Sanyo pulls I have seen with the purple insulating ring have been the UR18650ZT cells, which are rated at 2800mAh. Strange.
There’s an older pink wrapper Sanyo cell with a purple top that was commonly used in laptop packs a few years back. I’m thinking it was a 2250mah cell and I sometimes found them in packs where I expected to see red top Sanyos (2200mah). Some info on older sanyo cells from Boaz here.
Hey guys, i just cracked open a Lenovo battery pack and found 9 Panasonic ncr18650 MH-12210 grey color cells.
According to the info i found, these are 2,900mah cells.
I’d post pictures but i still don know how lol.
you are probably correct.
time to test them out.
are they above 3v each?
do you have an analyzing charger or a hobby charger?
and to post pics you have to host them somewhere and paste in the link using the button with the sunset pic in it.
Hi there snakebite!
The only charger that i have is the Xtar vc2, all the cells showed 3.46v~3.50v. According to the charger, most cells where charged to 2,840mah+. Each pair took about 5 hours on a 500ma current to charge.
sounds like winners to me.
my next step would be discharge at 1a to 3v and see what they deliver.
vc2 can only tell you what it put in.but its a good sign.
Nice score! I have a shed load of those and they take recharges forever and never die.
Hi there! They do seem to hold their own in my stock Convoy C8 (which is the main reason for me having the need for these cells) so that’s good, i charged them all up and have been rotating their usage. But for now they seem like really good cells!
I found those cells in this one “Dell Latitude 60Wh Laptop battery T54FJ” one of my favorite pulls
2) HP MU06 [2011/02]
10.8v 47Wh
6 cells (2 parallel x 3 serial)
=> 6x Samsung ICR18650-22F (2200mAh) [actual]
3) I’m just wondering what the laptop battery pack with the following labels will contain
(this laptop battery still in use, no plan to dismantle yet, but I’m curious what it may contain)
Lenovo (ThinkPad) 2012/05
11.1v 5.6Ah 63Wh
LG Chem 112711 11.1v 5300mAh min.
=> ?? 6x LG 2900mAh??
11.1v 5.6Ah 63Wh
I wonder if there is any place to salvage high drain batteries Electric Scooters, power tools, other mechanical or heat producing applications probably, huh?
Yep, that is where the “good stuff” is, lol. I’ve salvaged some excellent high-drain cells from packs used in battery-powered lawnmowers, landscaping tools, vacuums, and drills/saws.
Brands include Kobalt, Ego, Echo, Greenworks, etc. The last one I opened was a Kobalt pack, and it had 20x Sanyo UR18650RX (20 amp) cells!
I know this is an old thread but I still have a question.
Recently opened up a laptop battery and
6- ICR18650 -22F Samsung SDI.
Can anybody tell me anything about these?
A lie is a lie even if everybody believes it.. The truth is the truth even if nobody believes it.
John 3:16 --
2 Cor 5:17
Hi guys, i have a question:
These batteries actually are 4.3 volts instead of the usual 4.2.
http://budgetlightforum.com/node/13448
Ah, now i understand, thanks!
Hello Guys; you gave me an idea; if got an old Acer laptop; this one got a 10,8v 4400mAh battery-pack. See link of picture for detailed info.
http://s9.postimg.org/b9vvnb9zz/batteryacer.jpg
It is done when it is done
How my BLF Specials generally work, please read before asking Qs
The Q8, Exciting a groupbuy for a Premium BLF special high lumens soda can light!
The GT, A BLF special GIGA thrower
The FW3A, a TLF BLF special small, elegant, powerful triple
Lithium Ion safety 101 important read
Sorry grammarlovers, I am a real King Typo.
http://postimg.org/image/ve8nzv69t/
http://postimg.org/image/577h3wo01/
http://postimg.org/image/a74xbutmp/
I couldn’t find anything on google. I guess it’s time to put them through some testing!
Hi there snakebite!
Excellent Resource !
Also http://budgetlightforum.com/node/25670
So, the formula to calculate individual cell capacity of a random Dell laptop battery:
Capacity: 85 WH
Rating: 11.1Vdc
85/11.1 = 7.66
9 Cells (3 parallel x 3 serial)
7.66/3 = 2.55
rounding up = 2600MaH cells.
Another:
Capacity: 58 WH
Rating: 11.1Vdc
6 Cells (2 parallel x 3 serial)
(58/11.1)/2 = 2.61
or 2600MaH cells
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.
Capacity: 85 WH
Rating: 11.1Vdc
85/11.1 = 7.66
9 Cells (3 parallel × 3 serial)
7.66/3 = 2.55
rounding up = 2600mAh cells.
Another:
Capacity: 58 WH
Rating: 11.1Vdc
6 Cells (2 parallel × 3 serial)
(58/11.1)/2 = 2.61
or 2600mAh cells
Another:
Device: 2009 MSI Wind U100
Capacity: 49Wh
Rating: 11.1V
(49/11.1)/2 = 2.21
The first 2 laptop battery packs I tried opening had the following:
1) HP PH06 [2010/03] 10.8v 4200mAh 10.8v 47Wh
6 cells (2 parallel x 3 serial) => 6x Sanyo UR18650A (2200mAh) [actual]
2) HP MU06 [2011/02] 10.8v 47Wh
6 cells (2 parallel x 3 serial) => 6x Samsung ICR18650-22F (2200mAh) [actual]
3) I’m just wondering what the laptop battery pack with the following labels will contain (this laptop battery still in use, no plan to dismantle yet, but I’m curious what it may contain)
Lenovo (ThinkPad) 2012/05 11.1v 5.6Ah 63Wh LG Chem 112711 11.1v 5300mAh min. => ?? 6x LG 2900mAh??
2650mAh
or 2600mAh actual.
View BLF with NO Commercials Here!
Cool idea.
John 3:16 --
2 Cor 5:17
All the info you could ever want:
Data Sheet
HKJ review
Thank you very much for the info
John 3:16 --
2 Cor 5:17
