New Lens L2
I'm after a decent lens for the Uniquefire L2
The current lens is 29.35mm
I would prefer it to be glass but not mandatory.
I await your suggestions :-)
Charles
Try the AR coated from KD. Many bought them and we were impressed so far!
http://www.kaidomain.com/ProductDetails.aspx?ProductId=9064
Budgeteer, aren't these a bit short? He needs some 29,5mm(30?) and these are 28mm...
Actually they are the correct size for an L2 - I have one of those in an L2 in front of me. I'd guess the KD spec is smaller than the lens actually is.
These lenses from KD fits well on a Solarforce L2P and a KD R7 (Seraph clone) and AR coating seems to work well as they look like there is no glass there. A Uniquefire can be a bit wider than a real Solarforce but so looks my R7 and these lenses fit well. I have a Solarforce L2 (fake) I got from KD looking wider than my L2P but it may be the thickness of the material. It was a bit stiff to open the front bezel and couldn't try my 28mm lens on it.
Those lenses fit perfectly in the 2 different seraph clones i have the solarfarce L2 and the solarforce L2 i have, the UF-504b new design. Did not bother with the 501B which are unworthy of such a lens. The best use for those 501B is as UV lamp.
Buy these if you also need R5 dropins. Cheap solution.
Cheers guys lens ordered :-)
