Small Sun ZY-T08
137 posts / 0 new
southland
southland's picture
Last seen: 2 months 1 day ago
viffer750 wrote:
Ledsmoke wrote:
Hi Viffer750. What kind of mod did you do to the driver and why did you (of all people) do a “conservative resistor modification” ??
I’d want to drive that thing… You already know what I’m gonna say don’t you Embarassed
I soldered an additional 0.22ohm resistor parallel with the 3 small smd resistors.
1
This increases the driver/led current. Now the measured current on the driver side is 3.2A.
And the output brightness increased from 600 to 750 lumen, and from 41kcd to 50kcd.
Trying to find the right resistor to do this mod, found the .22 ohm resister in 1/2 watt, 1 watt, 2 watt, 3 watt. Which one should I use and what do the different watt numbers mean?
heggood
Last seen: 10 months 3 weeks ago
Is this light powered fully with just one battery or does it take both for full power? Is it more safe to use. Just one versus two?
garrybunk
garrybunk's picture
Last seen: 1 week 2 days ago
In stock form one battery is just fine. Cells are in parallel and therefore pretty safe. I do believe it's still best to use matched cells (same brand, same capacity).
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
light junkie
light junkie's picture
By now but this light and reflector makes a SUPER host for the MT-G2 mod .
Lj
JasonJ
Last seen: 2 years 1 month ago
Has anyone done anything new or interesting to this light in the past 2 years? I meant to buy one long ago, forgot all about it. I’m back to thinking about this light vs the Courui D01, both lights seem to be less prolific on the retailer sites than they used to be.
Is there a newer equivalent light that I should consider in place of the ZY-T08?
cera@1967
Last seen: 1 week 3 days ago
 This light is a good thrower even in it's stock form . A  dedomed XM-L2 , driver resistor mod up to 4-4.5 Amps , a little work on the high of the spacer between led and reflector , double springs in the tail (or wire bypass) , a capable  switch (Osrom) ,and you gone have a new lover...Just give it a try !...
Adrian
JasonJ
cera@1967 wrote:
 This light is a good thrower even in it’s stock form . A  dedomed XM-L2 , driver resistor mod up to 4-4.5 Amps , a little work on the high of the spacer between led and reflector , double springs in the tail (or wire bypass) , a capable  switch (Osrom) ,and you gone have a new lover…Just give it a try !…
Nice… good to know! I can’t believe I haven’t bought one of these already… but I go through “interest phases”, and often my interest in flashlights wanes in the winter months. Probably because I get up north into the woods off of the lake every week in the summer; it provides LOTS of opportunities to use high powered flashlights.
Mike C
Mike C's picture
Last seen: 7 hours 8 min ago
Personally I think this light is way too big for tail switch only so I recommend installing a momentary side switch with a dual switch compatible driver. Mine was just laying in the drawer collecting dust before I did it.
JasonJ
A good idea. Did you post about that mod anywhere on the forum? I’d love to see what and how you completed that (not that I couldn’t figure it out, but it helps to have a baseline idea).
Mike C
Mike C's picture
Probably overkill for your intentions but I went all in and designed my own dedicated drivers for series cell conversion: http://budgetlightforum.com/node/40759
For just side switch mod with existing LED you could piggy back the current driver with any driver of your choice. There is a lot of room inside that pill.
JasonJ
Mike C wrote:
Probably overkill for your intentions but I went all in and designed my own dedicated drivers for series cell conversion: http://budgetlightforum.com/node/40759 For just side switch mod with existing LED you could piggy back the current driver with any driver of your choice. There is a lot of room inside that pill.
Read through your thread.. nice work. You and my dad would have gotten along nicely.. he scratch built a lot of electornics in his years. Former Motorola field Tech.. that man could wield a soldering iron and acid etch a pcb board like no one else. The crazy cool stuff he built…. much like your work.
Thanks for the tips.. I’ll be ordering soon. Looks like Fastech has it in stock at the best price. About $21.
MRsDNF
MRsDNF's picture
Last seen: 5 months 6 days ago
The o’ring on the battery tube to seal with the head is way to small on the ZYT08 I’ve been getting from Fasttech. I’ve been using C8 bezel o’rings that work a lot better.
JasonJ
Good to know.. I had read that the o-rings used were kinda crap.
Has anyone put an XPL-HI in one of these? If so, I’m curious how it compares to a dedomed XML2.
Might just have to try it myself.
zeremefico
zeremefico's picture
Last seen: 9 hours 43 min ago
I have tried with xpl hd but did not love the beam. It had some ring around spot.
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
kiriba-ru
kiriba-ru's picture
Last seen: 4 hours 7 min ago
imagebam.com
Mike C
Mike C's picture
kiriba-ru wrote:
imagebam.com
Nice work! Personally I’d still rather just put a side switch in Smile
