Test / Review: TrustFire 14500 900mAh (Blue)
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 23 hours ago
DSC_0501
Official specifications:
  • Protected 14500
  • 3.7V
  • 900mAh
TrustFire%2014500%20900mAh%20(Blue)-info
These batteries are significantly below the rated capacity.
DSC_0500
DSC_0502 DSC_0503
DSC_0504
DSC_0505
DSC_0506
TrustFire%2014500%20900mAh%20(Blue)-Capacity
There is a signifant capacity difference between the two batteries and the protection prevents doing a full 2A trace.
TrustFire%2014500%20900mAh%20(Blue)-CapacityTimeHours
TrustFire%2014500%20900mAh%20(Blue)-Energy
TrustFire%2014500%20900mAh%20(Blue)-PowerLoadTime
TrustFire%2014500%20900mAh%20(Blue)-TripCurrent
The protection is at a low value on this battery, it might be a good value to protect the battery and user, but when playing with some high power lights it is a little low.
TrustFire%2014500%20900mAh%20(Blue)-Charge
Conclusion
Looking at one battery, it works well up to my 1A trace, but the capacity difference between the batteries is not good and with the low capacity, I will only rate the battery as acceptable for a cheap battery.
Notes and links
Comparison to other LiIon batteries
Edited by: sb56637 on 08/26/2014 - 17:45
kreisler
kreisler's picture
Last seen: 7 years 11 months ago
Thanks a lot!!
Big Smile
I got up to 830mAh out of the 14500 Trustfire flames!!
Ref: http://budgetlightforum.com/node/6564?page=1#comment-134138
*FMI* i got 4 i/o sh
SashiX
SashiX's picture
Last seen: 7 years 7 months ago
H, can you sort your list by type (10440, 16340, 14500, 18650… and then by brand if you want) and not only by brand? Smile You can also add one line (with no data) just for cleaner look. Thanks.
scaru
scaru's picture
Last seen: 4 years 12 months ago
Thanks for the test!
kreisler wrote:
Thanks a lot!!
Big Smile
Without opening the thread I can guess you got yours from DD. Silly
HKJ
HKJ's picture
SashiX wrote:
H, can you sort your list by type (10440, 16340, 14500, 18650... and then by brand if you want) and not only by brand? Smile You can also add one line (with no data) just for cleaner look. Thanks.
Why? It requires a lot of work and makes the name part of the list look unordered! Wink
I have done it and it includes all lists, it makes it easier to compare batteries of the same size. In windows you might need to press F5 to refresh the graphic. But I am not going to add a blank line, that would require a lot of changes in my script.
kreisler
kreisler's picture
scaru wrote:
Without opening the thread I can guess you got yours from DD. :P
i think my role is getting old Steve
SashiX
SashiX's picture
It’s OK with 18650 – almost all your tested cells. But when I need a, lets say, 14500 cell review, IMO, would be much easier to compare 2 or 3 14500’s you’ve tested when they are in order (I mean, 1,2,3) and not AW 14500, then, 10 places later Eagletac 14500… (just an example). When I see first one, and while I search for the other one, I forget everything, because I need to read other brands and types, etc Flat Stare
I don’t wanna say you need to create a stat list for every type, but (again, IMHO) it will be much easier when you have dozen and dozen bars. You sort them by size/type, and then by brand too.
i.e.:
TF 10440
UF 10440
(blank line as separator)
AW 14500
ET 14500
TF 14500
UF 14500
AW 16360
If you have new 14500 review, you just insert another line in 14500 category. Actually, you will need to order them only once, then if the new brand starts with “B”, you just inserts it between “A” and “C”. Logical :bigsmile:
Just my .02, H Wink
sb56637
sb56637's picture
Last seen: 7 hours 48 min ago
Thanks very much! Frontpage’d and Sticky’d.
hoffig
Last seen: 2 years 1 month ago
I got about 600-650mAh from my recent Trusfire blue 14500s at 0.7-1A (I’ve not tested at lower current because about 0.7A is what my application uses them at).
Some year-old Flame models have given me about 750-780mAh @1A.
They all have holograms and are assumed genuine because of that.
